Old 03-17-2013, 08:29 AM   #1
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
Mounting Big Blocks help...
Im in the midst of "trying" to spoon on some Kenda Big Blocks on my R1100 rims. I got the old tourance off the rear rim in under 5 minutes....easy as pie.
I got the Big Block and got it halfway on with very little effort. But im completely stuck trying to get the last half of the tire on the rim. Initially I tried it yesterday in the garage, but it was cold here yet. So i brought the tires in for the night to warm up. I just gave it another go (indoors) and it is impossible. I dont have a tire changer, just the ole blood, spoons, sweat and tears method. It just seems that tire has NO give at all and is almost too small. ( yeah its the right size ) If i get the tire say 3/4's of the way on, the last bit of tire has like a solid inch and a half to go yet before it can even attempt to hop over the rim.
At this point, im thinking the tire is shot. It started to tear even from just trying to spoon it over the rim before. (not bad....ill get a pic) THe last attempt before i gave up just now i thought i heard tearing/stretching ( or maybe that was some muscle tearing in my arms).
I got the rim and tire lubed up with tire gobs of tire mounting lube, so it should just slip right on, like when i did my Anakee 3's on the 1200 GSA a few weeks back.
Any tips or should I just throw in the towel and bring em in someplace?
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Ducs2Dirt is offline   Reply With Quote
Old 03-17-2013, 08:34 AM   #2
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,594
Make sure the back side of the tire is in the valley before proceeding. I use wedges of plastic to force the backside into the valley. This allows the "topside" to easily mount. You can see them on the right. At this point I would still try the tire out as long as the bead isn't destroyed.
Trust me, putting these 185/55 x 17s are a big pain and I swear I'll bring them in next time and let a pro do it.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-17-2013, 08:55 AM   #3
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
Here's the little tear. Its not hard bead itself, but the softer excess rubber around the inner bead. well a pics right here so why the hell am I describing it even.
I havent tried that shim idea yet. I've been trying to keep it in the valley, but this rubber on the big blocks is hard as hell. Id try that out if i didnt have any fear of screwing up the tire anymore. But at this point....i might throw towel in. Hoping that tire isn't shot now.....Ive never had a fight this big with a tire ever. Its noon here and saint patty's day.....time for a beer.
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Old 03-17-2013, 08:58 AM   #4
vtwin
vtwin's Avatar
Oddometer: 7,594
I'd run that tire. Leave it in the sun (we have plenty where I live.) to soften. Makes life easier. Good luck, I've been there.
Monroe.
unknown
Old 03-17-2013, 09:05 AM   #5
victor441
victor441's Avatar
Oddometer: 990
Maybe try using the zip tie method....if that tire is really stiff it make take 8 + ties or in the original thread here cargo straps were used...anyway the beads are forced together, both are mounted at the same time, and it is fairly easy to keep both in the well while mounting. I have done two in that size (150/70) but nothing bigger, a front tire is shown in the photo. If you try it there is no need to cut the ties once the tire is on, the lock tabs can be released w/ a small screwdriver
victor441 is offline   Reply With Quote
Old 03-17-2013, 09:35 AM   #6
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,024
I have a BigBlock on the back of my 1150, don't remember anything out of the norm when I put it on. Like mentioned, you have to make sure the tire stays in the center opposite of the side you're trying to get on right now. I put a wooden block under that side and my knee on the top, keeps the tire pinched into the center as you spoon on the last section.
That little booger you tore won't hurt a tubeless tire, it might pop a tube, but you don't have tubes.
Old 03-17-2013, 09:45 AM   #7
xcflyn
xcflyn's Avatar
Oddometer: 1,152
2 -2x4's
2-spoons
some use windex- I use paste.
2 good knees- which I dont have but I kneel on the edges of the tire with the a 2x4s under the areas of where I kneel as I work it around. The 2x keeps he bottom up in the relief and my poor old knees keep the top down. I lubricate the tire and rim, and once over that tight spot it pops right on. Kendas are tough but for a good side wall it is worth a bloody knuckle or two.
xcflyn is online now   Reply With Quote
Old 03-17-2013, 10:34 AM   #8
gsweave
Yinz, blinkers are on.
Oddometer: 12,110
Ohhh! Me likey zipties.
No stiff sidewall can resist 1hr in 80 degree sunshine
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 03-17-2013, 10:59 AM   #9
sieg
sieg's Avatar
Oddometer: 2,880
Is the tube in there?
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 03-17-2013, 12:28 PM   #10
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,725
use plenty of dish soap all over the rim bead area, and tire bead.
I mounded a big block on the back of my 1100gs, using only little 6 inch tusk tire irons.
It wasnt easy, but certainly not unpossible.
your technique has to be good, make sure the opposite side from where you are stretching is as far into the rim as it will go, thats the only way.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 03-17-2013, 01:40 PM   #11
Ducs2Dirt OP
Not quite all there
Ducs2Dirt's Avatar
Oddometer: 168
ZIPTIES TO SAVE THE DAY!
After I last posted I had to run out to lowes for some stuff. So when I was there I picked up some of those huge HVAC zipties. 10 bucks for 25 of those 1/2" wide X 36" long ties.
I popped the rear tire completely off again and put eight ties on the big block. I kept working my way around until i pretty much got both beads touching.
Then.....it was THE easiest tire change ever. I literally had the big block on the rim in under a minute, after it was a ziptied up. Using my travel 6 inch irons.
With the same method...I had the front done in under a half hour. Including taking off the rotors/abs ring and putting it all back on afterwards.
Thanks for all the help guys. Have a cold one on me. Speaking of which it's time i had a cold one myself.
2011 1200 GSA
1995 1100 GS (sold)
2013 S 1000 RR
Old 03-18-2013, 06:49 PM   #12
jdrocks
Gravel Runner
Oddometer: 4,546
glad it worked for you. truth is, you just needed to warm those BB tires up a little, check that, you needed to warm them up alot.
the method i've always used when the shop is cool is to put them on the front seat of the pickup, turn the heat up to fry your butt, fan to helo high speed, walk away and do something else for awhile. the rear tire needs to be darn warm to the touch, if not hot. that and plenty of lube, and it mounts right up.
the fronts aren't anywhere near as stiff, but it still helps to warm them too.
even in summer temps, i'll let the BBs sit in the sun before mounting.
once you mount them all heated up, you'll wonder what all the fuss was about.
jdrocks is offline   Reply With Quote
Old 03-17-2013, 10:33 PM   #13
victor441
victor441's Avatar
Oddometer: 990
yep, you inflate it just enough to round the tube out and it is nearly impossible to pinch it when mounting the tire...also very easy to get the valve stem through the rim hole
Old 03-18-2013, 06:46 AM   #14
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,452
Have you ever used the zip ties when trying to mount a tire with rim locks?
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 03-18-2013, 09:44 AM   #15
victor441
victor441's Avatar
Oddometer: 990
Not me, have used them on all three of my bikes successfully but none have rimlocks...
Times are GMT -7.   It's 04:58 PM.
