Old 11-15-2012, 07:20 AM   #1
rossguzzi OP
Oddometer: 239
How to TB balance
I am still getting use to navagating around this site. I have not found how to balance the throttle bodies yet. Can someone point me in the right direction please?
rossguzzi is online now   Reply With Quote
Old 11-15-2012, 08:39 AM   #2
AdvGa
AdvGa's Avatar
Oddometer: 1,320
I am not sure how it is done with Throttle Bodies... but it should be similar to the links done with Carbs:
http://www.advrider.com/forums/showthread.php?t=568920
http://www.advrider.com/forums/showp...4&postcount=10
AdvGa is offline   Reply With Quote
Old 11-15-2012, 01:41 PM   #3
DirtyADV
DirtyADV's Avatar
Oddometer: 1,431
Send a message via ICQ to DirtyADV Send a message via MSN to DirtyADV
Not sure either how it works on the fuel injected bikes but here is a penny tech solution on car syncing on a carbed LC8
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 11-15-2012, 02:43 PM   #4
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here is a link to the TBS on a 990 SuperDuke:
http://www.superduke.net/forum/viewt...=asc&highlight=
by lockers » Sat Jun 21, 2008 1:20 am
I use the vaccum hoses that connect to the IAP (intake air pressure) sensors. Theres one on the frame beside the left side of the airbox and one just behind the radiator filler cap on the right. It's just small sensor with one thin hose and elec plug connecting to it, mounted in a rubber holder. Just pull the hose off, stick a joiner in the end of the existing hose and then connect the carbtune hose to that. You must disconnect the Elec plug too, or it will stall when running. You will have an FI light to come on too, due the the disconnected IAP sensors but don't worry about that.
The adjustment/balance screw is inside the airbox, on the left side of the rear throttle body. You need to raise the tank/remove the air filter to get to it. Then just tweak it until she's running sweet and re-assemble.
I do mine every minor service.
Old 11-15-2012, 04:17 PM   #5
rossguzzi OP
Oddometer: 239
So sorry I meant carb balance. I am so use to talking about throttle bodies (FI) !
Thanks for all the links etc.
Cheers.
Old 11-26-2012, 06:48 AM   #6
Hipster
Hipster's Avatar
Oddometer: 1,433
To sync the throttle bodies on FI 990's is it best to mechanically adjust the TB screw or make the adjustment thru software (TuneECU)?
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is online now   Reply With Quote
Old 11-26-2012, 02:29 PM   #7
Geek
oot & aboot
Geek's Avatar
Oddometer: 25,748
I use one of these:
Couldn't be easier... stick it in one.. stick it in the other.. make sure the reading is the same.
if it isn't adjust the screw (mentioned above) until they match.
You are basically measuring the actual air consumed.
Hope this helps
www.motogeek.com
Old 11-27-2012, 04:51 AM   #8
SlickSix
SlickSix's Avatar
Oddometer: 177
In my CBR F3 and F4i, which is Fi, I do it the grandpa way and as never failed me.
A piece of wood with 1m x 15 cm with 4 fishtank silicone hoses plugged together on the bottom with some small T´s and filled with regular car/bike oil.
Just plug the other end of the hoses to the TBs and adjust. Just like with a Carbtune only waaaaaaaaaaaaaay cheaper
SlickSix is offline   Reply With Quote
Old 11-27-2012, 04:55 AM   #9
SlickSix
SlickSix's Avatar
Oddometer: 177
Old 11-27-2012, 05:03 AM   #10
SlickSix
SlickSix's Avatar
Oddometer: 177
double post
Times are GMT -7.   It's 06:44 AM.
