Old 01-12-2013, 12:51 PM   #1
Dustodust OP
Dustodust's Avatar
Oddometer: 1,075
Best source for Chain and sprockets ?
its time for a new drive
anyone know the best source for a DID VMX2 and sprockets ?
google search gives only one shady result
thanx
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 01-12-2013, 01:12 PM   #2
catalina38
Contrarian
Oddometer: 1,681
I got OEM sprockets through munnracing.com and the DID ZVMX 525 chain from motorcyclesuperstore.com with a coupon code and that made it the lowest $$ I could find. I haven't had a coupon code for quite a while, maybe they stopped offering them? I kept the same 16/42 stock gearing but the 45t rear is actually cheaper then the 42t. I ordered the 120 link chain but should have ordered the 130 so I would have a section of chain after cutting it down to 118 links, for trail side repairs.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 01-12-2013, 02:52 PM   #3
TcRulz
Oddometer: 289
Hi, do yourself a favor and only use OEM front sprockets. I learnt the hard way as an aftermarket sprocket ate my splines. Nut was torqued up right so can only assume sprocket was too hard. Now have sprocket welded on
TcRulz is offline   Reply With Quote
Old 01-12-2013, 03:42 PM   #4
David37
David37's Avatar
Oddometer: 409
Check out Ironman sprockets they make a great product and actually guarantee their sprockets will not wear out for one year.
David37 is offline   Reply With Quote
Old 01-12-2013, 07:02 PM   #5
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,540
Originally Posted by tcrulz View Post
hi, do yourself a favor and only use oem front sprockets.
+ 1000
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 01-12-2013, 04:33 PM   #6
corndog67
Oddometer: 1,281
I use Stealth/Sidewinder/Krause Racing rears exclusively, the aluminum over steel. They last for years and years, and with the DID ZVM chain (best chain you can buy), I go years without adjusting chains, 5 tires at least on my Ducati without touching the adjusters, 2 years on my YZ450F without adjusting it, and I've got the same setup on my KTM950, been on there about 6 months or so, no adjustments at all, not even after breaking it in. And I always use stock countershaft sprockets. Its worked for me.
The set up has probably the most expensive chain you can buy, about $215, the sprockets are fairly cheap at $80,but to me, it's worth it. No issues, long life.
corndog67 is offline   Reply With Quote
Old 01-12-2013, 05:02 PM   #7
Hipster
Hipster's Avatar
Oddometer: 1,815
DID updated the old 525 VMX2 to 525 ZVM-X, try searching again with the new p/n.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is online now   Reply With Quote
Old 01-12-2013, 11:43 PM   #8
Dustodust OP
Dustodust's Avatar
Oddometer: 1,075
Good stuff
thanks for the wisdom everyone !
stock front sproket only for matching rockwell hardness
possible Ironman rear
chain superceded to zvmx
maybe I should get new rear sprocket nuts and bolts
04 KTM 950 S
Old 01-13-2013, 09:41 AM   #9
MortimerSickle
Semi-Adventurer
Oddometer: 12,540
Originally Posted by Dustodust View Post
Good stuff
thanks for the wisdom everyon...
I have changed rears twice using the original nuts and bolts. I don't know of a reason to change nuts and bolts that do not appear to be damaged, but if someone else does, I am all ears.
G.H.W.S. 1878-1962
Old 01-13-2013, 10:42 AM   #10
Dustodust OP
Dustodust's Avatar
Oddometer: 1,075
the aftermarket industry sure sells a lot of sprocket bolt kits
The 950 doesnt fly much but a loose sprocket bolt can be catastrophic. I have about 4 changes on mine using blue locktite
http://www.mechanicsupport.com/stop_nut.html
Several aircraft accidents (Canadian TSB Report A97O0055) and aircraft control problems (C-130 aileron) caused by lock nuts coming loose have challenged the idea that lock nuts can be reused.
Air Force T.O. 1-1A-8 now states: "New self-locking nuts shall be used each time components are installed in critical areas throughout the aerospace vehicle" This seems a more practical policy given the low cost of a lock-nut.
04 KTM 950 S
Old 01-13-2013, 10:00 AM   #11
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,188
Ironman sprocket will come with them.
Old 01-13-2013, 06:54 AM   #12
catalina38
Contrarian
Oddometer: 1,681
OEM Rear 42t is $68, the 45t is $55 and the bolt/nut are about $4 each at Munn
KTM 990R 500EXC
Old 01-13-2013, 11:16 AM   #13
corndog67
Oddometer: 1,281
My old KTM 500MX would really beat the sp rocket bolts up, they were visibly worn at at each change, and wore out the holes so there was a lot of slop. I reamed the holes to the next bigger size, and made sure every thing fit tight. A rear hub for an oldbKTM dirt bike was about $500, so I didn't want to break the ears off it, that's why some people change them out every time. My 950 uses that strange pin setup, and 2 places told me not to replace the screw that go into the pins if they are not damaged.
If your sprocket rides directly on the screws, some do, some don't, I'd change them, they are cheap insurance.
Old 01-14-2013, 05:35 AM   #14
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,865
Don't need to change my underwear often- I can keep using the same pair whenever I change my pants.
(OK, the comparison breaks down- but it's was a fun thing to say)
I always replace. The nuts are "pinched" to lock down, and once used will not provide the same grip on the bolt. Sure, one can use Loctite which will help, but I'd rather have the combinitation of the two.
I have seen the consequences of nut/bolt failure on a sprocket, and it's worth the several dollars to me when I replace a sprocket just for that extra-special respect for things mechanical.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Times are GMT -7.   It's 03:54 PM.
