07-03-2009, 02:39 AM
#1 |
so little time
Oddometer: 1,824
gps
Magellan triton 400 thoughts please are they the go?
nothing sweet about me |
07-03-2009, 03:59 AM
#2 | |
scrub basher
Oddometer: 979
can even use it on the boat;http://www.gpsoz.com.au/magellan/mag...blunav_xl3.htm sweet huh !!! |
07-03-2009, 04:05 AM
#3 |
so little time
Oddometer: 1,824
you got a boat??
i got the gps now trying to work out how to use it!
07-03-2009, 04:35 AM
#4 | |
scrub basher
Oddometer: 979
nah, semi retired but good friends of ya mayor, can borrow his ![]() know a copper up there as well (x tuna farm diver) hey remember the bands xamount or the resinators 1985 'ish. doing lakes to childra rock hole around aug. u keen ???
07-03-2009, 06:10 PM
#5 | |
I did that.
Oddometer: 6,433
BurnieM should be able to be more specific, and this should be moved to the GPS forum. |
07-03-2009, 08:14 PM
#6 |
Tightass KLR rider
Oddometer: 799
I have one and I’m not a huge fan of it. The original firmware wasn't the easiest to use, the recent firmware upgrade makes it better, but still not 100% happy with it. Little things like not being able to simply jump to the next waypoint when following a route and not many online resources supporting the Magellan units or being easily compatible with the Vantage Point PC software.
I play around Geocaching and they only support Garmin, there were a few other sites that I have visited that don’t support the Magellan format either. Magellan guarded their operating system too well, so no one else bothered making anything compatible with them. The unit works well, just not as well as I had hoped. It was useless with the supplied map too. I got a copy of OliverK shonky maps from GPSOZ that work well, They are derived from the Auslig 1:50 000maps and had all the tracks marked that I rode on out west. Here is my mount, GPS held on with velcro and it doesn't go anywhere. For power I use the USB lead that comes with the unit and plug it into a 12V-USB adaptor I stole from my daughter's DS. hoyks screwed with this post 07-03-2009 at 08:22 PM |
07-03-2009, 08:45 PM
#7 |
tEAM iDIOT
Magellan is the Apple of the GPS world
This is not a link Note to self. When fueling up at Windorah do NOT say "I'll see you later", "I had better get a hop along" or "See you around". You will just look like a prick in front of the locals and feel like a dick.
07-03-2009, 11:10 PM
#8 | |
so little time
Oddometer: 1,824
07-04-2009, 01:50 AM
#9 |
Nipple boy
Oddometer: 4,101
Have a look at the Garmin GPSmap 60Cx
07-04-2009, 02:25 AM
#10 | |
tEAM iDIOT
07-04-2009, 02:50 AM
#11 |
so little time
Oddometer: 1,824
thanks for the replies ,i have the triton 400 already (birthday present)just askin about the is all!
07-04-2009, 03:54 AM
#12 | |
scrub basher
Oddometer: 979
bugga, aug is just a test run for anne beadell hwy, maybe in early sept ?
07-05-2009, 01:44 AM
#13 |
Tightass KLR rider
Oddometer: 799
Have you had a look at the forum, there seems to be a forum for everything these days, it addressed a few of my problems;
http://www.tritonforum.com/forum/ I loaded the latest version of VantagePoint (VP) the other week and had real issues. VP would continually die whenever I tried to modify any files, and that was if I could get it to run at all. The fix is to run the update file which will uninstall most of the files. Then you have to manually remove all VP or Magellan files you can find on the computer. I had to do it twice as each time I found more. Once that was done, reinstall VP and it should run OK, I then transfered my custom maps back across from the GPS. hoyks screwed with this post 07-10-2009 at 01:45 AM |
