Old 06-16-2013, 11:46 PM   #1
tshelver OP
Oddometer: 567
Clutch cable: to lube or not to lube?
Just had a seized cable as a result of corrosion. Only 6 months on the bike.
It could have been a sea crossing where the whole bike was liberally doused by the waves, or standing in the rain, or it could have been slightly corroded from delivery, as the clutch and shift action after replacement is much better than it's ever been.
I have a lube tool, another question is whether to use the supplied cable lube or a really good corrosion inhibitor I have (ACF-50).
No WD40 thanks, I've proved that the ACF-50 works a lot better already.
Sent from my Android chinaphone, please excuse the spelling
'11 Yamaha YBR125G (cheap and very cheerful
'12 Zongshen Fly / Motorstar MSX200-II (biggest-fun-to-dollar ratio of any bike I've owned)
'03 Honda VFR800 (sold)
'06 Husky TE610 (gone)
tshelver screwed with this post 06-16-2013 at 11:55 PM
tshelver is offline   Reply With Quote
Old 06-16-2013, 11:50 PM   #2
usgser
Oddometer: 2,167
Lube.
usgser is offline   Reply With Quote
Old 06-17-2013, 04:49 AM   #3
Strawdog
Strawdog
Strawdog's Avatar
Oddometer: 113
I been using transmission fluid on my throttle cables and clutch cable on all my bikes never had a broken cable yet in 600000 KM.
I think as long as your using something to lube it its better then nothing .
Strawdog is offline   Reply With Quote
Old 06-17-2013, 07:02 AM   #4
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
I second that and add that some grease on both heads of the cables help avoid bending the wire at each control input, which is the main reason of failure.
lnewqban is offline   Reply With Quote
Old 06-17-2013, 07:44 AM   #5
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 992
If you have an uncoated steel cable, lube it. If you have a Teflon coated cable, don't lube it. Always grease the cable ends.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 06-17-2013, 09:20 AM   #6
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,294
I'd have to agree with this. I've seen the lined cables start dragging because the inner cable eventually saws its way through the lining, creating drag. "Modern" cables seem to last a long time. Unless they get doused with salt water.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is online now   Reply With Quote
Old 06-17-2013, 04:51 AM   #7
trailer Rails
trailer Rails's Avatar
Oddometer: 3,792
Once you start lubing, you have to do it regularly. Dust gets stuck to the lubed cable and you have reoil to flush it out. I prefer not to lube and just replace the cable when it gets sticky.
trailer Rails is offline   Reply With Quote
Old 06-17-2013, 05:38 AM   #8
tshelver OP
Oddometer: 567
Thanks for the info guys. About what I expected.
Apart from my old Guzzi in the early 80s which had very stiff controls, I've never had an issue until now, at least on a motorcycle, and never lubed them.
I've had cables freeze up in winter on my bicycle, due to moisture, but solved that with sealed and lined Gore Ride-on cables. Lubing worked a bit to solve that problem but wasn't a permanent solution, at least for sub 20F riding.
It could also be that I'm in a much hotter, moist climate with no real garage, and I guess a few doses of salt water doesn't help either.
I'll do a spray test with the cable lube to see how sticky it is, but my guess is that the ACF-50 or maybe 3M Teflon lube will be the way to go, as neither leave much sticky residue to trap dirt.
tshelver screwed with this post 06-17-2013 at 05:57 AM
Old 06-17-2013, 06:09 AM   #9
yooperbikemike
high, wide and handsome
yooperbikemike's Avatar
Oddometer: 12,541
Yes, but use a moly/graphite based lubricant.
"...people in the stands want to see good, close racing. The thing is to put on a show, and that’s what’s going to draw people in..." -- Scotty Parker
yooperbikemike is offline   Reply With Quote
Old 06-17-2013, 04:42 PM   #10
tshelver OP
Oddometer: 567
Originally Posted by LuciferMutt View Post
I would use a lube made for cables -- most of them have a solvent carrier that distributes the dry graphite lube where it needs to be, then evaporates. Nothing left to attract dust and grit.
How are they on corrosion? That was my problem on the cable I replaced.
Old 06-17-2013, 06:54 PM   #11
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,223
I don't know. Probably not great, but if you grease the cable ends, it acts as a barrier to keep moisture out of the cable sheath and let the dry lube continue to keep things smooth.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 06-17-2013, 07:05 PM   #12
yooperbikemike
Oddometer: 12,541
Bike Aid creeps into the smallest spaces including the pins on the chain and cures to leave behind a dry film of moly. This unique dry film won't attract dirt or dust, is highly resistant to water, and prevents rust and corrosion It is the perfect lubricant to use on brake and gear cables, derailleurs, front and rear brake pivot points, shift controls, chains quick release nuts. Prevents cable freeze up. It functions properly in temperatures from -20* F to 1000* F.
Dri-Slide* Multi-Purpose Lubricant,
A versatile penetrating formula of Technical Fine grade moly and Graphite with rust and corrosion inhibitors.
Broad range of uses makes this our largest-selling lubricant. One of the easiest ways to apply drislide. It is the most widely specified dry film lubricant in aviation maintenance manuals and for general industrial MRO applications, for tractor-trailers, motorcycles, bicycles, and even weapons. Effective temperature range of -20* F to 1000* F (7* C to 537* C). Agitation required. Drislide Multi-Purpose dries to a dry moly film, that bonds to the metal service, staying in place, to lubricate longer than other lubricants. Does not collect dust & dirt and repels moisture.
yooperbikemike screwed with this post 06-17-2013 at 07:13 PM
Times are GMT -7.   It's 06:16 PM.
