Old 04-26-2013, 04:48 PM   #1
XL-erate OP
Oddometer: 154
Custom Fork Mods....
Hi folks!
Just thinking about Steering Fork modifications for a sidecar rig.
I'm guessing that some companies that do mods to reduce Trail may weld up the Triple Tree parts and then redrill fork tube holes in brackets at a new angle to reduce Trail? Others may fabricate new Triple Trees?
Seems like it might be possible to simply install triple tree in a solid jig for accurate alignment and zero movement, then over-bore existing fork tube holes at the new desired angle. Then fabricate a simple tubular spacer insert for oversized triple tree holes, to take up gap of old tubes with new larger hole.
Tubular spacer would need a slit down the side so it can compress. May want to fab spacer so there's a slight ridge at top and bottom edges to help keep it from walking up and down in new triple tree hole.
Seems to me this would be one of the easiest and cheapest methods to reduce Trail, yet as effective as custom triple trees? I would assume [uh-oh] that most topnotch machine shops can do this. Thanks for any feedback!
XL
XL-erate is offline   Reply With Quote
Old 04-27-2013, 03:07 AM   #2
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,398
Sounds like an elegantly simple solution. My first thought is that there may not be enough material in the outer edges of the tree to retain significant strength. I guess the amount of movement would vary with each bike.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 04-27-2013, 05:25 AM   #3
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,186
What you're thinking of is close to this at Liberty:
http://www.sidecar-industry.com/trip...tripletree.htm
Liberty makes lowers and modified upper clamps.
Bobmw is right- there's not enough material to hog out the lowers to increase the rake.
http://www.perrysmotorcycles.com/
Perry's solution of all new billet trees is elegant and is pretty cheap.
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 04-27-2013, 08:19 AM   #4
XL-erate OP
Oddometer: 154
Thanks, guys!
I thought it was too simple....
Old 04-28-2013, 06:32 AM   #5
leejosepho
Sure, I can do that!
leejosepho's Avatar
Oddometer: 506
I have decided to just leave my forks as they are, but I believe there is a simple way to move the entire assembly forward a bit by adding a second second set of trees behind the first and attaching the two together.
He who so shall, so shall he who.
leejosepho is offline   Reply With Quote
Old 04-28-2013, 07:54 AM   #6
NitroMax
NitroMax's Avatar
Oddometer: 687
In the Netherlands they are called "Ed Pols platen", when you Google that you'll find info and pics
Here's some info on Halflive's page ( in Dutch )
CLICK
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Old 04-29-2013, 12:31 PM   #7
claude
Sidecar Jockey
Oddometer: 3,990
This type of sysem is nothing new and has been done ... and does work quite well . One good thing about it is that it does not change the angle of the forks and still reduces trail. It also does not affect ride height which can b egood. 'Raking ' the forks with different trees or modified trees can cause complications with various things such as bar mounts, bar mounted fairing clearances etc. The system of moving the whole fork assembly forward does not create these issues and retains the stock triple trees. Yes, there are other issues even with this sytem with fixed fairings and so forth but over all It is a good system. We have discussed producing this type of an item for quite a while and may still do so at some point.
Claude
http://freedomsidecars.com/
claude screwed with this post 04-29-2013 at 12:50 PM
Times are GMT -7.   It's 03:09 AM.
