Old 01-28-2013, 06:33 AM   #1
bigtrailie OP
Rough idle
bigtrailie's Avatar
Oddometer: 702
Baja Designs -- Dual Sport kit NiCad battery, Recharge? Replace?
My XR650R came with a B-D dual sport kit (high /low beams, turn signal lights and a small horn). I believe that the turn signals are driven by the pack of NiCad batteries. My signals refuse to light up or flash. Is there a way to tell if the battery pack is shot? Or is there an easy way to re-charge?
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 01-28-2013, 09:43 AM   #2
Baja Designs
Baja Designs
Baja Designs's Avatar
Oddometer: 678
Does your headlight remain on for a few seconds when the engine is off? The turn signals don't run straight off the battery.
Also our tech support department is more then happy to walk you through a few tests to finding out what the issue is.
Might be the flasher. I would recommend checking the battery with a volt meter.
Mike
Baja Designs is offline   Reply With Quote
Old 01-28-2013, 08:28 PM   #3
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,567
You can buy a little charger for the battery pack. I bought one for mine about $10. If you can start the bike the pack should charge after a good ride. I don't remember getting any lights when the battery was low. My XR650R battery pack sat for 3 years no use charged up good and is being used and working for new owner.
http://www.bajadesigns.com/ProductDe...mNumber=120001
Emgo 6/12v battery charger
Just realized BAJA Designs answered you . They should know.
scooteraug02 is offline   Reply With Quote
Old 01-30-2013, 01:28 PM   #4
vfxdog
Oddometer: 624
I have a Baja dualsport kit on an XR650R. The Nicads go flat pretty quickly if the bike isn't being used, but the bike will start fine anyway and you'll have functioning lights etc while the motor is running.
I've hooked up an SAE Battery Tender lead, and give the Nicads a tickle every now and then with a very low rate charger.
So far so good after 3 years.
vfxdog is offline   Reply With Quote
Old 06-14-2013, 05:31 PM   #5
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,221
I've found that with a used up battery pack you'll get dim headlights and the turn signals and horn won't work below about 3000 rpm. Above 3000 everything will work fine. Below 3000 and you get dim headlights (and tail light) only. YMMV
Carlo Muro is offline   Reply With Quote
Times are GMT -7.   It's 03:16 AM.
