12-19-2012, 07:55 PM
#1 |
Oddometer: 271
Heated Jacket? 65 or 90 Watt?
I recently got a Firstgear heated jacket. I've been putting this off thinking I could get by with more layers. I gave in but I've been second guessing my decision after doing some post purchase research.
I got the 90 watt jacket, thinking it would pull less current if I turned it down. I'm sure it would be fine on the V-Strom at just about anything over idle. It would probably be too much for the DRZ or TU. Should I have gotten the 65 watt version. It is still new, and I can exchange it straight out from my local dealer. I also got the single zone controller. Everything I've read since I bought it says the dual zone is much better. I don't have any heated gloves or pants, and haven't planned on adding any. But, heated gear may be the best investment I never knew I needed. This too is still in the package, and can be exchanged for the dual zone for the difference in price ($30, I think). It's starting to look a lot like winter here, and should do the exchange soon so I can get some use out of the new gear. Thanks, Ryan
07 DL650, blue 07 DRZ400, also blue 11 TU250X, not blue former rides: 98 KLR650, 01 SV650 (another blue bike),89 KLR650, 92 Bandit 400 ( For Sale) |
12-20-2012, 03:47 AM
#2 |
Forever N00b
Oddometer: 1,602
A PWM controller can make a 90W jacket act like a 65W jacket No controller can do the opposite.
I have a 90W jacket and like it.
Motorcycles are magical. |
12-20-2012, 04:36 AM
#3 |
WFO for 41 years
Oddometer: 3,995
I have the 90w, BUT I cheaped out, have a single controller, no problem, except when the pants are worn, the top is significantly warmer than the pants. Looking back, I could have gotten the 65w and been better off. JFWIW
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
12-20-2012, 04:43 AM
#4 |
Lost in Georgia
Oddometer: 558
Install a voltmeter on the bike, and just turn it down if needed.The controller will turn it down to the same as a 65 watt, or less, easily.
12-20-2012, 06:18 AM
#5 |
Oddometer: 169
I have a 90 watt jacket and a dual controller, I'd suggest the same setup.
There are so many choices that influence how the gear works, does the bike have a fairing/hand fairings etc. On my xr400 I use a heated vest with no controller, it is somewhere around 55 watts and works great compared to no heat. My 90 watt jacket under a snug fitting winter leather jacket is usually run on high, put the same setup under a pressure suit with a good windshell and high will cook you like a turkey, point I'm going for is every bike and setup is just enough different that you want choice/flexibility I think you'll be real happy with the setup you bought, if you later add gloves my experience says a dual controller is better. |
12-20-2012, 11:22 AM
#6 |
Registered Lurker
Oddometer: 661
I have the 65w, & yet to need it turned all the way up. I'm wearing it under textile w/liner. The coldest I've been in so far is 30* F. YMMV
For those that fight for it, freedom has a flavor the protected will never know. |
12-20-2012, 01:15 PM
#7 |
Oddometer: 147
I have the W&S 90W liner with gloves and the duel controller. When it is in the teens I will turn the liner up to maybe half way, and the gloves almost all the way up. I would probably be OK with the 65W jacket liner but I'm keeping the 90W unit. A neck sock/gator go a long way in keeping drafts from going down your neck - thus you warmer. Just my experience.
12-20-2012, 03:51 PM
#8 |
Motorcyclist
Oddometer: 571
You should ask heat-troller_mike.
I thought the way the controller works is that when it's set at, for example, 50%, it would cycle the gear on and off several times a second, so that the total On time is 50% of the time. If so, then that means that when it is On, it's drawing the full load of power (i.e. 90W) - but only very briefly. That seems like it means the bike would need to be able to handle a 90W load, whether you ever run the jacket at 100% or not. That said, I personally am all about future-proofing. So I got the WnS jacket liner and the dual remote controller. Then I ended up adding the WnS heated socks and I am glad I got the dual controller! I turn on the socks before I ever turn on the jacket and generally run them at a higher setting when they are both on. ps. In case you didn't know, Warm n Safe makes the heated gear that First Gear sells. It's identical, just with the FG label on it.
