Old 03-31-2013, 02:57 PM   #1
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,689
Exhaust pipe expander ?'s
I am working on another custom exhaust and I have the following measurements.
The header terminates in a male tube 1.66-1.69" OD depending on where you measure it. I found 1.75" SS exhaust tubing 16g would be 1.75-(0.065*2) or 1.62" ID
1.75" 18g (0.049" wall) would be 1.652" theoretically.
http://www.mandrel-bends.com/catalog...-tube-390.html
I know I am going to need to massage this tubing slightly to make that joint a nice slip fit.
I've read some reviews of exhaust pipe expanders on Amazon etc and did not get a good feeling but I am only trying to get a little bit of diameter out of this tubing.
http://www.amazon.com/Lisle-32500-Ex.../dp/B0002STSNU
Suggestions including buying new tools or having a shop do it?
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 03-31-2013, 04:11 PM   #2
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,336
I've built a couple exhaust collectors for LC8's and needed to get some SS pipe expanded. I went to a local guy that does custom exhausts and headers to have the pieces expanded. As soon as he saw the SS he said it will split. Sure enough,,,,every piece he tried to expand split. Some split as soon as he put pressure on them and others split after about 1/16"
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-31-2013, 04:57 PM   #3
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,689
I have to think it's possible in some way. The guys mandrel bending this stuff are deforming the metal much more than I would be getting fifty thousandths or so. But I guess I would be getting close to the 1/16" you were.
I have some larger diameter SS from this same supplier and I might try out a piece with a local muffler place before buying a bunch of new stuff.
Everything from this joint back to the can will be welded so I really only need it fit this one section. Hell even if it split I could pretend it was supposed to be that way in order to split it for clamping. I could also slit the tube and form it over a blank I make on the lathe and TIG weld it but I think that's a lot of effort for something that should be easier.
What wall thickness was the material you had when it split?
Nessmuk
Old 03-31-2013, 11:42 PM   #4
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,536
This is my pipe expander - you need to heat the pipe for it to expand. Exhaust shops have hydraulic expanders that work pretty well....but not pretty.
motu is offline   Reply With Quote
Old 04-01-2013, 05:20 AM   #5
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,336
18ga SS. Maybe with the little bit you need to expand it will be fine. The shop I use has been doing this work for as long as I can remember,,, he can bend anything. He's even bent a couple brass and copper boat exhausts for me over the years.
We did try heating one and it split just as easy. Not sure what you mean by not pretty,,, the hydraulic expanders are the same principle as the manual.
Old 04-01-2013, 06:23 AM   #6
crawdad
Oddometer: 488
Don't know if you could go the other way with a bigger tube but Concours has some 2" stainless .060 wall for sale In the FM and the price seems pretty reasonable to me.
crawdad is offline   Reply With Quote
Old 04-01-2013, 09:40 AM   #7
redprimo
Oddometer: 461
Did you anneal the tubing or heat it up and try expanding it while red hot. I'm just curious because I have my first exhaust project comming up and I will be using stainless tubing.
Id love to see some pics from the Op as the project progresses, will you also be fabing up a muffler?
redprimo is offline   Reply With Quote
Times are GMT -7.   It's 10:47 AM.
