Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 02-28-2010, 06:26 PM   #1
Drizzt OP
Ranger
Drizzt's Avatar
Oddometer: 1,037
Tucson Area Tool Exchange
This thread is for the sharing of tools (especially specialized ones).
If you have tools and or facilities, and would be willing to share either, please post up! It would be useful if you posted the following information
A)A list of tools that you have (an example would be a 30mm socket, or tire irons)
B)A list of facilities that you have (an example would be a tire changing machine or a bike lift)
C)A list of skills that you would be willing to share (such as how to change a tire by hand, or how to do an oil change)
D)Your general location. It doesn't have to be an address, but the more specific the better (Broadway and Kolb is a lot better then "Tucson")
If you want a tool/service, just look through the thread and PM a person that has it, and you can make arrangements.
I would like to keep the thread just to a listing, so you can find information quickly rather then sifting through 3 pages of "does anybody have this?!"
It would be a general courtesy to return the tools at least in the same cleanliness, if not cleaner. Please don't return tools all greasy and oily, otherwise people aren't going to want to loan out their tools to anybody.
So, if you have tools, please post!
2000 Suzuki DR-Z400S
And what is good, Phaedrus, and what is not good- Need we ask anyone to tell us these things? Pirsig
Drizzt is offline   Reply With Quote
Old 02-28-2010, 06:37 PM   #2
Drizzt OP
Ranger
Drizzt's Avatar
Oddometer: 1,037
I'll begin
A) Common tools (just use this to summarize the following items-screw drivers, common sized wrenches, common sized sockets, hammers, crescent wrenches, pliers, ect...).
A variety of oversize sockets and wrenches, mostly standard though
Really long extensions
Torque wrenches (Heavy, begin at 50 pounds)
Punches and Files
Tire Irons and Valve Core Removers
B)A heavy duty car jack
Air compressor (~30 gallons) with air tools
Wire Welding Machine (for iron and steel)
A concrete slab for working on things (no cover)
C)Tire change (by hand)
Oil Change
Valve Check
Cleaning Air filter
Other light duty maintence
D)3 Miles from Houghton and Sahuarita road, Corona De Tucson
Old 02-28-2010, 06:50 PM   #3
ravenranger
rave
ravenranger's Avatar
Oddometer: 1,538
dirt bike stand
motorcycle jack
various hand tools (sockets, drives, etc.)
tie down straps
1989 NX250
2006 ST1300A
2006 Aprilia Caponord
ravenranger is offline   Reply With Quote
Old 02-28-2010, 07:03 PM   #4
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
All manner of chains, straps, hitch carrier and a truck(its a tool just like a big hammer)
Lots of extensions and hand tools, metric and standard, 1/4 3/8 1/2
tons of wrenches. electrical tools, drills, hammers, pliers, etc.
cut off wheel, d/a sander, die grinder, paint gun(no air compressor though)
bike stand, tire irons and such.
specialized tools: xr swingarm sockets
inside garage space for bikes
I'm in southeast tucson, I know upholstery, welding, fabrication, custom bodywork, and some other stuff.
I'm happy to help.
lstzephyr screwed with this post 02-28-2010 at 07:11 PM
lstzephyr is offline   Reply With Quote
Old 03-02-2010, 07:55 AM   #5
685
Scarred Adventurer
685's Avatar
Oddometer: 1,001
Thumb
I am located at Pantano and 5th, Far Horizons Tucson Village (a blue hair RV park.) Covered, concrete carport. Until late April (when most of the blue hairs go home) working on more than one bike at a time is no-go. Summer rules are a lot looser than winter ones.
Tools, all the usual suspects sockets, ratchets, breaker bars (with a cheater pipe,) a real good torque wrench. Hammers. 5hp compressor, pneumatic tools (ratchet, impact, drill, cutoff wheels, nailers, a coupla spray guns w/regulator.) Some sockets that are larger than the usual candidates--30 mm deep wall, impact socket for GM hub nuts, 1 1/8, 1 1/4 sockets. 1/4 1/2 3/8 drive sockets, extensions, wobblers, and drives.
Got a broomstick for taking fork legs apart, necessary to keep things form spinning inside the leg.
M/cycle jack, tire spoons, valve remover tool. Many automotive jacks (bottle and floor jacks.) Cheep multi meter from HF, digital & dial micrometers, and a mic for measuring runout (but no attachments or frames.) Some feeler gauges, wire gauges for spark plugs.
Hobart handler MIG welder (currently even have gas.) Grinders, pedestal grinder one side is stone, the other is a wire wheel. 1/2 in drive drill. Drill press (fairly good sized) various sized drills of various qualities. Ox/acetylene torch setup with small tanks (no gas, tho,) kinda the HVAC/Roofer special. Anyone who can afford to fill the bottles can borrow it.
I have manuals for the 08 & later KLR, DR 650 (95 & earllier.) If I can ever get into my old hard drive, I have manuals for later DR 650 and earlier KLR.
