Old 01-11-2013, 10:22 AM   #1
indr OP
Oddometer: 501
Dowel Pin Stuck
indr screwed with this post 02-22-2015 at 09:44 PM
indr is offline   Reply With Quote
Old 01-11-2013, 10:49 AM   #2
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,796
If the pin is tight enough to not spin, try running a tap in there to grab it.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 01-11-2013, 10:56 AM   #3
twinjet
Oddometer: 306
Originally Posted by indr View Post
The picture is of the bottom of the upper half of the crankcase.
(bottom half of the picture)
The dowel hooks onto the bearing on the driveshaft to prevent spinnage of the outer race of the bearing.
The dowel is supposed to be sticking out but it is some how lodged and flush with the case with no where to grab onto.
How to take out?
If the dowel is hollow all its length, find a solid dowel that will just slip into the stuck hollow dowel, fill the cavity with oil then tap the solid dowel into the hollow dowel. Hydraulic pressure will force the hollow dowel out. (wear safety goggles).
If the stuck dowel is solid, drill a smaller diameter hole from the other side and use a suitably sized drift pin to drive the dowel out from above.
twinjet is offline   Reply With Quote
Old 01-11-2013, 12:01 PM   #4
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 470
Snap and Mac make inside/outside pliers. A little heat and a pair of those pliers might just do the trick.
WRW9751 is offline   Reply With Quote
Old 01-11-2013, 12:08 PM   #5
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 18,173
drive a self tapping screw into it, and then use a slide hammer to pull the screw out, hopefully with the dowel pin on it.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 01-11-2013, 12:48 PM   #6
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
dowel pins ARE made of stern stuff . . . . . . .drilling will be messy . . . . try to get it to turn
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 01-11-2013, 01:00 PM   #7
Beezer
Oddometer: 5,940
the only other thing I could add to the list is welding... put a piece of rod, screw, etc down one side and tack it with a wire feed. the heat will help too
another desperate possibility is to take a tiny cutoff wheel on a Dremel & cut down one side enough to cave it in & get a bite. it prolly means putting a groove in part of the saddle, but I'm sure there is enough metal so it won't matter
Beezer is offline   Reply With Quote
Old 01-11-2013, 01:08 PM   #8
twinjet
Oddometer: 306
An expensive but effective way to remove a hardened dowel if other methods won't work is to take the case to a high end tool and die shop that has an EDM machine. The EDM machine uses a carbide electrode in a fluid bath to eat away at the dowel. The expense would have to balanced against the cost of replacing the case.
Old 01-11-2013, 12:53 PM   #9
sieg
sieg's Avatar
Oddometer: 2,932
Easy out to grab and turn the dowel, while heating the aluminum case. The case will expand faster and greater than the steel dowel therefor freeing the dowel.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is online now   Reply With Quote
Old 01-11-2013, 03:54 PM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,432
This. Will work.
Old 01-11-2013, 12:57 PM   #11
mouthfulloflake
Not afraid
Oddometer: 18,173
this might be a good method too
http://forums.nasioc.com/forums/show...93&postcount=2
Old 01-11-2013, 02:47 PM   #12
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 470
If snap ring pliers won't fit in the hole it's probably to small for the other pliers.
A tap or easy our and some heat to the case sounds like the best plan. A screw probably won't bite, to soft. The dowels are very hard.
Old 01-11-2013, 03:56 PM   #13
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,400
Duh
Just turn it upside down and let it fall out...duh
OK. my real vote is to follow CONCOURS' endorsement of Sieg's idea.
SilkMoneyLove is offline   Reply With Quote
Old 01-11-2013, 09:25 PM   #14
Maoule
Maoule's Avatar
Oddometer: 607
That crankcase was prolly wore out anyway...the good news is you prolly don't need to fuck with that dowel any further
Maoule is offline   Reply With Quote
Old 01-11-2013, 07:33 PM   #15
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
Correct me if I am wrong, but doesn't it also bring oil under pressure to the bearings????
Have tools, will travel!
Times are GMT -7.   It's 10:06 AM.
