Old 01-14-2013, 11:21 AM   #1
flossandfly OP
flossandfly's Avatar
Oddometer: 331
Anybody use shrink wrap to hold spare tube on front fender?
Got this idea based on how secure things are when I have to take the shrink wrap off things. I have read lots of posts about fender bags with a warning to check them often as they can come loose. Has anybody used shrink wrap to help hold it on? Seems like it would work but maybe there are some downsides I haven't thought about.
flossandfly is offline   Reply With Quote
Old 01-14-2013, 11:26 AM   #2
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
Never heard of it being done, but that does not mean it cannot be a workable solution.
With the low expense of attempting it, why not give it a go?
Old 01-14-2013, 12:24 PM   #3
flossandfly OP
Oddometer: 331
It may look kind of "ghetto" but I will try it out in combination with a fender bag in the spring. It will free up lots of space in the tool tube to move the 21" tube somewhere else.
Old 01-15-2013, 03:37 PM   #4
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,408
For maximum irony, please do this on a brand new GS, and film the reactions.
Light shade will provide near ideal lighting.
Thanks.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 01-15-2013, 05:55 PM   #5
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Thanks.
In front of Starbucks.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 01-15-2013, 08:32 PM   #6
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,256
Are you going to carry a roll of shrink wrap so that you can redo the job with the old punctured tube, after you fixed the flat with the spare tube?
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 01-15-2013, 09:42 PM   #7
cobrags
Lost ADVR
cobrags's Avatar
Oddometer: 656
Use old tube as rubberband/bungee!
ChildsPlay Riding
ChildsPlay Racing
Of all the roads you take, Make sure a few of them are dirt.
cobrags is offline   Reply With Quote
Old 01-16-2013, 02:03 PM   #8
JensEskildsen
Oddometer: 1,023
Fenderbags work, you could always bolt it to the front fender for extra support.
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 01-16-2013, 02:17 PM   #9
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,245
Shrink wrap doesn't do well in the sun for very long. UV will break it down.
+1 on bolting it to the fender. Get a cheapie plastic kitchen cutting board and cut it to fit the bottom of your bag. Using bolts and "fender" washers,
fasten it thru the cutting board, bag and fender with some nylock nuts to finish it off. FWIW, I have not yet lost a fender bag that is held on by it's little straps. YMMV.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 01-15-2013, 06:00 PM   #10
viverrid
not dead yet
Oddometer: 30,482
As the underside of the fender isn't flat, won't this create a space for debris to collect, and/or a reduction in clearance between fender and tire? Or am I misunderestimating how you plan to wrap the wrap around the fender.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 01-15-2013, 08:11 PM   #11
outdoornate65
Oddometer: 66
If the shrinkwrap doesn't work, maybe a big hose clamp....that should look "real nice Clark".
outdoornate65 is offline   Reply With Quote
Old 01-17-2013, 08:04 PM   #12
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
fbj913 is offline   Reply With Quote
Old 01-16-2013, 02:13 PM   #13
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,498
The UV rays pisses with the integrity of the rubba.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 01-17-2013, 09:12 PM   #14
flossandfly OP
Oddometer: 331
One guy likes to meet at the starbucks before rides, but don't have a GS.
There is probably a good reason I haven't seen it in hundreds of ride pics here on advrider. There would be a big space for crap to get caught up between the fender and wrap.
The fender bag is probably held down well enough with straps as I plan to carve a notch into the fender to keep the straps from wandering. Maybe just keep the patch kit and spoons in a separate place.... Just in case.
Thanks for the feedback.
Old 01-17-2013, 10:00 PM   #15
epix1718
epix1718's Avatar
Oddometer: 727
Why not just use some sort reuseable ziptie?
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Times are GMT -7.   It's 01:44 AM.
