Old 11-03-2012, 11:11 AM   #1
Shep OP
Vagabond
Shep's Avatar
Oddometer: 508
1200 RT No Power
Recently picked up a 2005 1200RT that has been sitting for the past year+. Ran fine, but the batter was weak, so I put a new battery in it. Was performing fine. Parked it for a week and jumped on it yesterday to ride to work. Turned on the key, all the instruments came on, everything appeared normal. Hit the starter...nothing. No click, no attempt at a turnover, nothing. Had to go to work, so I checked the battery the next day...full charge. Now, even the instruments panel will not come on. Nothing. Any suggestions on where to look first? Thanks.
Shep
Looking for the Road Less Traveled...and a 690 Duke.
http://motorheadcoffee.wordpress.com/
Shep is offline   Reply With Quote
Old 11-03-2012, 12:21 PM   #2
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,315
I would check the battery terminals/connections first. If you have a voltmeter you can then start testing the voltage and work your way towards the starter and fuse panel.
GreaseMonkey is offline   Reply With Quote
Old 11-03-2012, 04:01 PM   #3
mwood7800
Oddometer: 611
My 05 did the same thing it was the pos wire on the starter loose
mwood7800 is offline   Reply With Quote
Times are GMT -7.   It's 06:47 PM.
