Old 03-30-2013, 07:40 AM   #1
muttley92 OP
Oddometer: 66
what do you get if you combine and RS 125 and a 640 LC4???
This a a build thread for a supermono road bike, it's been done before but I've never seen a proper build thread. Several people have asked me for this so here it is.
muttley92 is offline   Reply With Quote
Old 03-30-2013, 07:48 AM   #2
muttley92 OP
Oddometer: 66
First things first
I should start by saying that I am 20, I live in the UK, I'm studying a masters degree in Mechanical Engineering at Loughborough university and this is something I'm doing for fun in my spare time.
Old 03-30-2013, 07:52 AM   #3
muttley92 OP
Oddometer: 66
This is what I started with
The engine came from ebay 2004 640 LC4 from a duke II, the bike is a 2009 Apilia RS 125 that was a cat B write off and it arrived in bits.
Old 03-30-2013, 08:12 AM   #4
muttley92 OP
Oddometer: 66
getting the engine in there
This engine looks like it was made to fit in the Aprilia frame! The mounts needed filing down by about 2mm to fit in the swing arm, and I had to take a little off the front of the swinger for clearance. The earlier engine is easier to get in the frame (you don't need to do anything to the swing arm) just the bushes. It's tight, but it fits
Old 03-30-2013, 08:18 AM   #5
muttley92 OP
Oddometer: 66
Engine mounts
I cut down the standard RS engine mounting plates and modified them slightly
Old 03-30-2013, 08:24 AM   #6
muttley92 OP
Oddometer: 66
Then I made an exhaust
It's not the best but I made it, it's mine and it will work
Old 03-30-2013, 08:12 AM   #7
Kawidad
Kawidad's Avatar
Oddometer: 4,974
From the LC4 thread and I'm in.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 03-30-2013, 08:20 AM   #8
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 773
what do you get 640+rs125
A frame twisting mind bending wet dream ,and that's before it starts ! Subbed on the title value alone..
Go for it ,Ed !
pennswoodsed is offline   Reply With Quote
Old 03-30-2013, 08:38 AM   #9
pennswoodsed
lizards,bugs and me
Oddometer: 773
Remembering your field
Hi,
Your 2nd post ,engineering student so maybe this is dumb ,the front mounts are single shear on a butt weld ,I would want to spread moment above and below weld. Maybe.
regards,Ed
Old 03-30-2013, 09:32 AM   #10
Salsa
Oddometer: 420
Originally Posted by pennswoodsed View Post
Hi,
regards,Ed
Or overkill !!!!!!!!!!!!
Don
Salsa is offline   Reply With Quote
Old 03-30-2013, 09:59 AM   #11
muttley92 OP
Oddometer: 66
That was considered. It's 3mm stainless 304 on both sides, since the engine deadweight is only around 40kg max and majority of the weight is on the rear mount I think it will be just fine. But I'll keep an eye on it and if it should crack I'll find a solution.
muttley92 screwed with this post 03-30-2013 at 10:41 AM
Old 03-30-2013, 10:02 AM   #12
muttley92 OP
Oddometer: 66
Got hold of an FCR
And many thanks to the Loughborough University Formula Student team for letting me use the lab and the weld set!
Old 03-30-2013, 07:17 PM   #13
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 12,184
Dead weight is nice. That's your statics class. Have you taken dynamics? What about when that thing starts up and flexes those welds to death? The LC4 is known to be a paint shaker. I'd seriously rethink the design of that front mounting system.
Also: the LC4 doesn't need an oil tank at all. The original engines didn't have one, nor did the strictly off-road models. The oil capacity was to add some extra oil to wear out and burn, as well as a place to mount an external oil filter. On the original design, the filter was located where the e-starter lives now.
Have you considered something like an automotive remote filter mount and using the largest oil filter you can find? That should add 500cc of capacity and a filter without having to worry about that oil tank failing.
Donkey Hotey is offline   Reply With Quote
Old 03-30-2013, 09:55 AM   #14
Droptarotter
Oddometer: 1,296
Hi,
regards,Ed
I'm no engineer, but have been around these thumpers for quite some time and the front mount looks like a crack waiting to happen.
Did you make the mounts just for a temporary hanger? Redo them later?
Good luck with this...........it looks like it will be a nice combination once completed!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter screwed with this post 03-30-2013 at 10:54 AM Reason: spelling
Droptarotter is offline   Reply With Quote
Old 04-21-2013, 11:20 AM   #15
Dazed Productions
Oddometer: 188
Seriously good build, nice one! I am in the UK and starting to wonder what to build with a 690 engine I have sitting about. Thinking more of a scrambler type thing myself though.
www.dazedproductions.co.uk
Dazed Productions is offline   Reply With Quote
Times are GMT -7.   It's 02:59 PM.
