Old 03-03-2013, 01:31 PM   #1
JayhawkGSA OP
Oddometer: 108
Another Gerbings install
After reading several other threads on Gerbings installs I thought I would try one on my 07 GSA. I wanted the install to be as "built in" as possible meaning I wanted al the connectors and controls to look like they belonged there as best as I could manage.
I used a PDM60 module to power everything and installed weatherpack connectors on all the leads so if I ever want to change out gear it will be easy.
Bad picture of the cables running up and the controllers being tested before I install them.
Controls installed and still working.
I am a big fan of shrink tubing and this woven wire loom. It makes it easy to pull wire and offers a lot of protection.
I cut up the tool tray quite a bit and installed plexiglass (painted black) to create a pocket underneath for the Gerbings module. Here you can see the module and the weatherpack connectors I used to connect the barrel jacks.
Here is a shot of the control wire tapped into the diagnostic plug.
And the payoff. Barrel jacks exiting the tool tray. I saved the rubber plugs that came with the Gerbings and will rivet those to the tool tray as well so I can plug up the barrel jacks when not in use.
This is probably not an install for the faint of heart. I pretty much took the Gerbings out of the box and immediately cut all the ends off of all the wires. There is some delicate soldering as well to connect the center pin of the barrel jack without melting the plastic insulator.
I would like advice on a good solution to grounding. Currently I have the PDM60 going straight to the battery but as I add other stuff I need some sort of bus bar to ground things to. I don't want to have 15 wires coming off the battery. I also have no idea where good grounding points are on this bike. So if anyone has a suggestion I am all ears.
JayhawkGSA is offline   Reply With Quote
Old 03-05-2013, 08:50 PM   #2
seniorasi
Oddometer: 816
Looks like you have it covered. If you use a single lead from the battery to the bus bar it should work as a ground as long as it doesn't corrode.
seniorasi is offline   Reply With Quote
Old 04-10-2013, 09:16 PM   #3
JayhawkGSA OP
Oddometer: 108
Do you have any suggestions on a tpe of bus bar or where a good place to mount it is? This brings up another good question, where are the grounding lugs on these bike. Like on my truck I can find 3 or 4 places where things are grounded and connect to them.
Old 03-06-2013, 05:03 AM   #4
mitchapalooza
Rider is Air-cooled
mitchapalooza's Avatar
Oddometer: 122
Thumb
+1 on the weatherpack and fiber loom.
mitchapalooza is online now   Reply With Quote
Old 03-06-2013, 02:16 PM   #5
qman8
GS09
qman8's Avatar
Oddometer: 520
Nice job! But..Curious why you feel the need for all those weatherproof connectors taking up all that space instead of direct connection.???
qman8 is offline   Reply With Quote
Old 04-07-2013, 03:03 PM   #6
JayhawkGSA OP
Oddometer: 108
Just for overal versatility and service. Eventually there will be several items plugged into the PDM and I don't want to have to desolder everything to change the PDM out should it go bad. More and more I find myself using OEM style connectors for things. They are really robust and offer a lot of versatility. There is a reason they are OEM.
I believe there is a new standard of connector that GM uses now that is smaller so I might check that out in the future.
Old 04-07-2013, 03:22 PM   #7
'05Train
Mind is not for rent
'05Train's Avatar
Oddometer: 1,050
I think his question is why you didn't just connect the Gerbing's leads directly to the battery. It seems to me that would have been massively easier, as long as you don't mind having it unswitched.
Slick install though.
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
'05Train is offline   Reply With Quote
Old 04-07-2013, 04:19 PM   #8
BTL
WINTER!! UGH!
BTL's Avatar
Oddometer: 414
Thumb
Looks real slick..nicely done.
BTL is offline   Reply With Quote
Old 04-10-2013, 09:12 PM   #9
JayhawkGSA OP
Oddometer: 108
Exactly that, I wanted it switched. Also, I don't like a bunch of stuff coming off the battery. This way only one thing is connected to the battery and I can plug and play whatever I need off of the PDM60. I Like the PDM60 because there are no fuses to blow, the downside is if it takes a crap you are out of luck I guess.
Also, it was winter, what else was I going to do?
Times are GMT -7.   It's 04:32 PM.
