Go Back   ADVrider > Riding > Regional forums > Alaska
Old 12-06-2012, 12:30 AM   #1
Alcan Rider OP
Frozen Fossil
Alcan Rider's Avatar
Oddometer: 3,924
What's Wrong With Me?
Wait a minute, before you all get in line to answer that – it was meant as a rhetorical question!
What I'm referring to is this: I'm getting tired of the cold. And it's not even really COLD! yet. Just barely bounced off 50 below this morning. In years past, I remember being pleased when it warmed up to 45 below. But this morning the Jeep couldn't cope with the low temperature and the ECM had it pouring gas into the engine, giving me 6 mpg where it would normally deliver over 18 mpg. With half a tank of gas when I pulled out of Glennallen it should have made it to Anchorage and through half of my shopping without running out. But at the rate it was burning petrol we would not have been able to reach Palmer. Had to turn around 25 miles out and go back for more dead dinos. Then, when I drove into the coldest spot, the transmission started acting up, with the torque converter clutch locking and unlocking and shifting up and down violently. Finally went back to the apartment and parked it. There's something to be said for carburetors and manual transmissions.
Besides vehicles, there are heating systems. Or, more accurately, systems that are supposed to produce heat. And I'm tired of them. A wood stove. Simple (like me), works even when there's a power outage (unlike me), romantic (definitely not like me!).
Everything is being controlled by little squares, octagons, trapezoids, tiny cans on two or more legs – all glued together on a little board in patterns discernible only to electronics wizards who speak in strange tongues. “Inductor” “Diode” “Nand gate” “NPN transistor” “NMOS” (how the heck are you supposed to pronounce that?) “Bipolar transistor” (how do you administer lithium to a transistor?) And so on.
And you know what? The literature for those little devices often says “Storage at 0° to 40°C” In automotive use they often test these things clear down to – are you ready for this? - the incomprehensible temperature of -40°C/F!! Yeah, a balmy day in wintertime Alaska.
Okay... maybe I'm just getting old and cranky. Naw, it can't be that. Guess I'm just not into this "Global Warming".
But I'm sure looking forward to summer.
"I am in the prime of senility." Ben Franklin
I'm so old I remember when the gallons rose faster than the dollars on gas pumps.
The Lure of the Dalton, The Lure of the Dempster, Haul Road Chronicles, My Evening Rides, Alaska Primer
Haul Road Primer
Alcan Rider is offline   Reply With Quote
Old 12-06-2012, 12:48 AM   #2
nuttynu
nuttynu's Avatar
Oddometer: 938
Wink
Less snow, yet cold. Maybe well have a fast break up = riding
nuttynu is offline   Reply With Quote
Old 12-07-2012, 04:44 PM   #3
beamertwin
Paul
beamertwin's Avatar
Oddometer: 1,068
Jack....You must be forgetting to check your frost meter.....must near the life time total....Wheeldog's meter gets reset every winter....being south is easy on the wood pile too.
"Fate will inevitably catch up with those who run away from it." Kai-'Jade Warrior'
Pancreatic cancer stinks
beamertwin is offline   Reply With Quote
Old 12-08-2012, 01:39 AM   #4
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,411
WTF? Frost meter? “No, man, I don’t have grey hair. That’s frostbite”.
I got yer “life time total” right here.
Tom S is offline   Reply With Quote
Old 12-06-2012, 01:26 AM   #5
phoenixdoglover
Where to next?
phoenixdoglover's Avatar
Oddometer: 116
Misery Loves Company
Without miserable conditions, how would we know we are alive?
Perhaps in 5 months I will post a similar rant...only mine will feature temperatures in the 50 deg C range.
Today, partly cloudy, a little breeze, high of 30 deg C. Tomorrow the same.
My Guzzi waits.
2009 KLR650
2009 Suzuki C50T
2011 Moto Guzzi Stelvio NTX
phoenixdoglover is online now   Reply With Quote
Old 12-06-2012, 03:15 AM   #6
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,411
Ain’t that the truth. They won’t suddenly go bad & leave you stranded like a lot of the electronics will. And if there is a problem with a carb I can usually find the problem & fix it on the spot. Hard to see WTF those little electrons are doing. .
Manual transmissions seem to last forever. I did have to change the clutch on my old snow plowin’ 1971 Bronco last year. Original clutch, had seen 40 years of very hard use. It would still be in there if one of the three pressure plate finger bolts had not broke. http://i4.photobucket.com/albums/y14...ncoclutch4.jpg
The clutch disk was overdue anyway.
I really hate automatic transmissions but you can’t even buy a lot of new cars or trucks with a standard transmission anymore. That just ain’t right.
There are now a lot of people that can’t drive a stick shift car. That don't seem right either.
Even some that I *think* can drive a stick shift are completely baffled when faced with a “Three on the tree”.
BTW, I hear you ran into my friend & a fellow worker of yours from years ago, Don D. We graduated high school together but didn’t hang out back then & he only lived a block away from me. He didn’t hang out with the little bit wilder ...emm, ... cool guys back then I guess.
Old 12-06-2012, 08:45 AM   #7
TxLoneRider
TxLoneRider's Avatar
Oddometer: 343
Well, luckily I avoid most of the cold crap down here in the South. But I've somewhat been there, used to live in Ottawa and would frequent parts north there of. Say sub -40 more than once or twice.
