Go Back   ADVrider > Riding > Mapping & Navigation
Old 06-09-2009, 09:39 PM   #1
Yellow Pig OP
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,630
Thumbs down Garmin 276C Shuts Down?!?!
I have my Garmin 276C mounted on a ram mounts, its hard wired and also runs on a battery at the same time.
Recently the unit has started shutting down on me during my ride. I'm convinced it's from the jarring and vibrations during offroading, but w/ both the battery and the hard wire I don't think it's loosing power.
Any ideas?
Anyway to shock proof the unit by opening it up and heat gluing components?
Thanks Dan
Old 06-10-2009, 03:07 AM   #2
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,521
Most likely. Check your settings on what to do when it loses external power. It may be set to shut down. You could also have dirty or loose battery connections.
You can open it up and silicone things, but I'd first work on the external possibilities.
dunno.....
Old 06-10-2009, 03:54 AM   #3
ebbo
ebbo's Avatar
Oddometer: 150
I've had mine crash and reboot it's self during a trip a couple of times, my mates Garmin (but different model) did exactly the same thing at the same time & place so I suspect a mapping/routing error.
Martin Ebdon, England,
R1200RT replaced by MX5
ebbo is offline   Reply With Quote
Old 06-10-2009, 08:02 AM   #4
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,630
I've got it set up to stay ON when external power fails so between the hattery and the hard wire it should not loosie power. Its not arouting thing snce I was not routing, just tracking my progress.
This is why I think it's and internal short, what elso should I look for?
Old 06-10-2009, 08:26 AM   #5
rider1150gsadv
Fl Keys Fishing Guide
rider1150gsadv's Avatar
Oddometer: 5,914
Internal battery, if there is one, could be the culprit. It happened with my Furuno on my boat...Just some thoughts....
rider1150gsadv is offline   Reply With Quote
Old 06-11-2009, 03:11 AM   #6
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,521
The internal battery is soldered in, and welded to the lugs - but, I guess if the solder joint came open on the battery to the board, it could do something.
Most problems with the units shutting off have been external battery related, but you never know.
If you have someone you could swap external batteries with, I'd try that on a route when you know the thing will crash and see if it does anything.
Opening up the unit is not hard, nor is replacing the internal battery. I'd give a look just for giggles. Look for the thread on replacing the internal battery for excellent instructins. You can also silicone other stuff while you are in there.
dunno.....
Old 06-11-2009, 12:03 PM   #7
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,630
If the unit is hard wired the battery loosing contact would matter.
Old 06-14-2009, 08:32 PM   #8
munchmeister
Grow'd Up Mini Trail
munchmeister's Avatar
Oddometer: 1,423
I agree. That was the problem with my 376C. Got a new battery, no problems since (and my problems were similar to yours).
HTH
Munchmeister
2002 R1150GS - It's not about the knockdown, it's about the recovery.
munchmeister is offline   Reply With Quote
Old 06-17-2009, 07:48 AM   #9
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,630
Checked internal battery and it was fine. 3.3V, so that's not the problem. Any more ideas?
Old 06-20-2009, 11:04 AM   #10
marco polo
marco polo's Avatar
Oddometer: 643
My 276C was crashing then re-starting. After trying several things suggested by Garmin Tech Support, I had to send it in for service -- meaning I paid $200CDN to get a refurbished unit back (mine was outside the warranty period).
marco polo is offline   Reply With Quote
Old 06-22-2009, 08:00 PM   #11
Yellow Pig OP
Yellow Pig's Avatar
Oddometer: 7,630
Update: So while I was in there checking the voltage of the internal battery I siliconed pretty much everything I could. Well this weekend I did a 500 mile offroad ride full of rocks and jumps and the Garmin never once shut down. So I'm assuming the silicone dd it's job.
Now all I need is a new antenna, the old one fell off half way through the ride.
Times are GMT -7.   It's 07:45 PM.
