Old 11-29-2012, 11:59 AM   #1
Dustodust OP
Dustodust's Avatar
Oddometer: 673
KTM 950/990 no buffet windscreen
This windscreen is shortened and laid back to speed up the airflow and send it overhead instead of dragging through like the stocker.. It is a huge improvement over the cut down stock rally style windscreen too. The angle of the rally screen is great for accomodating instruments , but the near vertical angle and narrow shape causes horrible buffeting and drag turbulence at higher speeds.
The design is also completely out of the way when riding off road and is flexible for improved safety..
this version still allows minimal wind protection and improved airflow
.....and it looks good too while cutting through the wind sport style instead of crashing through like the stock rally style
This sport short screen is crafted with the advantage of low resin to fiber reinforcement ratio using a rubber top infusion mold which eliminates air entrapment to increase strength and assures proper curing of the resin. It incorporates high flexibility Iso blend infusion resin with UV protection for the highest quality part possible .
Extremly strong, flexible, lightweight with excellent fit and finish
In Gloss Black , black chemical resistant gelcoat with carbon fiber/ fiberglass $130 + shipping
In all carbon fiber , gem quality carbon under glass with UV resistant resin $ 210 + shipping
In gloss black gelcoat
tough durable chemical resistant finish
this part is only 2-3 mm thick and very flexible with a later of carbon fiber to add additional strength
in Carbon Fiber , fabricated using 3 layers of 2x2 twill carbon fabric in clear UV resitant resin , tough durable chemical resistant finish , flexible and strong
These parts are fabricated using the best materials and methods in the industry and are the result of a lot of research and consulting with industry professionals to be sure it is done right . No shortcuts or cheap materials used. Each part takes about 6 hours of careful craftsmanship to cast .cut and trim, and materials are expensive at about $45 in resin and fabric each
04 KTM 950 S
04 KTM 525 EXC street plated
Dustodust screwed with this post 11-30-2012 at 04:11 PM Reason: spell check, add content
Old 11-29-2012, 07:17 PM   #2
ontherock
ne'er do well
ontherock's Avatar
Oddometer: 31
better windscreen
Very nice product, thanks D2D, I'm happy with mine, much smoother, with the stock screen I felt like I was being beat by seagulls.
ontherock is offline   Reply With Quote
Old 11-30-2012, 12:13 PM   #3
Dustodust OP
Dustodust's Avatar
Oddometer: 673
Thanks OTR
amazing how being laid back a little can make such a difference
and you got one of the first experimental ones , the latest ones are much better quality ,the New ones are UV resin and infusion , the early ones were vacuum bagged epoxy resin
Glad to hear it is holding up OK !
04 KTM 950 S
Old 12-01-2012, 10:47 AM   #4
mototahoe
nevada adventurer
mototahoe's Avatar
Oddometer: 148
Black Gloss please........
PM sent.......Thanks
04 950 Adventure GO!!!
07 950SE
07 525EXC
08 Ducati Hypermotard
mototahoe is offline   Reply With Quote
Old 12-01-2012, 07:44 PM   #5
zgfiredude
Oddometer: 521
Looks great. Very interested.....would love to see a pic of the cockpit area behind the screen. And perhaps with a measurement of the height above the stock dash.......how much room is available for a GPS?
Thanks!!!!
zgfiredude is offline   Reply With Quote
Old 12-02-2012, 08:56 PM   #6
Dustodust OP
Dustodust's Avatar
Oddometer: 673
Thanks!!!!
Here is a picture of the typical backside , (carbon or black). straight up line off dash panel yields 2 3/4" or 70mm to 10mm at front
Not a lot of room for a GPS but the air sure is smoother coming over the top
the backside is a fine textured surface carbon
04 KTM 950 S
Old 12-03-2012, 12:20 PM   #7
Dustodust OP
Dustodust's Avatar
Oddometer: 673
It took me 3 months of failures and successes to finally figure out how to do this but now I made it happen
I rode for several years with a hacked up stock screen that I cut and layed back to speed up air and stop the buffetting of the stock rally style windscreen
I started out to just make one for myself but when I showed it around I got a lot of requests so I made some more
the first ones I was making with a crude basic mold and they took about 30-40hours of post finishing to fix all the bubbles that normnally happen with vacuum bagging. So I had to stop and regroup and devise another method if I was to suceed
so I set out to do resin infusion which produces a flawless part with no entrapped air ' the resin is pulled into the reinforcement fabric by vacuum
I built the mold after making a positive plug using tooling gelcoat and special resin made for molds
there is a careful process to make the mold
the first one I made got ruined when I didnt cure it enough, got the part stuck to the mold and I had to start over and make a new mold
I had a materials supplier make the tooling, a rubber top for the infusion
it took weeks of failures to finally find a process to make gem quality carbon fiber parts now I have a dependable process and cut the time down to just a few hours to make a part
the part is made by carefully making a sandwich with the fiber material , then a perfect vacuum is held with no leakdown , then the resin is infused through the fabric, here it is going in
when it comes out of the mold it looks like this
after the part is properly cured , it takes about an hour of skilled craftamnship to cut and shape and polish
Easy
now hopefully I can sell a few now to recoup some material costs
04 KTM 950 S
Dustodust screwed with this post 12-03-2012 at 12:33 PM
Old 12-05-2012, 12:35 AM   #8
Dustodust OP
Dustodust's Avatar
Oddometer: 673
Here are some more being cut and polished
04 KTM 950 S
Old 12-05-2012, 09:49 PM   #9
harcus
harcus's Avatar
Oddometer: 1,169
Nice work, D2D! As a guy who spent many, many years doing this for aerospace, etc, these look nice. RFI certainly has it's place.
Want Creative Adventure Products? - See Globetrottin.com
Current rides - 03 ST1300 72k, 07 990Adv 33k, 12 500EXC 5k
harcus is offline   Reply With Quote
Old 12-10-2012, 10:43 PM   #10
Dustodust OP
Dustodust's Avatar
Oddometer: 673
thank you sir, that means a lot
I suppose you appreciate the difficulty , I have heard even pre-preg and autoclave also takes some post finish
04 KTM 950 S
Dustodust screwed with this post 12-11-2012 at 02:35 AM
Old 12-06-2012, 10:17 PM   #11
Rootkiller
Rootkiller's Avatar
Oddometer: 343
Great work, My wife and I ride 950/990's and will be trying this out
Rootkiller is offline   Reply With Quote
Old 12-13-2012, 08:49 PM   #12
reollc4
reollc4's Avatar
Oddometer: 214
New screen
I have recieved my screen and it looks fantastic, great vendor to deal with and great international postage, took 11 days to Australia concidering the time of year thats great.. Yet to go for a test ride will post pictures and report later.
Reollc4
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure
99 XR400 electric start
95 DR350se
reollc4 is offline   Reply With Quote
Old 12-14-2012, 12:13 PM   #13
Rootkiller
Rootkiller's Avatar
Oddometer: 343
Just got mine also,Great looking screen.
I will get a chance to try it next week!
Old 01-05-2013, 01:40 PM   #14
procycle
procycle's Avatar
Oddometer: 1,614
Now that you have the process down is there any chance you would add a taller version?
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 01-22-2013, 03:51 PM   #15
procycle
procycle's Avatar
Oddometer: 1,614
Bump...
Times are GMT -7.   It's 10:55 PM.
