Old 01-06-2013, 10:10 AM   #1
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
bonding plastic and fiberglass
I am building a project bike and one thing I want to be able to do is extend the seatpan to allow a more comfortable seating position. The seatpan is on the Ninja below and my hand is approx how far I want to extend it. I don't have any idea what type of plastic it is, but its fairly flexible and smooth. I've used adhesive like 3M 5200 before and that stuff seemingly would stick to anything and was a nightmare to get off, nightmare.
Here's about how far I want it to go
Underside
I am planning on making the extension from fiberglass and epoxy but I don't expect the epoxy to stick to the plastic. I was hoping to either mechanically fasten it with rivets maybe or some badass adhesive that will hold the part to the original seat pan yet remain flexible enough to allow some slight movement as you would encounter on a seat.
The extension and original seatpan will be properly supported all the way to the subframe so this is just to hold parts together. Suggestions? Esp from McMaster since I seem to order from there a couple times a week.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 01-06-2013, 10:19 AM   #2
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,494
Might be a good application for carbon fiber. Strong as shit and the goo might bond better to plastics, but I am not sure. There are a couple excellent CF threads going on ADV, some of those guys are real rock stars with that stuff, they would know.
Great post, just the same.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 01-06-2013, 11:31 AM   #3
the_gr8t_waldo
Oddometer: 2,114
if possible, i'd go with 3M9485 in the 5mm thickness adhesive( about 25$ for a 60yard roll X1/2"wide).. this is a tape composed of just adhesive on a coated peil off paper strip. the bonding surfaces must be clean before using this 3m product. and the more overlap the better. this 3m product should be applyed to the entire mating surface(only one side need be covred). and once set and allowed to bond it's permanet! i'd sweeten this with two pop rivits, to insure that the parts are alined,before the two parts are allowed to make contact, and that some pressure is applyed for the bonding to take place. full bonding takes place a in about 24hours of close contact... not a cheap project, but anyone who uses this stuff comes away impressed with the ease of handling and a first class repair.
the_gr8t_waldo screwed with this post 01-06-2013 at 11:52 AM
the_gr8t_waldo is offline   Reply With Quote
Old 01-06-2013, 11:34 AM   #4
therivermonster
therivermonster's Avatar
Oddometer: 327
Underside
Hey Sailah! You have an interesting project going on there.
I have a little bit of composite experience, and it is my experience that a good epoxy resin will stick very well to just about everything; even plastic if it is prepared correctly.
How do you plan on laying up the extension of the seat pan?
Are you going to make a mold of sorts?
Have you ever worked with fiber glass before?
Your pics are great, and your post has been very informative so far, but if you could include a few more details on how you plan to create the composite part, that would be of great help to those of us who might have some answers.
I'll keep an eye out for your next post.
“Behold, I am sending you out as sheep in the midst of wolves, so be wise as serpents and innocent as doves."
My Virgin ADV Trip
, Rocks Flyin', Me Cryin', and God Looking On - A WABDR Adventure, Fun With Carbon Fiber
therivermonster is offline   Reply With Quote
Old 01-06-2013, 01:10 PM   #5
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,279
It has been my experience as well, that epoxy resin will bond to sanded and cleaned plastic.
polyester resin will likely not work.
the 3m 5200 is great stuff, but i think you would have to prep the seat in the same manner as epoxy resin to adhere, and the 3m5200 takes, what 10 days to cure in warm climates?
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 01-06-2013, 01:28 PM   #6
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
Thanks guys. I have a reasonable about of composite experience used to work for a large custom yacht builder that did SCRIMP infused hulls plus I have built a number of small craft using epoxy. I have a gallon of west epoxy, carbon cloth, kevlar, mat and some light weave cloth. I don't plan to make a mold this will never be seen, just layup right over the part.
I'm no expert though. My experience with epoxy is that it will crack if flexed. Maybe that high strength tape would be a good choice after I layup the part.
I'll probably keep the build thread updated if folks want to help with suggestions
Nessmuk
Old 01-06-2013, 01:32 PM   #7
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,979
Plastic welding? Find a body shop that does it, perhaps.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 01-06-2013, 01:58 PM   #8
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
I have a good friend that owns a plastic welding company, I'm sure he could help but I was hoping this could be done much more simply, and he's 2 hours round trip.
Nessmuk
Old 01-06-2013, 03:02 PM   #9
the_gr8t_waldo
Oddometer: 2,114
5200 will be more forgiving because of"not perfect" surface matches. and can always be picked up at the local marine box store.- just something to consider
Times are GMT -7.   It's 05:05 AM.
