Old 06-26-2013, 12:30 AM   #1
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
BergDonk's XT1200Z
This followed me home last week
Replacing the GTR, that will not be forgotten, but it wasn't for the sort of riding I'm keen on now.
So the net no of bikes in the shed remains the same for the time being.
Why an S10? The price was right and they are a great bike as attested to by many, and I enjoy riding them. I had toyed with getting a GS when I got the GTR, but once again, they just don't do it for me for some reason. So why not an S10?
Been googling a bit and sorting out the farkling needs and wants and it'll end up like many, but I thought I'd post up the build here on ADV anyway. And I'd certanly like to specifically mention that Wasp's and jaumev's threads have been very helpful. Thanks guys. And as ever, there is also lots of good stuff here on ADV and also over on the Super Tenere forum.
http://www.advrider.com/forums/showthread.php?t=595933
http://www.advrider.com/forums/showthread.php?t=778809
http://advrider.com/forums/showthread.php?t=797977
http://www.yamahasupertenere.com/index.php
First up was connecting up the battery tender, so off with the side cover/panel and hook up the tail for the Ctek and the first issue is identified!
Its almost impossible to get the screw on the +ve battery terminal to grab the nut because it won't stay put, gravity and all that.
A little bit of foam that I think originated a mouse pad or similar and good to go.
Also note that I have got a can of flat fix jammed nicely in where the tool kit is supposed to live.
Next was the supplied factory headlight protector after using some thinners to remove the 'Not For Highway Use ' logo. Fits well and looks the part.
So what to do with the tools?
There is some useful space under the seat, so some CO2 cartridges and tubeless repair plugs go there nicely.
Then raiding SWMBO's tupperware drawer located a tray that after a little trimming fits too. This is with the seat in the high position, and I modified the mount a bit so the low position isn't so simple now. Not sure about the colour, but it was cheap, and its hidden once the seat is on. Gotta set up the tool kit so that roadside maintenance can be done, and the stock kit isn't much good for much at all.
We get mail 3 times a week here, and today was one of those days
Hepco Becker bash plate, water pump and rear master cylinder guards, Altrider crash bars, uni joint guard and Rox Risers have arrived and await fitment.
Also to be fitted are the factory panniers that were included in the package, and to do in no particular order are:
Driving lights
GPS mount and wiring
Clutch switch bypass
ABS disable switch
Extra power outlets
tank bag
Ohlins shock
Sort the forks with linear rate springs and valving
footpegs
barkbuster
etc
My focus is on comfort/ergonomics and suspension, because that's what I like. There may be a pipe in the mix down the track too, time will tell!
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk screwed with this post 07-01-2013 at 06:10 AM
BergDonk is online now   Reply With Quote
Old 06-26-2013, 01:24 AM   #2
Woody2627
Skinny Decaf Latte Thanks
Woody2627's Avatar
Oddometer: 1,039
Hey Steve, did you copy Mcalister or did he copy you??
Woody2627 is online now   Reply With Quote
Old 06-26-2013, 01:35 AM   #3
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Dunno Woody, but displaying my igorance here, who's Mcalister?
Nevertheless, not too much original stuff likely to happen here, but you never know.
Old 06-26-2013, 01:36 AM   #4
Woody2627
Woody2627's Avatar
Oddometer: 1,039
Shane, from DSMRA...950SE...plus S10 as of a coupla weeks ago.
Old 06-26-2013, 01:50 AM   #5
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Well there you go, great minds think alike perhaps?
Old 06-26-2013, 02:07 AM   #6
Happy Snapper
GOMOB.
Happy Snapper's Avatar
Oddometer: 2,160
Mate I have had mine for 9 months now... just love it.
With the alt rider rear rack there is a sub rack that holds my compressor and puncture kit. Have also fitted a small GS style aluminium tool box that holds the OEM tool kit.
You'll love it mate!
Happy Snapper
Never trust atoms.... they make up everything!
