Old 04-12-2010, 05:39 AM   #1
DeeGee OP
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,884
What Did You Do To Your KTM Today?
Share your farkles, mods, tyre changes, breaks and mends here
I've just got back from a ride out to Ripon to get a repair kit for the clutch master cylinder. I'm going to have a go at fitting it, I've searched the O.C. to no avail to actually fitting the kit, loads of inmates posting the fault, but no answers
To the garage
DeeGee is offline   Reply With Quote
Old 04-12-2010, 08:01 AM   #2
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,836
I'd like to see your install as its on my list of things to do.
Old 04-12-2010, 08:52 AM   #3
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,480
Changing the rubber bits in a master cylinder isn't usually too complicated.
If it's anything like the average brake master cylinder, you remove the lever, remove a circlip, and pull the gubbins out, catching the fluid that'll spill. Then replace the rubber bits on the central shaft, replace it, replace the circlip, refill with fluid and bleed.
Have fun fettling :)
Not today, but last week I welded up yet another hole in the 2-1 section of the exhaust, brushed all the rust and winter cack off it, sprayed it black and baked it in the oven for an hour to cure the paint.
Tonight I am going to replace the reflector in the headlight as the silver coating seems to have burnt off! HID lights too bright, perhaps?
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 04-12-2010, 08:56 AM   #4
Qwik
Adrenaline Addict
Oddometer: 6,894
I added Bar risers to mine. Brings the bars up 17 or 18 mm (Im not sure now) but made it much more comfortable for standing up and puts my arms at a more comfortable angle
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 04-12-2010, 08:58 AM   #5
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,512
Mine's toasted too. Are you going to crack the headlight case open? If so, how do you get the silicone bead to free without snapping the plastic tabs? Post a couple photos for me when you do PLEASE!!
Daniel
2005 KTM 950 Adventure S
2004 KTM 525 exc
2006 Beta Rev3
xdbx is offline   Reply With Quote
Old 04-12-2010, 09:57 AM   #6
DeeGee OP
DeeGee's Avatar
Oddometer: 1,884
I fitted the master cylinder seal kit. After a few problems with the clutch I suspected the slave had let go so I bought one of these babies in blue of course
Anyway after fitting it the dragging and not getting into neutral still persisted so I went and got the seal kit and fitted it today.
Leaking
I unbolted the mirror and took the lever out, then took the master cylinder off the bars, emptied the master cylinder and cleaned it out.
Removing the circlip was a total PIA, but managed to get it out. Be warned if you are going to carry out this minor overhaul be careful when you remove the circlip as the spring behind it will fire the seal out with a good squirt of oil
Replace the spring and seal, fasten everything back onto the bars and re-bleed the clutch.
Test ride tomorrow
Old 04-12-2010, 11:30 AM   #7
Denalidirt
High Plains Drifter
Denalidirt's Avatar
Oddometer: 930
winters over!!!
Well, today I checked the weather in Denali National Park, and decided it was going to be warm enough. So with a push of the button I soon heard the rumble from the fmf's and the 950 fired right up!!! It wont be long before its rolling down the highway.
Denalidirt is offline   Reply With Quote
Old 04-12-2010, 12:51 PM   #8
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,480
Sadly I haven't found a trick to do this the "nice way".
Basically I hacked off the plastic tabs with a knife, and hacked away at the silicone or whatever that black sealant stuff is. After a lot of hacking and digging, trying to avoid damaging the lens or the plastic case, I got it free.
To put it back together I just put the lens in place, held it with some tape, and ran a bead of normal silicone (bath sealant) round the groove.
That's how I repaired my headlight originally (I bought the bike with a cracked headlight reflector) - that was a few years ago and it held up fine. I've just replaced the reflector with one I blagged from another broken unit using the same method.
Sorry I didn't take photos of any of this process, but I took this one of the end result.
Old 04-12-2010, 01:05 PM   #9
FORRY
FORRY's Avatar
Oddometer: 94
Well I fitted my new rox risers to my 640 adv then went to change the front brake pads.Got a metal grinding noise still got 3mm of meat left on them seems the right hand disc is catching the top of edge of the caliper.Spent ages trying to work it out checking the spacers are fitted correctly gave up its beat me any ideas?
also read every thread about converting to high mudguard whata task clear as mud.
Day off tmw hopefully get something sorted then
Hello mouse long time no see think the last time was the cambrian rallye you were wrecking your partners ktm
My Photos
My Videos
FORRY is offline   Reply With Quote
Old 04-12-2010, 01:19 PM   #10
Peanuts
Peanuts's Avatar
Oddometer: 1,698
Put a washer under the head of the caliper screw cos they are too long rub on the disc..... thats the case on the 950 anyhow ;)
Peanuts is offline   Reply With Quote
Old 04-12-2010, 01:22 PM   #11
FORRY
FORRY's Avatar
Oddometer: 94
I'll give that a try tmw
My Photos
My Videos
Old 04-12-2010, 09:38 PM   #12
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,836
Over the past two weeks I've done a boatload of updates to the bike.
...but today all I did was stick these on. Took about 1.2 seconds each
Old 04-12-2010, 10:22 PM   #13
Qwik
Adrenaline Addict
Oddometer: 6,894
Put a new front tire on. Its no big deal because
I do it almost monthly
Old 04-13-2010, 01:59 AM   #14
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,170
- Did a oil change and Valve clearance check. All valves are still within spec. (not today)
- forgot to install the copper washers on drain plugs (both) and had to get some hot oil on my hands to put them back again.
- flushed and cleaned clutch slave, refilled & bled with motorex min oil
- lost the little grey cap on the slave bleed screw
- stripped the threads on the engine support (where bash plate screw goes in)
- forgot to clean the clutch oil jet
- took off the tank guards, rear rack and spare tubes in the front fairing (will be doing some more desert runs and want to reduce weight)
i've been getting closer and closer to her........... she only hits back occassionally
Building a KTM 690Exc - the ultimate dirt tourer
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally, 2012 KTM Adv990
Vicks is offline   Reply With Quote
Old 04-13-2010, 02:05 AM   #15
DeeGee OP
DeeGee's Avatar
Oddometer: 1,884
Good work Vicks sounds like my kinda spannering
Times are GMT -7.   It's 01:14 AM.
