Go Back   ADVrider > Bikes > Battle Scooters
Old 12-03-2009, 01:36 AM   #1
monkeywaythere OP
Scooter explorer
monkeywaythere's Avatar
Oddometer: 90
battery trouble for adv
Question to ask about batteries. I have a 12v 4amp battery and wanting to put another battery in parallel so it will still be 12 volts but bigger amps. Now the hard bit if for example my magneto puts out 4 amp and I have a capacity of 12 volts 14amp will this over load the magneto/charge system?
Cheers stuart
Its on my scooter but need the extra battery for a adv ride Im doing.
getting ready to explore a new world!
monkeywaythere is offline   Reply With Quote
Old 12-03-2009, 02:04 PM   #2
Lone Rider
Registered User
Oddometer: 25,130
You may want to post this in the Scooter Forum.
Lone Rider is offline   Reply With Quote
Old 12-03-2009, 07:47 PM   #3
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 5,119
monkeywaythere,
What is your load in amps? If you charging system only puts out 4 amps and your load is greater that 4 amps then your batteries will discharge.
Of course if both your batteries are fully charged at the start of your ride then you will have power for a longer time than with just your smaller battery.
Vince @ SWFL or WNC
2015 Ural cT 2012 Dong Fang DF250RTB-A
Bar None is offline   Reply With Quote
Old 12-03-2009, 11:53 PM   #4
monkeywaythere OP
Scooter explorer
Oddometer: 90
Right done some more research and decided that the risk to the genarator/magneto/reg rec is to much so just going to invest in one good battery and take care of it!! might even put a charge meter on the scoot?
The scooter is geared(or will be with in the next week or two) for long distance touring. By long distance i mean 3000+ miles in 8 days in mid next year and in feb 500+miles in 2 days.
Old 12-04-2009, 02:31 AM   #5
Coopdway
Curiouser
Coopdway's Avatar
Oddometer: 711
I thought about a variation of this for my Helix with its trunk in back.
My idea was to have an additional, smaller (space considerations) 12v to use as a total loss system, isolated from the normal charging circuit. Use would be to power various campground electronics.
The next day, after the primary battery is charged, 100 miles into the day, parallel the TL batt and get it re-charged.
In a nutshell, extra capacity while stopped rather than while riding. Never followed through with the project but the space is there, wiring diagram, connectors, etc. all fit perfectly together in my head.
Doug
Frontenac, MN
Chauncey likes to watch.......I like to ride
Coop's Corner
Coopdway is offline   Reply With Quote
Old 12-04-2009, 08:00 AM   #6
approachbears
250cc is 50cc too many
Oddometer: 917
Why not get a battery isolator like they use on RV's and other vehicles with 2 batteries?
approachbears is offline   Reply With Quote
Old 12-04-2009, 08:36 AM   #7
where2next?
Map guy
Oddometer: 221
the isolated battery is the way to go for powering additional loads. think of your charging system as a pump, your battery as a tank, and the load (stuff you're running) as the outflow. you can get a bigger battery (tank) and it won't affect your charging system, however, you can never get more out (continuously) than your charging system puts in. a second battery will provide additional power for a short period of time, hence why the isolator is a good idea... you can do this easily with a HD switch or maybe with a switch and solenoid... I would think that over time the additional load will wear out your stator faster, but not catastrophically. there's no such thing as a free lunch and in physics there is no free power....
where2next? is offline   Reply With Quote
Old 12-04-2009, 06:22 PM   #8
rdwalker
Oddometer: 2,545
Originally Posted by monkeywaythere
....Its on my scooter but need the extra battery for a adv ride I’m doing.
Stuart, are you talking about a real scooter (like a Vespa) - or is it some "Britishism" I am missing?
If it is a "real" scooter, my hat's off to you! I've been planning a scooter loop of Europe in my college days, many decades ago - ultimately went by car - thus I have a really soft spot for your adventure.
Good for you! (And post some pics).
Here is a suggestion: I saw somewhere, either on ADVrider or on BMWLT.com, a setup with a small solar panel mounted on the top case of the bike. It charged up the battery (batteries?), so that the rider could power up his electronics.
As I remember, it was not big at all - but sufficient for the use.
As others suggested in previous posts, the extra batteries will not overpower the magneto - if charged - but it is the accessories that will kill you. If your power draw exceeds what the magneto puts out, you need a secondary source of power. Solar may be it. Search the forums for this solution. If I find something myself, I'll post here.
Good luck on your adventure!
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker screwed with this post 12-06-2009 at 09:03 AM
rdwalker is offline   Reply With Quote
Old 12-04-2009, 11:44 PM   #9
monkeywaythere OP
Scooter explorer
Oddometer: 90
[quote=rdwalker]Stuart, are you talking about a real scooter (like a Vespa) - or is it some "Britishism" I am missing?
Its a 50cc pug speedfight so its a twist and go machine we brits still call them scooter.
thanks for the idea about solor i hadn't thought of that and thionk that will now be the route. cheers.
as for the pic's am not to good at up loading but goig to try and do a ride report thingy for the first trip wales and back in 2 days (500+miles) and if i can do that then a ride report for the longer one should be easy.
thanks stuart
Times are GMT -7.   It's 10:33 PM.
