Old 07-31-2009, 08:40 AM   #91
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
The rear upper mount plate made and mounted..
The BMW needs a subframe and here`s a view of the right hand side..
A close up of one of the mounting lugs of the subframe..
A bit of work is needed to "true" up the case lug..
7/16" bolt works well here..
Having spoken to me a few times now, Phyllis ( ) decided his normal crash test dummy wasn`t needed as a worthy replacement had been found..
"Nev was right ." - Phil_Fong
"Troy was wrong!" - DRjoe
nevgriff64 is offline   Reply With Quote
Old 07-31-2009, 08:52 AM   #92
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
The subframe in progress.. Note the two extra holes in the mounting block..
On one of my visits, I was asked to sit on the bike so Phyllis ( ) could see where my legs sat comfortably.. The green tape was used to trace the outline of my legs so nothing was mounted in those spaces..
A view of the oil filter and crankcase lug..
With the subframe nearing completion, it was now time to turn the attention to the upper mounts..
The two fasteners that will be used to anchor the forward upper mount..
Old 07-31-2009, 08:59 AM   #93
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
Another angle of the 25 mm Aluminium block..
and again from below..
The lower attach arms begin to form..
Inside and outside diameters machined.. Bolt support tubes formed ( drilled )..
Needing a bit more room..
( Note straight edge )
Old 07-31-2009, 09:12 AM   #94
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
Clamps now in place on sidecar frame..
Setting toe in, lead and track..
note tape on muffler..
still measuring..
AND AGAIN!!
Sidecar arms in progress and coming along nicely..
As reported earlier, the sidecar was purchased from a vehicle involved in an accident so anything that didn`t quite look right needed close up inspections..
Forward inboard corner of sidecar frame..
A little rusty, is that a crack??
Close up of suspect area..
Arms and clamps now well under way..
Old 07-31-2009, 09:20 AM   #95
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
Lug almost off..
Corner brace removed.. ( lower arms in background )
Both bracket and lug now removed..
How much of the overhang should be cut off??
Should be safe to cut almost all of it..
Now, how to plug the end??
Dog giving second opinion..
and coming up with the better idea..
Old 07-31-2009, 09:32 AM   #96
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
Setting up again.. ( note dead computer )
Phyllis ( ) just loves computers and more than happy to use it the way it was designed..
Forward upper mount block and rod end..
Rolling on 3 wheels for the very fist time..
View over sidecar wheel..
View from behind..
General view of mounts..
Old 07-31-2009, 09:35 AM   #97
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
More to come tomorrow..
Old 07-31-2009, 09:57 AM   #98
koifarm
Twas ever thus!
koifarm's Avatar
Oddometer: 1,800
Good Job!
I am totally impressed by the work you gents are doing. And for posting the process, I thank you!
It follows the entire sequence of designing and mounting a custom sub-frame, to modifying the frame and creating new mounts for that. Not only that but following the set-up process to the recommended specifications for sidecar mounting. The work is first rate from what I can see and is well thought out, even the dog had good input, and looks structurally sound plus 10.
As a relative newbie, it is a tremendous lesson in how to set up a car frame properly and in a workmanship like manner with lots of creativity thrown in for good measure.
I'm looking forward to seeing the rig when it's finished.
Again, many thanks for allowing us to see the process on the forum here, I know it takes much time to snap pictures which suspends work for a bit each time, but it's invaluable for others to be able to see exactly how a superb rig is put together from all the bits.
koifarm
koifarm is offline   Reply With Quote
Old 07-31-2009, 03:31 PM   #99
farawayman
Oddometer: 549
Looking good Nev and Phil, cant wait to see it on the road. Will it be ready monday? I'm happy to give it a test run.
So many roads . . .
So little time!
If I'm in here, I'm suffering from PMS
(Parked Motorcycle Syndrome)
farawayman is offline   Reply With Quote
Old 07-31-2009, 06:08 PM   #100
johno
johno's Avatar
Oddometer: 2,911
Come on Nev, its 10am, and no pics Lift your game mate
Looking good, soon out there wobbling all over the road
Down in the land of the confused(mainly me)
johno is offline   Reply With Quote
Old 07-31-2009, 06:09 PM   #101
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,017
Ha! join the queue! I offered my services for a test ride and that was quickly knocked on the head!
Good luck with the test ride Nev.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 08-01-2009, 01:26 PM   #102
Shmerel
Oddometer: 11,152
Thumb bravo!!!!
magnificent work there, nev. i also appreciate your photography.
i'm in the queue for a ride ...
Shmerel is offline   Reply With Quote
Old 08-01-2009, 11:42 PM   #103
Racketeer
Must escape......
Racketeer's Avatar
Location: Melbourne near the sshitty...I mean the City!!
Oddometer: 882
Hey Dave!!
You could always threaten to Bann him for a while if he doesn't give you a test ride????
He wants to give me a ride, but in the sidey!! No chance in hell of me getting in there!!
Racketeer is offline   Reply With Quote
Old 08-02-2009, 04:09 AM   #104
TouringDave
Tri Moto Veritas
Oddometer: 7,017
Originally Posted by Racketeer
Hey Dave!!
No, I think I'll just go watch him ride it. That should be amusing.
K7 Strom with Chair
Old 08-02-2009, 06:46 AM   #105
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,898
koifarm
Hi koifarm..
Glad your enjoying the build mate and thanks for those kind words..
More to come..
Times are GMT -7.   It's 06:48 PM.
