02-05-2013, 05:47 PM
#1 |
Oddometer: 577
Need advice on half wall at top of stairs.
I'm building a half wall at the top of my second story stairs. I put up the first of two tonight and need some advice as to how to make them stronger. The end at the top of the stairs wobbles back and forth with little effort. How do I make this better?
![]() Some pics to see what I'm working with... ![]()
1983 Honda CB650SC Nighthawk 1984 Honda GL1200A Goldwing Aspencade, a work in progress 1996 KTM 300 EXC Plated |
02-05-2013, 05:57 PM
#2 | |
gleam
Oddometer: 13,025
Can you cut some of the green color wallboard and run a sheet of 3/4 plywood up the stairwell face of the wall, bonding the lower wall with your pony wall?
02-06-2013, 09:19 AM
#3 | |
Oddometer: 1,473
Depending on what's going to happen in that little space behind the half wall, you could add a little 6-12" L at the free end pointing away from the stairs. And hopefully you're screwing that bottom plate down, nails won't offer much resistance to pullout as that hall gets pushed in or out at the top. |
02-05-2013, 06:04 PM
#4 |
Oddometer: 149
First, you need to double up the end 2x's and have them go down into the floor. Also, you can skin one side with 1/2 inch plywood an cut it into the full height wall some. Screww it every 6 inches and you wil create sort of a box beam. Also; stagger some 3.5 inch screws in the bottom plate.And, you need WAY more screws in your drywall; 6" on the edges and 12" in the field...
02-05-2013, 06:49 PM
#5 |
Whatever...
Oddometer: 2,503
4x4 post or doubled 2x4 needs to go through the floor and tie into the framing below floor level using carriage bolts through a king stud made for the half wall instead of screws. Then sheet both sides of the half wall with luan to create a "web frame" before sheeting with the drywall.
02-05-2013, 07:28 PM
#6 |
Oddometer: 2,242
easiest way would prolly to have a post going to the roof.other ways could be a steel L bracket or two bolted/screwed to the floor(rebated in)
Its not exactly a high traffic area behind it though,looks barely high enough to walk in there
aka BMWST?
02-05-2013, 11:40 PM
#7 | |
Oddometer: 604
needs to be heavy enough to not flex much and screwed to a floor joist, not just the subfloor. rebate=mortise ??....you can hide the bracket once flush under the floor covering. BTDT
08 KLR, 02 620Monster |
02-06-2013, 10:00 AM
#8 |
Oddometer: 2
In addition to above recommendations, if code will allow, consider making wall shorter by the width of the top step (12"?).
Some Assembly Required |
02-06-2013, 11:40 AM
#9 |
Oddometer: 248
Turn that wall into a bookcase or cabinet 12 or 20 inches deep.
02-06-2013, 12:37 PM
#10 |
Oddometer: 119
1st, skin the backside of the wall with plywood, 1/2" should do. Glue and screw (NO NAILS) the plywood to the studs. Go buy some construction adhesive. Don't be cheap with the screws, every 8-10 inches in each stud, run glue down all studs. 2nd, drill a few pilot holes and strew some 3"x1/2" lag bolts into the floor. The plywood will make the wall rigid, and the lag bolts will hold it to the floor. Most of the wiggle is coming from the fact that the nails are not keeping your joints tight. When you build the second wall fell free to put the construction adhesive between each joint for added strength.
Good luck! r1200gs_chris screwed with this post 02-06-2013 at 12:41 PM Reason: Big fingers |
02-06-2013, 01:45 PM
#11 |
Oddometer: 643
I am betting this isn't a permitted job. The space behind the wall doesn't look like it could used for anything but storage. I would build the wall floor to ceiling. Any attempt to steady the wall with brackets to the floor is a waste of time. GH
02-06-2013, 03:32 PM
#12 |
Oddometer: 577
I like the plywood to tie it in to the lower wall. you guys are right, storage behind this wall, but there is gonna be a matching (but longer) wall on the other side of the stairs that will see a teenager boys traffic to his room and all of his friends, etc.. so any techniques will be applied to that side too. Keep the ideas coming.
02-06-2013, 05:56 PM
#13 | |
gleam
Oddometer: 13,025
Gluing it with construction adhesive is an excellent move, but skip the screws unless they are the GRK structural kind. Screws snap over time. Nails are the best bet in wood construction.
02-14-2013, 09:26 AM
#14 |
Oddometer: 224
02-14-2013, 06:00 PM
#15 |
Oddometer: 9,786
