Old 01-09-2013, 02:57 PM   #1
indr OP
Oddometer: 1,197
Cleaning Engine Sludge
1. The engine is off the bike. The crankcase is split with the transmission / drive shaft / shift drum / everything taken out of it.
2. A couple of days ago, I soaked the crankcase halves in some Murhphy's Oil Soap.
3. Now, there is slick sludge in various places on the CC halves. Inside and out. In corners and on surfaces. I'm thinking it's something like molybdenum mixed with the oil and soap. It's white/greyish.
4. It's very light in viscosity. But, there's a lot of it and it's in nook and crannies where I can' reach with a toothbrush or towel. Using a pick would take a long time.
What's the best and fastest way to dissolve this slime from the crankcases? Something that'll clean out the oil passages because I have a feeling there's a lot of the stuff in there. Are mineral spirits going to strip the engine paint?
indr is offline   Reply With Quote
Old 01-09-2013, 04:30 PM   #2
sparkymcgee
sparkymcgee's Avatar
Oddometer: 335
I've heard Pine Sol is the go to cleaner for engine parts. Haven't tried it, but I've seen pics and things come out gleaming.
2008 VFR800
2012 Super Ténéré
sparkymcgee is offline   Reply With Quote
Old 01-09-2013, 05:23 PM   #3
Beezer
Oddometer: 5,658
kerosene, diesel, mineral spirits, gasoline.... something petro
Beezer is offline   Reply With Quote
Old 01-09-2013, 06:37 PM   #4
RTCHIEF
Oddometer: 313
engine
Have it hot tanked.
RTCHIEF is offline   Reply With Quote
Old 01-09-2013, 08:51 PM   #5
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,236
Originally Posted by RTCHIEF View Post
Have it hot tanked.
No - that will effectively dissolve aluminum.
Try the PineSol first.
HapHazard is offline   Reply With Quote
Old 01-09-2013, 09:19 PM   #6
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,546
Murphy oil soap, that's to clean wooden floors, not much degreasing power.
I king of object to some of the above suggestions, Caustic Lye products such as hot tanks or oven cleaners, really bad for aluminium. But I can be patient and don't have a problem picking at stuff for a long time.
Go buy some Castrol engine cleaner/degreaser at CT.
Have tools, will travel!
Old 01-10-2013, 12:44 AM   #7
Beezer
Oddometer: 5,658
if petro products don't work try paint stripper... it has methyl chloride which one of the really good cleaners we used to have in the old days, but bear in mind there are reasons it isn't used for that anymore... like it's pretty evil on your body. I brush it on and cover it with plastic sheet to keep it from evaporating
if you buy "gasket remover" in a spray can thats all it is... paint stripper
Easyoff is ok on stainless steel but be careful on aluminum... it can eat alloy
Old 01-10-2013, 05:40 PM   #8
RTCHIEF
Oddometer: 313
How do engine rebuilders clean oil from aluminum?
Old 01-10-2013, 09:22 PM   #9
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,236
Machine shops/rebuilders do hot tank iron blocks and heads in a mixture of water and caustic soda. Caustic soda is lye and it quickly eats aluminum. They have solvent tanks for aluminum. A million years ago you could buy a similar solvent product called Hydro Seal. It would clean baked on grease and take carbon off pistons and aluminum heads with an overnight soak. I used it on a Corvair rebuild (nothing but aluminum!) Hydo Seal is gone now (another toxicity victim), and replaced with Hydro Seal II, which the Internets seem to say is a disappointment, although I haven't tried it myself.
Old 01-10-2013, 10:04 PM   #10
ragtoplvr
Oddometer: 6,061
They make special bake ovens. They also make some really heavy duty dishwashers. And some high wattage ultrasonics are very popular.
There is no single solution.
Link
http://www.enginebuildermag.com/Item...spx?MostRead=1
Rod
ragtoplvr is online now   Reply With Quote
Old 01-12-2013, 09:37 AM   #11
RSRennsport
Navigator
RSRennsport's Avatar
Oddometer: 64
Mineral Spirit and a washer.
Strassen?
AHRMA # 59
RSRennsport is offline   Reply With Quote
Old 01-12-2013, 02:57 PM   #12
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,898
I used Pine Sol on some carbs I was rebuilding. Did an outstanding job. Definitely my cleaner for smaller parts.
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 01-09-2013, 08:33 PM   #13
CaptTeach
Oddometer: 209
Easy Off oven cleaner in the yellow can - Place in the sun to warm up the part then spray Wait twenty minutes or so and either re-coat or rinse with water
CaptTeach
96 Heritage Softail Classic
89 XT 600
71 CB 200 Cafe Racer
70 CL 100
63 Sporty XLCH
CaptTeach is offline   Reply With Quote
Old 01-10-2013, 05:19 AM   #14
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Spray wand at the car-wash, hot soapy water. Have WD-40 WITH YOU to stop the IMMEDIATE rusting on the steel bits.
Old 01-10-2013, 09:13 AM   #15
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 11,475
^ right here!
Murphy's oil soap? THAT is a truely novel application for this product . . . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Times are GMT -7.   It's 02:38 PM.
