02-15-2013, 08:07 PM
#1 |
Oddometer: 295
Changing Sparkplugs on a 950SE
While waiting for my suspension to come back from SuperPlush. I decided to change the sparkplugs, replace the air filter and clean my pre-filter. I read here how it was a PITA to change the front sparkplug.
Changing the front sparkplug on the 950SE is a PITA becasue of the tight space. With my gas tank already off the bike, I found the easiest way to access the front sparkplug and to create some space was to:
02-16-2013, 02:23 AM
#2 |
Oddometer: 185
If you drain the radiator, you can just as well remove the radiator. Works much easier.
It's best to do it all at every 15000km service interval: - drain and remove radiator - change spark plugs - check and correct valve clearances - check and clean carburators - remount radiator with new coolant |
02-16-2013, 03:49 AM
#3 |
Oddometer: 5,036
Or take radiator bolts off, push rad forward and slide out cooling fan assemble. So you don’t have to touch coolant.
02-16-2013, 05:29 AM
#4 |
Ride more, BS less!
Oddometer: 8,399
Yup!
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150 Hi/low beam conversions for: Trail Tech, Baja Designs |
02-16-2013, 08:51 AM
#5 | |
Oddometer: 2,200
Thanks for saving me the time to type the same repyl!
07 SE PG007 "Up there where you eat moose-cock you must all be rockets scientists." |