Read my Blog: http://snapshotsfrommark.blogspot.com.au
Happy Snapper is online now   Reply With Quote
Old 07-01-2013, 05:51 AM   #7
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
So sucking it all in, some bits arrived in the post:
First up, the Hepco Becker bash plate. It had some sharp edges, so a little time with the file seemed like a good idea. Fits well, and its all welded. The marketing pics show its rivetted, but welding works better for me I reckon. It doesn't contact the engine underneath and where the lug is on the LHS, there is a hole in the plate. I thought about cutting the lug off the cases but couldn't quite bring myself to do it, yet.
The standard plastic deflector.
You can see the lug through the hole in the plate, and hole below it. in case.
No protection for the water pump and hose though.
Old 07-01-2013, 05:57 AM   #8
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Crash Bars
Some Altrider crash bars.
And a HB water pump guard. The wp guard goes under the crash bar mount onto the stock bar mount on the frame, spacing out the front 3 mm. After tightening it up from the LHS, this RHS mount was about 1 mm clear of the wp guard, and 8 mm clear at the back, so I machined up a spacer that you can see under the back bolt so that I didn't overstress it all by pulling it in.
Which has the benefit of adding a little more space to remove the panel to access the electrics and storage area underneath. The rag just means its less likely to get scratched.
BergDonk screwed with this post 07-04-2013 at 01:36 AM
Old 07-01-2013, 06:00 AM   #9
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Rear Brake Reservoir Protection
The rear master cylinder reservoir is a bit vulnerable.
HB has a simple solution
BergDonk screwed with this post 07-04-2013 at 01:37 AM
Old 07-01-2013, 06:06 AM   #10
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Top Box
I had a Kappa top box lying about in the shed, so decided to fit it.
Removed the standard rack top plate.
Machined up some spacers to get it level.
Bolted the top plate down with the stock bolts and one longer one up on the tail.
Fit the blanking panel and its good to go as a rack that's a bit bigger than stock.
Or with the monokey box clipped on.
Old 07-01-2013, 06:07 AM   #11
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Bar Risers
Some bar risers needed. Rox has a nice solution that goes up and not back. All cables are fine with no tweaking needed.
BergDonk screwed with this post 07-04-2013 at 01:35 AM
Old 07-04-2013, 01:45 AM   #12
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Heel Plate
The standard heel plate on the LHS stops about half way up compared to this Altrider version. Not impossible to hook your pants cuff over the stock one and find out about it as you attempt and fail to put your foot down when coming to a stop. Cheap easy fix.
Old 07-04-2013, 01:52 AM   #13
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Footpegs
Some lower pegs for more leg room from SW Motech. Nice and grippy, and easy on the boot soles. Optional rubber pad that I left off. More leg room and the bar risers make it easy to transition to standing.
But a bit of a problem here because I need to lower the brake pedal but ran out of adjustment.
So remove the clevis and get some protection in place and the Dremel to the rescue, shortening the push rod. Its held in by a circlip according to the parts manual and removing it to the bench may entail bigger issues like the piston coming out, so decided to do this in situ. Worked fine.
BergDonk screwed with this post 07-04-2013 at 01:58 AM
Old 07-04-2013, 01:57 AM   #14
BergDonk OP
BergDonk's Avatar
Oddometer: 3,721
Panniers
Time to fit the factory panniers that were part of the package.
Lay all the bits out and decide I didn't like the Torx bolts, especially having just 2 of them as security ones. Normal bolts to the rescue.
All fitted up. It took a while to figure out the locking mechanism. When I found the red plastic bit on the front of the pannier it started to make sense Some loctite on the lock assemblies and should be OK. Not the beefiest of panniers, but hopefully they'll do the job for the time being.
Old 07-04-2013, 03:36 PM   #15
GrahamD
GrahamD's Avatar
Oddometer: 5,366
Good one mate.
Locktite on the locks is a good idea. As far as the panniers go, lots of people like them once they have figured the locks need special attention.
So have you ridden it much yet?
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is online now   Reply With Quote
Times are GMT -7.   It's 04:04 AM.
