Old 02-19-2013, 07:33 AM   #1
ExTex OP
Oddometer: 248
ATF for Clutch Hydraulic Fluid ?
I'm rebuilding the clutch hydraulic system on my Nighthawk 650 and would like to replace the DOT 3 brake fluid with ATF.
Are there any problems that will arise if I do this ?
The ATF is a lot easier to be messy with and there should be no high temperatures to cause any boiling.
I appreciate any comments.
Ride Safely,
ExTex: 2015 CB500 FA, 1989 Inteceptor VTR 250
Sold: CB650sc, VF700s, VT500c, Ninja 500
ExTex is offline   Reply With Quote
Old 02-19-2013, 07:37 AM   #2
Hootowl
Oddometer: 1,268
I use it on my 990 KTM
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 02-19-2013, 07:39 AM   #3
jar944
jar944's Avatar
Oddometer: 730
Ride Safely,
If it calls for brake fluid you CANNOT use mineral oil (atf) in the system. The seals are not compatible.
jar944 is offline   Reply With Quote
Old 02-19-2013, 08:17 AM   #4
ExTex OP
Oddometer: 248
Thanks. Seal compatibility is very important, so I will continue to use brake fluid.
Thanks again,
Times are GMT -7.   It's 11:29 AM.
