Old 03-31-2010, 04:38 AM   #1
By-tor OP
remember 6/6/44
By-tor's Avatar
Oddometer: 257
Klr 650 Battery
What battery should I get that will fit properly? Bike Bandit has some for around 85.00.
By-tor is offline   Reply With Quote
Old 03-31-2010, 05:54 AM   #2
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 707
I went with the Yuasa sealed. As for the size... bike bandit should be able to get you the right size. The web site looks like it gives you all the options that fit.
http://www.bikebandit.com/2006-kawas...6?mg=43545&t=1
The link is from a Canadian site, but maybe the part numbers will work.
http://dualsportplus.com/klr650/batt...0_battery.html
Damn I wish all roads were dirt. 2011 White F800GS, 31,000 km's
Toronto to Maine and back, Toronto to Boston -The Long way, To the Dragon, 2days TCAT
tofire409 is offline   Reply With Quote
Old 03-31-2010, 06:44 AM   #3
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,774
STOP!
This is probably the best motorcycle battery I have ever bought. Cranks the engine faster and holds a charge longer than any others I've tried. Here is the right one for the KLR. $66.95 with free shipping.
DEKA PowerSport Battery (ETX15L)
http://www.tristatebattery.com/produ...roducts_id=977
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 03-31-2010, 06:56 AM   #4
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,998
I bought my KLR in February, 2007, and one of the first things I did was put in one of these. It's been fantastic. You'll have to do some fiddling to get it to fit, but it's worth it.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al screwed with this post 12-06-2010 at 09:49 PM
Bigger Al is offline   Reply With Quote
Old 03-31-2010, 08:42 AM   #5
JSPEED
650 Strommer
JSPEED's Avatar
Oddometer: 106
Originally Posted by tbirdsp
STOP!
+1
The Deka ETX15L is the way to go.
Fits perfectly, it's an AGM and it's affordable.
Plus it has the best terminals I've ever seen.
___________________________________________
2012 V-Strom DL650AEXPL2
www.dualsport.ca
http://www.rideatlantic.ca/
JSPEED is offline   Reply With Quote
Old 03-31-2010, 11:43 AM   #6
CA Stu
CA Stu's Avatar
Oddometer: 48,048
I buy the Walmart specials, they are $34.99 out the door and I get at least 3 years reliable service out of them with maybe one or two fluid level checks (if I remember to check at all ).
CA Stu
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 03-31-2010, 12:38 PM   #7
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,774
CA Stu
No way would I use a regular lead/acid battery again. I cooked my OEM battery dry *twice* in 15 days on the Continental Divide ride The second time it was a goner (luckily it died for good in my driveway).
Get the Deka AGM and be done with it
Mike S.
AMA MSTA
Old 03-31-2010, 12:42 PM   #8
Dagofast
Full giggety ahead.
Dagofast's Avatar
Oddometer: 1,789
+1 with Bigger Al. My Odyssey has been in my A14 since 2005. Still going strong. (knocks on wood) And that is pretty rare for a battery in AZ.
Dagofast is online now   Reply With Quote
Old 03-31-2010, 12:50 PM   #9
CA Stu
CA Stu's Avatar
Oddometer: 48,048
How the hell did you manage that?
CA Stu
Old 03-31-2010, 12:57 PM   #10
bman
bman's Avatar
Oddometer: 508
On long rides my stock lead acid battery cooked off fluid regularly.
Just had to keep an eye on it. One extra pain.
AGM will solve that.
bman is offline   Reply With Quote
Old 03-31-2010, 12:59 PM   #11
CA Stu
CA Stu's Avatar
Oddometer: 48,048
Funny, on the 2 KLRs I have owned, I have never had a problem. Yet.
Did you modify the electrical system somehow? Add heated grips/ clothing / lights / something like that?
Thansk
CA Stu
Old 03-31-2010, 01:13 PM   #12
By-tor OP
remember 6/6/44
By-tor's Avatar
Oddometer: 257
I kind of shy away from the fluid batteries. I am a little anal about getting battery acid on things. When the temp. here gets into the upper 90's I woory about things. I might look into the Deka.
Old 03-31-2010, 01:20 PM   #13
ROYAL COACHMAN
ROYAL COACHMAN's Avatar
Oddometer: 938
I went to Batteries Plus and got the Permaseal AGM Extreme.
$80.00 xta14ahl-bs
I noticed that the bike know starts with more "zing" in the starter
So far so good!
2009 KLR 685
ROYAL COACHMAN is offline   Reply With Quote
Old 03-31-2010, 01:29 PM   #14
kdxkawboy
Mr. NVKLRGirl
kdxkawboy's Avatar
Oddometer: 2,631
+2
The wife has an Odyssey in her KLR and I am completely impressed. No mater how long the bike has been sitting it always cranks over and it has been in her bike going on 6 years. When the current old tech battery dies in mine I will put an Odyssey in my bike as well.
When the going gets weird, the weird turn pro
kdxkawboy is offline   Reply With Quote
Old 03-31-2010, 02:05 PM   #15
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,774
CA Stu
Well - riding consecutive long days at high temps (July), low humidity (NM desert), high rpm (14 t sprocket on front). I had to refill it once in the middle of the trip then it was dry again when I got home.
Stock electrical system with no extras except a GPS ( hardly any draw).
Mike S.
AMA MSTA
Times are GMT -7.   It's 10:21 PM.