I have a single bike, small, very light trailer. The trailer lights work most of the time. & a Chevy Lumina with a trailer hitch.
In my 'useless' tool box, a valve spring compressor, piston ring compressor, some larger hones, brake spring tool, induction timing light w/variable advance. McPherson strut spring compressors. Easy outs. Some helicoil stuff. An air pop riveter. An oversized pop riveter. Cheep taps and dies from HF. A/C vacuum pump (electric.)
The usual rules about cleaning up, catching fluids, and recycling parts/fluids apply.
To post images. Go to http://postimage.org/ and do what they require. Copy it to clipboard (there's a box.) Paste the link (right click on the mouse, then left click 'Paste'.) Voila you got an image!
685 is offline   Reply With Quote
Old 03-02-2010, 04:00 PM   #6
goodtimes
local bum
Oddometer: 930
Big-ass hammer, + various other beating devices.
And a few other things too.
Price is soon forgotten, quality is not.
goodtimes is offline   Reply With Quote
Old 03-02-2010, 06:36 PM   #7
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,731
I've got bicycle tools (and 20+ years of know-how)
Not so much in the MC specific stuff cept for 1150 and 1200 boxer oil filter wrenches
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 03-04-2010, 12:33 PM   #8
TucsonBill
Tucson Tiger
TucsonBill's Avatar
Oddometer: 120
I have a shed full of tools with which I've built/maintained motorcycles, cars, boats, airplanes, and regular around-home stuff. I also have a motorcycle lift. Tanque Verde/ Sabino Canyon part of town.
2001 Triumph Tiger, Jack
1999 Triumph Tiger, Maggie
1989 Honda NX-650, Geena
1968 Honda CT-90, Edith
TucsonBill is offline   Reply With Quote
Old 06-08-2010, 04:25 PM   #9
685
Scarred Adventurer
685's Avatar
Oddometer: 1,001
I need to do a brake job on my ancient and decrepit motor home. Does anyone have a good 1/2 drive air impact I can borrow?
Old 07-10-2010, 10:20 PM   #10
inire
Browncoat symp
inire's Avatar
Oddometer: 412
Toolz
Electric impact
Tapered alum damper-rod holder
Flywheel puller(s) for DR650
Garage floor
Ironwood & Lloyd Bush
1982 AR80 (The Neverending Story)/ZX750A3 "99 Problems"/VTR250
inire is offline   Reply With Quote
Old 06-09-2011, 11:36 PM   #11
chuggins143
chuggins143's Avatar
Oddometer: 130
All the standard junk/hand tools... also have welders, plasma cutter, and general know how to hack junk together!
..and for the KLR folks, I have the Doo Tools!
Chad
09 KLR 650, blue... Done the Doo!, Thermo-bobed!, LED driving lights, aux fuse box, HID high beam, gel battery, custom racks, tool tube, de-Californicated it, moved main fuses to side cover, relocated plate, PVC mod, Hurricane mod, bypassed the side stand switch...
RIP - 95 Honda VFR750 (the most vulgar shade of yellow I could find in the book!)
chuggins143 is offline   Reply With Quote
Old 09-16-2011, 04:35 PM   #12
Radioman
Moto rider
Radioman's Avatar
Oddometer: 5,160
Tucson Area. Tire machine needed
Anyone in Tucson have a tire machine that we could use as we ride through to Mexico.
We will be arriving September 25 into North Tucson, and will need to one tire on a KTM 990 and maybe 2 on F800 GS.
Sunday Late or Monday . Any help would be appreciated!
Thanks,
Mark
Chapter 3 of my life...... with Faith, Hope and Courage!
Ride of my Lifetime...... Thread started 5/11/2011 http://advrider.com/forums/showthrea...0#post15950430
Radioman is offline   Reply With Quote
Old 09-16-2011, 10:48 PM   #13
Drizzt OP
Ranger
Drizzt's Avatar
Oddometer: 1,037
Thanks,
Mark
Try posting in the TABB, I'm sure that somebody will help you put on some tires. here's the link:
http://advrider.com/forums/showthrea...25691&page=799
Otherwise if you want a machine, probably just take it to a shop, you could try zmw or onanymoto, I'm sure they'll have tires and they have a tire machine.
Old 09-17-2011, 07:37 AM   #14
Radioman
Moto rider
Radioman's Avatar
Oddometer: 5,160
THANKS will post there. Have the tires we are using.
Mark
Old 03-26-2012, 08:35 AM   #15
Greenstreak-750
Greenstreak-750's Avatar
Oddometer: 12
I have lots of tools. Mostly METRIC ............ I used to work in a bike shop. I have fork seal drivers, carb sync'ing gauges. Air tools and a big compressor. I am not big on loaning out tools, but would rather help you fix it myself. A friend in need is a friend in deed.
Greenstreak-750 is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
