Old 07-03-2010, 04:19 PM   #1
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,854
Flat tire prevention! TyreGuardian Puncture Protection System
What do all riders dread when out on the open road? Yup, getting a flat tire. I hate flat tires, especially getting a flat at speed! It's scary, to the point that I have installed a tire pressure monitor. But I've often wondered why automotive run flat tire technology hasn't been applied to motorcycle tires. So anything I can do to reduce my chance of having a flat is money well spent. I've come across this TyreGuardian puncture protection product and thought I'd try it and bring it to the attention of ADV inmates, as a valuable time saving and safety product. It works in both tubeless and tubed tires and best of all, it doesn't make a slimey mess of your wheels when the tire is removed. I've managed to pull out a nail out of my rear tubed tire and the product worked as intended. No air loss.
This product is easy to install and reasonably priced. TyreGuardian has a web site where you can calculate the amount of product to put in based upon your tire size. I used one bottle to fill both my front and rear tires. Maybe I put too much in there, more is better!
TyreGuardian creates a thin latex glove like lining for the inside of the tire. TyreGuardian protects from air loss from punctures up to ¼” in diameter for tubeless and 1/8” diameter punctures for tube type tires. It does not matter if the nail, screw or whatever stays in the puncture, TyreGuardian migrates to the puncture and seals it. It is not a one puncture product. TyreGuardian is good for the life of the tire. When I was pouring the product into my valve stem, I spilled a bit and the trick is to let it dry, then you can just peel off it, no mess, no fuss.
I've contacted the US distributor and he's agreed to provide ADV inmates with a discount. Info at the bottom of this post.
One of the nice things about TyreGuardian is it is not nasty or slimey and won’t make you or your mechanic unhappy when it is time for a new tire. You can pull it out of the tire in one piece if you like or leave it in place and it can be recycled with the tire.
Youtube demo:
It’s easy to install, takes 10 minutes or less. Take the weight off of the tire, deflate the tire by removing the valve core. The bottles come with a valve core remover and a short piece of tubing to put over the stem of the bottle and the tire stem. Squeeze in the correct amount, replace the valve core, air it up and take a 5 minute ride. It’s that easy. If you get some on your hands just use soap and water to clean up, or let it dry and peel off.
Youtube demo on a bike:
I've used one 250 ml bottle to do the front and rear, putting 150 ml in the rear and 75 ml in the front. In the pic below, it says you can treat 4 to 8 tires, maybe I put too much in my tires.
The retail price is $29.95 for a 250ml "Cycle" bottle which will treat 4 to 8 tires depending upon the size of the tires. The "calculator" on the www.tyreguardian.us site will calculate the amount required for the tire sizes.
I've contacted the US distributor and he's agreed to provide ADV inmates with a 10% discount, and as an introductory offer and for a limited time, Jim, the US distributor will offer ADV inmates an extra 15% for a total of 25% discount to the first 25 inmates to contact him via PM. His username is: Max Bialstock
I'm #1 on this discount list
I will sticky this thread in Vendors for a while to give inmates a chance to learn about this important safety product and I have asked Jim aka Max to respond to inmate questions in this thread.
Old 07-04-2010, 06:07 AM   #2
bradatlarge
Insha'Allah
bradatlarge's Avatar
Oddometer: 12,382
Same installation method on tubed tires?
This product will definitely be going in my friend's F650, as she has little knowledge of roadside repairs.
PM sent to Max.
You have been warned.
bradatlarge is offline   Reply With Quote
Old 07-04-2010, 06:28 AM   #3
GB OP
Mod Squad
GB's Avatar
Oddometer: 56,854
Yes, same install on tubed tires. The only caution is to squeeze the bottle slowly, or you may get some splash back if you squeeze too hard
Also, I think it's best to treat one tire, go for a ride to distribute it around the tire or tube, then do the second tire and then go for another spin.
Old 07-04-2010, 08:11 AM   #4
See-Double-You
See-Double-You's Avatar
Oddometer: 1,674
Nice catch GB.
I've been using the RideOn sealant for 2 years now. I pulled one brass staple from the rear tire earlier this summer. Don't know if it punctured the tube yet, but plan on replacing the tire in a month or so, so I'll be examining the area closely. Can say that there is no loss of pressure over time.
The TyreGuardian seems to last quite a bit longer (treat more tires for a similar cost). W/ the RideOn, each tire took something like 5 or 6oz, used two of the three 8oz bottles they sent me.
Will MAX be making an appearance here? I'm wondering what makes the TyreGuardian different from RideOn, RhinoTire, or other market names.
CW
" Suggest you stick with failure analysis of Pork Chops " - -Benesesso
See-Double-You is offline   Reply With Quote
Old 07-04-2010, 09:52 AM   #5
DirtFarmer
Has anyone seen my mother
DirtFarmer's Avatar
Oddometer: 2,697
I'm a little worried here...
Did Max want to sell you shares in his company?
Well, sister, the time has come for me to ride hard and fast. - Rooster Cogburn
DirtFarmer is offline   Reply With Quote
Old 07-04-2010, 10:10 AM   #6
Max Bialystock
Max Bialystock's Avatar
Oddometer: 193
Thanks Gadget Boy!
Hi and thanks for finding TyreGuardian Gadget Boy!
