11-15-2012, 03:26 PM
#1 |
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,083
Dead airhead, what now?
Wonder if I can get some advice here? The other day I went out and started up the old r75 same as always, she irked right up and seemed to be ok. Here is the issue, I had it a little richer than normal because i had been tinkering with carb settings over the last week or so but she still started right up and seemed ok, at first. As I at there in the driveway with the choke on and engine warming I burped the throttle a few times and then BOOM, a big backfire! Oops! It sputtered and died and I have not been able to get her running again. I have had the carbs off a few times looking for dirt or something but find none, I seem to have spark at the plugs but it just spins over and backfires some times. Any thoughts? It would always fire right up before, maybe turn over once and catch and idle just fine. When I pulled the plugs looking for spark I did take a flashlight and look into each cylinder, it seems that the valves are all moving ok as well as the pistons, it blows my hair back as I look into the plug hole...hummmm
If you can't fix it with a hammer, you've got an electrical problem! |
11-15-2012, 03:32 PM
#2 |
Oddometer: 804
It was probably just unburnt fuel igniting in the muffler. How long was it idling? Try leaning the mixture some.
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= Big Bamboo screwed with this post 11-15-2012 at 03:56 PM |
11-15-2012, 03:36 PM
#3 |
Oddometer: 453
some thoughts...
Possibly the points, if that is what the bike has.....have closed up some.
Check ALL electrical connections......clean and grease. Could be CARB troubles....Perhaps you adjusted them a little TOO much....Maybe BACK off the settings that you changed, BACK to where they were before. New or clean and gap the SPARK PLUGS. Backfiring is usually TIMING and or LEAN condition. Good Luck and please post back. spo
spo 1973 slash 5 toaster spo123 screwed with this post 11-16-2012 at 12:26 AM |
11-15-2012, 03:38 PM
#4 |
Oddometer: 1,083
Checked one when I had some time last night, hope to get to the other tomorrow, what could have happened to them? Rupture? They were ok when I went through the carbs this spring. Guess I will have to pull the valve covers and timing cover tomorrow evening as well...although I don't really know what to look for now
11-15-2012, 03:43 PM
#5 |
ShadeTreeExpert
Oddometer: 4,980
In your profile it says you have a 1973 R75/5, I suppose this is the bike in question?
Do you have a booster or any other modification to the ignition? I would start with ignition. You have points and they can be loose. Check the point gap and then check timing. I do not suspect the carbs at all. A little rich on the mixture screw does not blow up engines. It makes the plugs black and that is usually all it does. Many engines today are being run rich because of the crap we have for gas. But while we are talking about carbs? The ones that your bike was built with are 64/32/9 & 10. If these have not been modified the mixture starting point for them is 0.75 (3/4) turn out.
Never memorize something you can look up. ---Albert Einstein |
11-15-2012, 03:53 PM
#6 |
Oddometer: 1,083
Yep diston, same bike we have talked about before, stock everything. The plugs were black when I pulled them as I had the mixture screws almost one full turn out. Definitely richer than normal, usually the bike likes things closer the the half out point and it runs pretty good, more and she gets a little too fat and muddy. Anyway, the timing was next and that's what I will tackle tomorrow. Dang thing is, I just checked the timing and points about 100 miles ago and all was well...I will let you know what I find out! Thanks as usual!
11-15-2012, 04:06 PM
#7 |
ShadeTreeExpert
Oddometer: 4,980
Every time everybody else is saying carburetor, I almost always start with the ignition. We have lost touch with these things in our joint consciousness. The fact is you could have adjusted the points yesterday and they are still suspect today. Often times the screw holding the adjustment is not tight enough and it slips. Or grease was not put on the rubbing block and they wear prematurely. If you don't have a broken valve head bouncing around inside the cylinder then I think it's ignition.
Many things will cause poor running and then eventually not running. But the ignition can go all at once more often than a lot of other things. I never heard of the wind blowing my hair type compression test?
11-15-2012, 04:09 PM
#8 |
Oddometer: 1,083
Yep, the breeze out of the plug hole is a Kentucky compression test! Or at least tells me I have something
11-15-2012, 05:21 PM
#9 |
Oddometer: 1,677
Spark?Fuel?Air?
"Nostalgia ain't what it once was" |
11-15-2012, 05:37 PM
#10 |
Who Me?
Oddometer: 484
Always go back and reverse the last thing you did before the problem occurred.
11-16-2012, 01:25 AM
#11 |
Oddometer: 1,246
I'll take this at face value and say you had an backfire and it came through the airbox. If this was the case then I would look at the carbs and see if any seals were blown out or if the diaphragms were ruptured. I would also check the floats and see if there is any crud. Turn the gas off and take one of the bowls off. Turn the gas back on and see if you have flow. Then gently push up on the float to see when the gas stops. Do the same for the other side. But avoid a mess and put the other bowl back on.
I've had this happen too with miss adjusted valves, jumped timing and bad ignition.. But since it was running fine and you were fiddling with carbs I would start there. If you do the above and all seems well, I would re-do the carb adjustments, and check to see if the cable runs are correct if you had the tank off.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S Save lives. Legalize lane sharing. Cow eyes don't glow. |
11-16-2012, 03:51 AM
#12 |
Oddometer: 3,733
That's a classic points problem if ever I heard one.
11-16-2012, 05:35 AM
#13 |
Confirmed Curmudgeon
Oddometer: 3,849
I'll agree with y'all. Start with the points. And check the carbs.
--Bill
'73 R60/5 Toaster |
11-16-2012, 02:00 PM
#14 |
Out of the office.
Oddometer: 4,942
Another vote for looking at the points.
A few things to add, replace your plugs and make sure the HT leads and coil are also in decent shape. Make sure the battery has a nice full charge. Double check all the grounds, especially the ones in the ignition and starting wiring. These bikes bounce and vibrate and stuff can get loose. Get a weak spark slightly foul the plug up and stuff spirals quick.
On vacation for a spell |
11-16-2012, 03:39 PM
#15 |
Oddometer: 1,083
OK you guys saved the day once again! SHE IS ALIVE! Looking at the points after work showed that the gap was a little off so I decided to swap them and condenser for the items I bought some time back. I really didn't like the thought of getting the old girl some distance from the house and having an issue on the side of the road. Anyway, the replacements fixed me up! The only thing I really saw was this original part...
Says it was made in West Germany on the back so it was an older part, maybe original, anyway she is running and I thank all that replied! Hope someone else will be helped by this as well! LOVE ADV!