Kind of hard to explain how everything makes different sounds. Even unlocking you car.
But there is something to be said about having to hold your breath for a few minutes while you start your car. 'cause if you exhale it will turn to ice as soon as it hits the windshield. But even the clutch on my old escort was fun. It would take about 10-20 minutes before the hydrolic fluid would start to thin out, when you side stepped the clutch, you could just watch the peddle rise.
Anyway, I agree on the whole transmission thing, the only reason why my Suburban is an automagic, is that you can't get it as a manual. Luckily my wife likes all 3 peddles to be there, so her little GTI has all 3
Stay warm and safe up there.
TxLoneRider is offline   Reply With Quote
Old 12-08-2012, 09:06 PM   #8
beamertwin
Paul
beamertwin's Avatar
Oddometer: 1,068
Does this include DR 650's???
Old 12-10-2012, 06:36 PM   #9
Solarmoose
electric
Solarmoose's Avatar
Oddometer: 708
time to play
nothing wrong with you other than too much cabin time,
temps broke this weekend to the positive
new snow on the ground everywhere
time to get out and play!
Solarmoose is offline   Reply With Quote
Old 12-12-2012, 07:10 PM   #10
HayDuchessLives
Loquita
HayDuchessLives's Avatar
Oddometer: 1,155
Originally Posted by Solarmoose View Post
nothing wrong with you other than too much cabin time; temps broke this weekend to the positive; new snow on the ground everywhere; time to get out and play!
AlcanRider will feel much better once he gets out traipsing through the woods on his snowshoes. Plus, I tried a new fudge recipe (blueberry cheesecake) that's guaranteed to bring a smile to the gregarious geezer's face, even if it is cold outside and he has problems with his vehicle!
Solarmoose is right - it's time to go play in the snow - which means skiing in the backcountry for me.
"In every walk with nature one receives far more than he seeks," John Muir.
2007 Suzuki DR650 (Loquita) & 2009 Suzuki DR650 (Soquili)
Fun Denali Hwy RR: http://www.advrider.com/forums/showthread.php?t=622201; Awesome Nome RR:
http://www.advrider.com/forums/showthread.php?t=808795
HayDuchessLives is offline   Reply With Quote
Old 12-16-2012, 08:57 PM   #11
Alcan Rider OP
Frozen Fossil
Oddometer: 3,924
time to get out and play shovel!
Yeah, 10" of the $#% stuff in one shot. I was perfectly happy NOT having to shovel or blow snow off the driveway and paths, and NOT having to put on snowshoes to take a walk in the woods.
It's back down to 35 below (or colder) tonight.
Maybe I am just getting old and crotchety.
Haul Road Primer
Old 12-06-2012, 11:03 AM   #12
HayDuchessLives
Loquita
Oddometer: 1,155
"What's Wrong With Me????"
Since my esteemed mentor, who is sometimes Handsome, Intelligent and Charming, still has some potentially embarrassing photos with me in them, I will demonstrate outstanding public relations skills and give a diplomatic answer.
Nothing is wrong with the Gregarious Geezer from Glennallen, at least nothing that can't be fixed with a big hammer or his amazing mechanical aptitude.
As for Tom S, I'm not sure what's wrong with him as it's difficult to quantify. However, I sure admire his creative talents, even when he pokes fun at me.
Old 12-06-2012, 11:41 AM   #13
Fast Idle
Since the Sixties
Fast Idle's Avatar
Oddometer: 309
Totally agree. Best to always have a least one vehicle without electronics. So not only the carb and MT but also a breaker point ignition system!
Now if we could just figure out what to do about those danged square tires...
2002 R1150 GS
74 R90/6- Restored
69 Triumph Daytona 500- Survivor
1970 Honda SL100
- Survivor
Riding as much as my old frame will allow!
Fast Idle screwed with this post 12-06-2012 at 11:49 AM
Fast Idle is offline   Reply With Quote
Old 12-06-2012, 01:46 PM   #14
akrider
mild adventurer
Oddometer: 1,743
Ah winter
Jack it sounds like the beginning of Cabin Fever is comming early this year.
I once sold my Porsche to a guy that paid cash and then called a friend to drive it home for him......He had never driven a stick shift.
Oh and by the way Jack......post those pictures of the Dutches. That may warm up the winter.
To someone with only a hammer - all problems appear to be nails.
Ignoranus-def: someone who is stupid and an asshole.
akrider is offline   Reply With Quote
Old 12-06-2012, 01:50 PM   #15
TxLoneRider
Oddometer: 343
Originally Posted by akrider View Post
I once sold my Porsche to a guy that paid cash and then called a friend to drive it home for him......He had never driven a stick shift..
Flashback! And I have to ask, what is wrong with that. I did that twice!
My first new car was an '86 escort. When the sales critter picked me up I scared him shartless, it was the second time I had ever driven a manual.
And when I got my first bike, EX500, I have the sales critter ride it to where I was living, because the dealership was on a busy street, no place to learn how to ride. Okay, I had sorta ridden a dirt bike prior, but .....
And hey, both turned out just fine .....
Times are GMT -7.   It's 04:46 AM.