The inmate discount is 10% using Code "TGADV" at our website http://www.tyreguardian.us
This discount code is active and you can order product direct from the website.
As Gadget Boy said pm me and the first 25 inmates will receive a code for a 25% discount. I will start a thread in the vendor area with this information, but you don't have to wait for that the discount is available now.
Max Bialystock
"Flaunt it Baby! Flaunt it!"
Max Bialystock is offline   Reply With Quote
Old 07-04-2010, 10:11 AM   #7
Max Bialystock
Oddometer: 193
Originally Posted by See-Double-You
Nice catch GB.
Thanks for the question "See-Double-You". Let me tell you what TyreGuardian is not compared to the competition.
It isn't nasty or slimy. Soap and water removes it from your skin if you get some on you. In addition your mechanic (if you use one) won't have a fit when he breaks the tire down for replacement. Some of the competition really creates a "mess". What you see in the pictures Gadget Boy supplied tells the story.
TyreGuardian creates a "thin protective layer inside your tire". Tire balance is not affected and you have added very little unsprung weight.
The product is not flammable nor is it water soluble. TyreGuardians toxicity is very low, making it safe to handle during installation and requires no special equipment for installation. As Gadget Boy said it can be recycled with the tire.
Our product is not expensive. TyreGuardian requires Less product for puncture protection and is good for the life of the tire resulting in a very favorable return on your investment.
Thanks to Gadget Boy for finding our product and contacting me. The product is new to the U.S. although it was developed and has been successful in Australian and New Zealand under a different trade name for the last ten years.
Max Bialystock
Old 07-04-2010, 10:21 AM   #8
Max Bialystock
Oddometer: 193
DirtFarmer I believe you and I have the same taste in movies! John Wayne and Zero Mostel two of my favorite (sadly gone forever) actors.
I have always admired "Max's" coiffure and his way with the ladies! Although my "little old lady" keeps tight reins on me. Sadly I don't have an ownership position. If I did I wouldn't be selling shares. I would want them all for myself!
Max Bialystock
Max Bialystock screwed with this post 07-04-2010 at 10:47 AM
Old 07-04-2010, 10:46 AM   #9
Max Bialystock
Oddometer: 193
Nice catch GB.
I neglected to mention in my first reply about TyreGuardians ability to seal the puncture whether the staple, nail, screw or whatever is in or has been removed from the tire. TyreGuardian will stop air loss either way.
Max Bialystock
Old 07-04-2010, 10:58 PM   #10
Ninthlord
Cadmium Enriched
Ninthlord's Avatar
Oddometer: 283
I'll give it a try
I was thinking of this very topic while working on the bike earlier today. My only experience is with the goopy stuff in my ATV (LP) tyres.
-CG
Ninthlord is offline   Reply With Quote
Old 07-04-2010, 11:10 PM   #11
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,667
Cool!
You da man, Rick!
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 07-05-2010, 05:53 AM   #12
Max Bialystock
Oddometer: 193
Talking
Originally Posted by JeffD
I can see it working well in a tubless tire but seems like a tube tire would still have a tendency to split when punctured.
I wouldn't argue with your statement. TyreGuardian protects tubeless tires from up to 1/8" diameter punctures and 1/4" for tubeless tires.
I was at a bike shop a few weeks ago and one of the employees was running tubes in his tubeless tires. He asked me if TyreGuardian would create additional heat in the tire with this set up.
I said it would work and I didn't think much if any additional heat would be created but this didn't make sense to me.
Why run the tube? I asked. His response was he considered it extra protection from punctures. My suggestion was since TyreGuardian will protect tubeless tires up to 1/4" diameter punctures why would you reduce the protection by using a tube in the tire? I suggested he lose the tubes and use TyreGuardian in his tubeless tires.
Thanks for bringing the point up JeffD
Max Bialystock
Old 07-05-2010, 07:42 AM   #13
PARIAH
PARIAH's Avatar
Oddometer: 632
Looks like a good product. Well worth it for piece of mind.
Salamat
PARIAH is offline   Reply With Quote
Old 07-05-2010, 08:01 AM   #14
Max Bialystock
Oddometer: 193
It is and it certainly does contribute to my piece of mind. I have had a few very scary experiences and two of them were flats at speed on a motorcycle. Both flats resulting from rapid deflation due to nails picked up on the road.
The front tire's rapid deflation wasn't too bad, the pucker factor only went to 9.5 on the 10 scale and I was able to scrub speed with the rear brake until I could slowly edge off the highway. Cagers honking like mad at me due to it being rush hour.
When the rear tire went flat a few weeks later at approximately the same speed (65 - 70mph) and area on a local highway the pucker factor went immediately to 12.5 on the scale. The tire jumped the rim, locked the wheel up and I understood very quickly what riding a bucking bronc must feel like. How I kept the bike upright is still a mystery. I'm running TyreGuardian in everything I have with tires and it works very well.
Thanks,
Jim
Max Bialystock
Old 07-06-2010, 07:55 PM   #15
PARIAH
PARIAH's Avatar
Oddometer: 632
Thanks for the response, but my question... Is the puncture protection for tubeless 1/8" or 1/4"? I think your quote meant to have one size for tubed and the other for tubeless.
Salamat
Times are GMT -7.   It's 06:02 PM.
