Old 11-14-2012, 09:26 AM   #1
Dan Alexander OP
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,656
Swingarm Paint
The PO spilled gas on the swingarm and tranny and they're a nice piss yellow now.
Is there a good aftermarket silver that matches closely and doesn't need a primer? I've got things apart for a clutch replacement and now's the perfect time for a touch up.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 11-14-2012, 09:33 AM   #2
LaurelPerryOnLand
Oddometer: 3,482
100 THREADS all GS/GSA owners should read.
http://advrider.com/forums/showthread.php?t=836736
35. HOW CAN I FIND PAINT THAT MATCHES MY BIKE/YEAR?
http://www.colorrite.com/index.cfm?killnav=1
LaurelPerryOnLand is offline   Reply With Quote
Old 11-14-2012, 09:59 AM   #3
Dan Alexander OP
Oddometer: 7,656
Try and get a BMW paint .. I went to 'motorcycles', then 'street' and BMW doesn't come up as an option.
Plus, it'll probably be a base coat clear coat with a primer, no?
I'd like a sliver in a Home Despot type of paint with primer built in.
I tried S100 and no luck. From reading on UKGS's Forum the stains won't come out with anything you can do besides top coat it.
Old 11-14-2012, 09:38 AM   #4
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,666
Man I'm surprised gas would do that to engine paint. Did u try something like S100 on it? I know it's a little harsh but since you are planning on reprinting anyway, I wonder it it would take it off with some good scrubbing?
AviatorTroy is offline   Reply With Quote
Old 11-14-2012, 10:06 AM   #5
LaurelPerryOnLand
Oddometer: 3,482
which of your bikes are you trying to paint?
In the meantime:
http://advrider.com/forums/showthread.php?t=382166
Also...if you've got any part on the bike (same color) that's removable...take that part to a PROFESSIONAL PAINT STORE (not Lowe's or HDepot) and they can MATCH the paint and put it in a PROFESSIONAL rattle can with PROFESSIONAL quality nozzle.
Otherwise...you're screxpdgdkskdkdk!.....
LaurelPerryOnLand screwed with this post 11-14-2012 at 10:19 AM
Old 11-14-2012, 10:31 AM   #6
Dan Alexander OP
Oddometer: 7,656
Thanks for the link which led to another thread which .....
Looks like Krylon Dull Aluminum with Krylon Satin Clear will do the trick and should be available around the corner.
Old 11-14-2012, 10:51 AM   #7
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,591
Uuuuuh.....this is gonna be good.
Photos please...before and after.
If you want my opinion (and you probably don't), repaint with rattle can only after trying other remedies like rubbing compound or a wax/cleaner containing an abrasive like pumice.
def is offline   Reply With Quote
Old 11-14-2012, 12:37 PM   #8
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,161
Hey Dan, I use the Krylon Dull Aluminum #41403 available at your local Cambodian Tire.
The Rustoleum ultra cover semi gloss clear finishes the job (uv resistant/non yellowing) available there too.
The trick is to do light coats - comes out as close as you are going to get.
Even my local body shop could not come up with a better match.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 11-14-2012, 01:24 PM   #9
Dan Alexander OP
Oddometer: 7,656
Perfect, thanks Reto.
I'll head over there tonight and get some.
Old 11-14-2012, 01:23 PM   #10
Dan Alexander OP
Oddometer: 7,656
http://www.ukgser.com/forums/showpos...8&postcount=14
Now I need to find it locally
http://www.kilz.com/hammerite/v/inde...008a05d103RCRD
Old 11-14-2012, 03:50 PM   #11
tar356
tar356's Avatar
Oddometer: 83
Kryon Dull Aluminum is the stuff...
http://advrider.com/forums/showthrea...=821333&page=2
Scroll down to post #26. I painted the handlebar clamps, risers and the back housing for the dash.
I like it without any clear, but a light coat of satin clear does make it look like powdercoat.
Todd Rudaitis
tar356 is offline   Reply With Quote
Old 11-14-2012, 04:46 PM   #12
Dan Alexander OP
Oddometer: 7,656
Old 11-14-2012, 05:20 PM   #13
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,122
Duplicolor Ford Silver metallic w/clear coat almost R1100 oem silver-a tad brighter but no one can tell the difference after polishing the original paint.
followed by
Just remember, once you're over the hill, you begin to pick up speed.
Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.
krellheat is offline   Reply With Quote
Times are GMT -7.   It's 04:32 AM.
