Old 12-23-2012, 11:36 AM   #1
prichmon OP
Oddometer: 121
KLX250SF Carb starting and cold run issues
I have done significant research but can't get the bike to start and run right cold.
From a cold sit:
pull choke
turn on gas
hit starter for 5-6 seconds - no running
wait 30-60 sec
hit the starter for 3-5 sec - may run or may not
wait 30-60 sec
hit the starter for <3 sec - usually runs
Idles for 1-2 minutes as it heats up then dies
crack throttle and crank -- bike restarts but must hold throttle open with choke off to make it run
After 3-5 minutes it will maintain a low idle without throttle.
Once warmed bike runs GREAT.
I have owned a dozen+ motorcycles and have NEVER had this much trouble making them run right. Cold or HOT!
I have rejetted to a 124 dynojet main, KLX300 adjustable needle on the 3rd position, changed the idle to a 38 with 1.5 turns out. Lastly I drilled the choke orifice to ~19-21 thousands. No Toil Air filter, air box top off or on has had little to no effect on running. Exhaust has been drilled with a 1/2" through the baffle and end is drilled with 6 1/4" holes in the end cap.
The only thing I can come up with is a lack of "1/2 choke" which allows mild enrichment. The sf has a carb which the choke is on or off only.
If anyone can lend a hand I would appreciate it.
Rich
prichmon is offline   Reply With Quote
Old 01-09-2013, 12:32 PM   #2
RockabillySlapMatt
Noobie McNoobington
RockabillySlapMatt's Avatar
Oddometer: 195
What temperatures are you starting in? I did the 124 main and dynojet kit, but left the stock pilot in with 3 turns out. At 30 degrees F it takes a choke still(I keep it garaged).
RockabillySlapMatt is offline   Reply With Quote
Old 01-09-2013, 01:00 PM   #3
Pauls2ndblessing
Oddometer: 99
Drain the float, turn gas on, wait 10 sec, choke, then start.
Next time, turn your gas off a block away from getting home, let most of the gas or all of it run out before turning it off. That should clear the issues, does for most.
Pauls2ndblessing is offline   Reply With Quote
Old 01-09-2013, 06:40 PM   #4
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,622
Drilling out the starter jet to .018" will aid cold starting in almost all cases. The stock starter jet is too small for cold weather for many owners. The jet is pressed in so you can't replace it. You drill it.
TNC is offline   Reply With Quote
Old 01-09-2013, 07:42 PM   #5
maxjett
Biketrader
maxjett's Avatar
Oddometer: 585
I did this primer and works great, found one in Ebay.
http://www.kawasakiforums.com/forum/...esolved-18885/
maxjett is offline   Reply With Quote
Old 01-11-2013, 04:26 PM   #6
prichmon OP
Oddometer: 121
klx
Temps are no lower than 40*F or so. I have already drilled out the starter.
Short of draining the bowl I have covered all of the recommended suggestions. I shut the fuel off ~1/4 mile from my stop if it will sit for a long while.
Rich
Old 01-11-2013, 04:39 PM   #7
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,542
Have you checked your valves recently? Many KLX owners leave the pilot jet stock when rejetting, the 38 pilot may be too big? How did you arrive at the 1.5 turns on the idle mixture screw? You really need to adjust that with the bike running and warmed up. Screw it in until the engine starts to stumble and then back out 1/4 to 1/2 turn. Blip the throttle and watch/listen for the engine speed to drop right back down to idle. If it hangs at a higher RPM, turn the screw out a bit and retest. If the engine speed drops down below normal idle speed, turn the screw in a bit.
cjbiker is online now   Reply With Quote
Times are GMT -7.   It's 09:28 AM.
