Old 01-19-2013, 01:35 PM   #1
Cyath OP
Impetulant Ignoramus
Cyath's Avatar
Oddometer: 427
Classic bonehead move...with bad results
I'm a moron, and I need help in undoing my mistake.
Let me bring you up to speed.
2010 990 Adventure with 16K trouble-free miles. Then last night, leaving from work, it wouldn't start. Cranks but wouldn't catch ignition. Ran the battery down trying to fire it up. Trailered it home.
Just got my CJ Designs fuel pump rebuild kit 2 days ago, so while the battery was being re-charged overnight, rebuilt and changed out all the fuel filters, which by the looks of it, it needed.
Here's where I fucked up. Anxious to see if it would fire up, I just slid the batt in with the poles reversed and of course when I tried to fire it up, the whole console was dead. No lights, nothing. Less than 30 seconds before I realized my mistake, but it was too late. I'm sure I fried something, but I can't find it.
Reinstalled the battery correctly, nothing. No lights, console dead. All the fuses in the storage box are intact.
The 30A, 40A and 25A fuses the down on the right hand side of the bike are all intact.
Are there any other fuses I'm missing?
Called my local dealer and they said to check the Starter Solenoid. I'm still searching through the forum and microfiche to find out where the hell it is.
Any other ideas?
"You think I can remember what you posted a year ago? I can't remember what kind of beer I drank for breakfast." -SScratch
'10 KTM 990 Adventure aka The Spork
Cyath is offline   Reply With Quote
Old 01-19-2013, 02:00 PM   #2
Cyath OP
Cyath's Avatar
Oddometer: 427
Okay, found this http://www.advrider.com/forums/showp...60&postcount=7 post which was very helpful. Turns out that there are two 30A fuses under the starter relay cover, one of which is nicely hidden on the back side of the cluster and I just barely saw the hint of green as I wedged my head in there. You cant reach it with your fingers, need a needle-nose plier to get it. Sure enough, that fuse was blown. Of course there's plenty of other spare fuses on the bike, but no 30's.
Old 01-19-2013, 04:12 PM   #3
Cyath OP
Cyath's Avatar
Oddometer: 427
Bummer update.
New 30A fuse. Bike cranks again, but doesn't fire up.
Fuel pump installed with CJ filters and O-ring kit.
Gonna pull the plugs to make sure they're getting juice.
Any ideas?
I'd appreciate any help.
Old 01-19-2013, 04:35 PM   #4
Cyath OP
Cyath's Avatar
Oddometer: 427
Nope. The plugs don't spark.
Now to chase that down. Back to the HOW.
Old 01-19-2013, 04:45 PM   #5
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 959
Send a message via Skype™ to ciedema
I wonder if the problem actually existed before the blowing of the fuses etc, ie when you cranked it flat in the first place.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
No Four Wheel Drives, No Fixers and No Fricken Whingers
Personal Attacks - the last refuge of the intellectually impaired.
ciedema is offline   Reply With Quote
Old 01-19-2013, 04:51 PM   #6
Cyath OP
Cyath's Avatar
Oddometer: 427
Yes, I think you're right. Never a problem starting before (other than with the known Shorai cold weather starting issues), but it now has a fully charged Yuasa.
The lost spark issue is probably what left me stranded and I went for the fuel pump since that seemed to be the most common issue in similar threads.
Old 01-19-2013, 04:59 PM   #7
catalina38
Contrarian
Oddometer: 1,422
Is it flashing an FI code? All wires plugged back together behind tank? Fuel line reconnected properly? Those seem to the most common and most likely.
Born 10,000 years too late
Scientific Wild Ass Guesser:hmmmm
catalina38 is offline   Reply With Quote
Old 01-19-2013, 05:15 PM   #8
Cyath OP
Cyath's Avatar
Oddometer: 427
All good ideas catalina83.
No FI code, and everything is back and plugged in again, rechecked.
At least an FI code would give me a starting point.
Old 02-14-2013, 11:33 AM   #9
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 9,685
I hate to admit this, but I once hooked up the low fuel connection to the fuel pump and vice versa. I know- it's color coded so a monkey can figure it out.
Shit! Now that I got to the end, I want to delete this post.
But I won't. It may help somebody as dumb as me someday.
Egotism anaesthetises the egotist's stupidity.
unaweep screwed with this post 02-14-2013 at 11:40 AM
unaweep is offline   Reply With Quote
Old 02-14-2013, 04:02 PM   #10
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,209
I shall not cast the first stone.
But I won't admit anything, either ; )
2011 White 990 Adv R
2003 565exc
FakeName is offline   Reply With Quote
Old 01-19-2013, 05:27 PM   #11
DuctTape
Oddometer: 239
Kickstand switch?
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 01-19-2013, 06:08 PM   #12
Cyath OP
Cyath's Avatar
Oddometer: 427
Wouldn't the kickstand switch prevent the bike from cranking at all?
The starter cranks the engine, but I've confirmed that the plugs aren't getting a spark.
Old 01-19-2013, 06:20 PM   #13
Gerg
Cupcake
Gerg's Avatar
Oddometer: 7,904
Bonehead
Hiya Mike
No frickin idea what you need to do (cept maybe time for a beer).
Gerg
Greg
OFFICIAL WARPED BEER MEISTER
BOOF 160, AMA, RA, MOA, HOG
Live life like you stole it!
Your $5 off SMUGMUG Coupon is
hESgLtqESqM1Q
Gerg is offline   Reply With Quote
Old 01-19-2013, 06:42 PM   #14
Wantajustride
Wantajustride's Avatar
Oddometer: 88
Cyath
I aint no mechanic,,
Could it be the electronic ignition coil (stick coil for the 990?) to the spark plug? Maybe the connector to the stick coil has come loose? You have no spark to either cylinder? I suppose there would be 2 of them since it's a twin. Odds that both went bad at the same time would be very remote I'd think.
I have no idea how you'd check them to see if they were damaged on the reversed battery polarity
I'm not sure about the 990, but when I was pulling the spark plug on my 690 I removed the 2 wires from the ignition coil to make it easier to get the plug wire off. I could see how those wires/spade connectors could work their way loose. I know if my 690 won't start some day that would be one of the first things I'd check.
Hope you get it sorted.
WJR
2012 KTM 690 R
2012 Yamaha Super Tenere
2012 KTM 990R Adventure
"Walking thru life to an unknown destination and trying to enjoy the adventure getting there"
Wantajustride is offline   Reply With Quote
Old 01-19-2013, 06:57 PM   #15
Dogtown
Dogtown's Avatar
Oddometer: 397
no start?
You can hear the fuel pump pre-start noise? I know you said no spark but just curiouse...
I think it will crank with the kickstand switch....Kick stand switch cuts the spark not the power to the starter..
I did this for about an hour once.....I found that I had my on / off toggle off.... duhh!
OH 7 990
Marin County To Cabo!
Dogtown is offline   Reply With Quote
Times are GMT -7.   It's 10:04 PM.