- Stu '09 R12GS, '05 GSX-R1000 (x3), '05 KTM 525EXC (plated) Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member Racer, Drummer, Bassist, Software Engineer |
12-20-2012, 09:10 PM
#9 | |
Oddometer: 271
After doing my initial research, I went with the Firstgear for two reasons. The first was the many positive reveiws of it and the W&S, and second I have a well stocked semi local dealer. It does seem well built. I think I may just stick with what I got. If I need the 2 zone later, I guess I can sell the single. Until then, I'm not out the extra few dollars or the trip back to the store to exchange it. I think I may hook it up to my power supply with a watt meter hooked up in line and see exactly what it is pulling at different power levels. I thought of doing this earlier, but didn't want to take it out of the package if I was going to need to exchange any of it. I may have a bit of time this weekend, if I'm lucky. Also, does anyone know how many "spare" watts a DRZ puts out. Thanks, Ryan
12-21-2012, 02:20 AM
#10 | |
Oddometer: 159
I run a 75 watt jacket and 17 watt gloves with no problem now, my newly installed voltage indicator never drops below 12.5 volts. And to be on the safe side I shut everything down 5 minutes before I get to my destination. When you check your current draw test it when riding if you can, I know my setup draws very little juice when standing still when I'm on the bike and the wind and cold are blowing through my jacket that's when you see the real draw, If you're really worried. get the kick start option for the DRZ, around $200, something I have been thinking about. Ron W.
DRZ 400SM DL-650 Gone but not forgotten |
12-21-2012, 03:45 AM
#11 | |
Forever N00b
Oddometer: 1,602
A PWM controller with high frequency makes the changes mostly invisible to your battery and charging system. I use a 90W jacket at full power on bikes with 210W and 280W alternators. On a bike with a 170W alternator I can draw the battery voltage down low enough that the alternator takes a while to charge it back up.
Motorcycles are magical. Grinnin screwed with this post 12-21-2012 at 04:10 AM |
12-20-2012, 07:46 PM
#12 |
Oddometer: 1,851
reguardless on what jacket you get, the power used to put you your "comfy zone" will be the same
12-21-2012, 02:34 AM
#13 |
Stoogely Adventurerer
Oddometer: 794
I have been looking at the cheaper end heated vests. I don't usually go on long fast rides, I do stuff like ride dirt roads to a singletrack area, ride, camp, then ride home. My time at high speed on pavement is not much but my time at 35-40 mph on dirt roads followed by some tight singletrack is alot. I just hate to invest in an expensive setup when I know I'll likely tear it mess it up somehow.
I have been looking at some cheapie heated vests from Sportsman's Guide and Cheaper than Dirt for around 50 bucks, but they all seem to only heat the back area which would be ok for me. I'll have layers and a heavy riding jacket over the vest to keep the heat in. Often I overheat rather than get too cold whenever I hit the slow trails. Anyone try any of the inexpensive vests? Any to stay away from?
jgas Question of the century: "When the little Singletrack remaining is gone, and we can't ride on the existing Two-track, will you be nhappy riding only on a few dirt roads and pavement? If not, what are you going to do about it"? Certified JB Welder. Certified 3M Duct Tape installer. Certified Farmer's Co-Op bailing wire expert. Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair. 02 KTM 520 exc DRZ 400 95 XR 250 2001 KLR 650 |
12-21-2012, 01:46 PM
#14 | |
Motorcyclist
Oddometer: 571
It seems that many riders approach cold weather riding by layering up and then, when that's still not enough, they add the heated gear. I think that approach is backwards. I put on my summer riding gear. If it's too cold for that, then the next thing I add is my heated liner(s). If it's still too cold, with the heated gear at max, THEN I think about adding long johns and/or fleece or whatever. I hate feeling like a stuffed sausage casing when I'm riding.
12-24-2012, 02:28 PM
#15 | |
Oddometer: 426
-dman |
