01-29-2013, 05:10 AM
#1 |
Oddometer: 312
Natchez Trace Parkway
So' thinking of this in some way shape or form. How similar is this to the Blue Ridge? If I ride it,will it kind of rob me of seeing the local culture etc? Like the BRP, as you know,doesn't really give you a sense of the towns that you are passing through.
Its all lovely countryside'of course, but I am looking for small southern town USA experience.I am happy to take any route suggestions,campground info etc.etc. Thanks! |
01-29-2013, 05:18 AM
#2 | |
Oddometer: 95
2010 Concours 14 |
01-29-2013, 05:20 AM
#3 |
Oddometer: 3,202
One thing is for sure that a slow speed limit for a couple hundred miles
Not bad if you are not in a hurry and very scenic and lots of roadside markers of the history of the route which is nice, towns not so much IIRC as it is limited access road like the BRP. Nice if you haven't seen it and easy enough to get off of to find your culture.
www.throttlemeister.net |
01-29-2013, 05:22 AM
#4 |
Follow me; I'm lost!
Oddometer: 4,286
Nice for a while. Pretty. Gets boring. Some cool attractions along the way.
01-29-2013, 05:31 AM
#5 |
KillerSmileIHazIt !!
Location: Moran Nation~ Some of the best roads in the east..
Oddometer: 21,514
I have done the whole thing... I have an RR in my thread..
THis RR we only rode 50 miles of the Trace.. The Natchez is a lot like the BRP...From what I could tell... But bigger sweepers... I do recommend to check out The LoveLess Cafe.. A lot of Nashville singers have stopped there... Plus a lot of cool art work.. The writing on the pie said: Shaky Puddin Pie... The Trace and Shiloh Here is the RR from The Trace ride... Natchez Trace part 1 Part 2 Windsor Ruins Part 3 Natchez Trace We enjoyed it .. And do want to ride it again.. And camp on the way the next time.. With out a huge group..
TISE Life is what you make of it~ If it don't fit make alterations Check it from time to time as I'm always adding to it.. My Rides and life on the Farm |
01-29-2013, 07:00 AM
#6 |
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,393
I rode the BRP, the Natchez Trace, and a lot of other roads in 2011. The Trace is similar to the BRP in being a long, essentially uninterrupted road closed to trucks and controlled by the Park Service, but they have very little in common in terms of landscape. The BRP is mostly mountainous and has a lot of twisty parts; the Trace is fairly flat and straight. But that said, it's still a nice ride in its own way.
For pics and more info, see my ride report: http://www.advrider.com/forums/showthread.php?t=697639 --mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe My ride reports: Missile silos, Labrador, twisties, and more Bennington Triumph Bash, May 31-June 2, 2013 |
01-29-2013, 06:48 AM
#7 |
Oddometer: 73
Natchez Trace starts out in the hills in TN and then gets flat as you get into AL. Slow speed, restricted access, nice ride when you have nothing better to do. Lot of interesting history.
BRP is in the mountains with some good views and curves. The two parkways are totally different. If you want to see local culture, pick any wiggly road that crosses the BRP. You will still have the mountains, views, and curves. Often the road will not be as well maintained but you will pass through a few small towns.
USA Representative - AREM Mexico Asphalt Rats Endurance Motorcycling Bunch of Kilometers! No Glory! |
01-29-2013, 07:44 AM
#8 |
Traveler
Oddometer: 171
I did the northern part of the Trace last year on a rented Harley. I thought it was kind of boring. The road is nice and its decent scenery but not much rider involvement. I wanted to see where Merriwether Lewis was buried ( Hoehenwald) and that was cool.
Quit dreaming, get on and start living. |
01-29-2013, 03:18 PM
#9 |
Oddometer: 13
I have ridden both the BRP and the Natchez Trail several times. I found the Natchez interesting the first time around but the second (years later) it was boring. The BRP however, I would go again and again
01-30-2013, 06:21 AM
#10 |
Oddometer: 1,437
I have ridden the Trace from end to end. The cool thing about the Trace is the history. Seems like there is a point of interest about every mile or so. The road for the most part is gentle curves with a 50mph speed limit. It is federally patrolled, but from my experience the police presence is not all that heavy. That said I did get pulled over while riding the Ural (so the guy could look at it)
2005 Ural 2005 BMW F650GS 2012 Triumph Tiger 800xc |
01-31-2013, 06:59 PM
#11 |
Oddometer: 877
The Trace can be a very relaxing ride , if you have adjusted your
expectations for a languid tour, not a timed run.Its character varies with the seasons. If ridden at the speed limit from end to end with only a few interruptions for scenic stops or short visits to towns just off the Trace it will actually take no longer than it would to connect the end points using the regular road system because the scenic parkway has no stop signs and cuts diagonally across the state and all other routes. In a spring ride from Natchez to near Nashville I saw lots of snowbirds in motorhomes heading north along it because they could so avoid heavy traffic . In late fall I imagine they use it similarly in the opposite direction If you want to see and experience regular Mississippi towns however the Natchez Trace will disappoint you., better stick to all the other state and county roads. Sjoerd Bakker screwed with this post 01-31-2013 at 08:47 PM |
02-02-2013, 07:02 AM
#12 |
Oddometer: 1,652
I'll add: the Trace is at its best in the spring & fall.
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85 |
02-11-2013, 11:26 AM
#13 |
Oddometer: 1,013
I have done all the BRP and Skyline Drive on the bike and then last summer did the Trace in the truck. I chose the truck instead of the bike based on a lot of reading about the Trace. There seemed to be way to much to do on the Trace and one would be climbing on and off the bike and gearing up and down all the time. We would be two up, so that compounds it even more. After completion I am glad we did the truck. If you want to just ride, the Trace would be fine. If you want to do the highlights of the Trace, then don't do it on a bike. One inmate already said it seems like there is a historic thing every mile, I tend to agree with that. We found a book in Natchez, MS that describes every single stop on the Trace. It gives you like the top 20 things to see. We stuck to the top 20 and it took us two very long days in the cage and we still didn't really spend the time we wanted at some of the stuff. Unlike the BRP that has some rest stops with food, etc.. along the way, you have to exit the Trace for anything like that. Which is fine because we found some really nice Mom and Pol places for lunch!! The views are right there on the road with you, no real vistas like the BRP, so although awesome in its own way, it has no comparison to the BRP. We did NOLA to Natchez to Tupelo the first day, then Tupelo to Nashville the second.
Heres a link to the guidebook we used http://www.amazon.com/Guide-Natchez-...+trace+parkway Don't get me wrong, the Trace is way cool, loved the history, but to me its not a trip done on the bike to really see what it has to offer. It would however be a great ride to go from Nashville to Natchez with a couple pre-planned historic visits. The Old Country Store Restaurant in Lorman MS is a must for lunch, IMHO!!!!! |
02-13-2013, 09:45 AM
#14 | |
Fabe
Oddometer: 62
- John Road Wise: An Odyssey of Machine, Maps & Meditations The Coulee - a 2012 7K ride blog |
02-15-2013, 10:08 AM
#15 |
Who . . . wha? Me?
Oddometer: 168
It's pretty and relaxing, but not nearly as majestic or grand as the BRP. Exceptionally smooth tarmac though.
