07-11-2010, 07:53 AM
#31 |
Oddometer: 4,542
There have been a lot of other changes in newer bikes to help them run at the lower oil content. You should not run an older engine at these lean ratios.
An old 16 to one or 24 to one engine with sleeve bearings (i know they exist, I have seen one do not know brand) will do best at 24 to one,. If they are roller you can go to 32 to one or maybe 40 to one. I would not ever run an air cooled 2 stroke at more then 40 to one, on hot summer days I would go back to 32 to one. Water cooled can go less oil. The penalty for too much oil is less than the penalty for too little. My $.02 Rod |
07-12-2010, 04:54 PM
#32 |
Oddometer: 45
I have seen on this post a couple times about 'jetting the carb to the ratio'. Or 'changing the jetting' for a different ratio.
How do you figure your jet size for a leaner or richer mixture? And how does the temperature of the day come in to play as far as jetting or mixing? I'm running 64:1 and have been doing so for a couple years on my MAR, TY 350 and now a Penton Trials bike. 50/50 Cam2 and 93 Sunoco with Golden Spectro. The Penton is a 125 Sachs Iron Barrel. 2nd gear is too high for any trials sections I do, so I tend to wind the piss out of it in 1st. Problem is, the bike loads up a lot. To the point where unburned hideous muddy fuel blows out the exhaust and the connection between the header pipe and spark arrester. I can't imagine putting more oil in this thing. |
07-12-2010, 06:40 PM
#33 |
Oddometer: 45
aerone, here is some great advice and instruction for sealing a fiberglass tank: This is from Mike Winter. POG member.
07-12-2010, 10:25 PM
#34 | |
Trails Evangelist
Oddometer: 963
I hope to find the article I read a long time ago, that discussed the combustion events of a 2 stroke, (heck it could be the article posted in this very thread that I havent opened yet...) But jist of it was, that the air/fuel mixture (in 2strokes this includes the oil of course) is explained like a PERFECT "train" of measured sizes of air & Fuel that is no matter how you looked at it, exactly as long as the piston of any engine were thinking about in this example, is in diameter, that moves at varying rates into, through, and out of any cylinder, depending on many things, but for simplicity, just RPMS. And when perfect designed operation and power, combustion begins when the inlet door and exhaust door are closed while that perfect train is at the perfect position on the combustion chamber, IE when the WHOLE perfect train is squished and then ignited, giving the maximum power or torque that can be attained from the design. the article pointed out that Combinations of porting designs, Intakes, and carbs cant do anything perfectly for more than a "range" or window of RPMS of operating, the rest is at best a happy medium attained through years of research and development... Basically, in theory and practice, The trick to "tunning" the power from a 2 stroke had to do with the timing the location of the perfect train in the combustion part of the cycle Since nothing is perfect bare with me as I discuss "perfect" train combustion. when combustion happens before the whole train entered the combustion chamber or cylinder, all the way through to the condition of the train was more or less already mostly leaving the combustion chamber, the power is mapable in a big curve, from 0hp to spec HP and back down to something like half of spec. most of you have seen dyno slips, right? Not withstanding all the newer tricks employed with recent technology, that can help re map velocity changes of the train, powervalves, exhaust technology. We're still stuck with our perfect theory, that the fact that physics dictates that the changes in RPM would adjust the "time" that the train arrives in cylider, to be combusted. Any time the whole train (the perfect air fuel mixture for any combustion cycle) is not in cylinder, the engine is basically starving, from a little bit to a LOT. A lot causes damages like detonation to simple lack of cooling from fuels that wouldnt burn at "perfect" train position, etc. So as I definitely oversimplefied this, above from memory (sorry): just follow me through this, that a high revving (especially older engines) a given racing type engine would typically be biting small bites of the head off the train when idling. then as you increased the revs, until the "designed" rpm was met then more and more of the train was perfectly in place, to where the optimum revs design is met, then any increased revs, the train was passing the station as it got squished, so as revs went up, less and less of the trains tail section was being bit and combusted. So also note, since it is a problem no matter how you sliced it, each case other than perfect they improvise with carbeurators operating ranges, you know them as the idle circuit, mid range, and full throttle (main jet) cuircuits... So on this raceing type higher revving engine, maybe past 80% of WFO, where a race engine is operated at optimum, then these woud typically bite the tails off the train as it went by, (meaning fuel/air {dont forget the oil now}) is getting past the combustion chamber ===> unburned. This means in exhaust. what is worse is I dealt with potential, same with idle, toss fatter trains at the cylinder, a lot at idle attempting to makeup for the trains not making it perfectly into the station each cycle of the piston, this usually caused a non perfect but rich trains to hit at idle which then seemed to "load up" a raceing engine. This is what is giving you the "powerband" feeling as the air fuel charge is getting to where it is "close enough" to perfect but has NOT gone past perfect, the potential seemd to increase. And so then since the air/gas/oil mix is movin through everything much faster in high reving duty engines, usually less oils are deposited in areas as a reserve as compared to a low reving duty cycle of a trials bike. So most high rev bikes mix more oil in the gas. It is basically because the perfect little train is way off from idle up thru closer to designed RPM ranges (the engine is biting off the head of the train less and less as the rpms increas) But the engine probably gets decent amount of good trains past design, thrul WFO where it is biting the tails off the trains, since it is a high rev design the train past cylinder is less than 20% of possible engine capasity, the top 20% of the RPMS which few actually probably bother to use... there is less air/gas/oil blowing out the exhaust, plus the higher temps, it gets burned in the exhaust more effectively. Trials bikes on the other hand are tuned differently, actually about polar opposite of a race engine. Ports and carbs work differently to make the "Efficient" use of that whole "perfect train" described above when at the lower to mid ranges, in this perfect world Im saying at highest is at 30-40% of full throttle. where things in general are "slower" etc. In theory the train is closer to perfect at lower RPM and the tolerance is wider from idle to designed rpm, but goes past that so quickly as revs increas (opposite of the high rpm engines) that they bite off less and less of the tails of trains as the RPMS increase past design rpm capasity. This means spooge in your exhaust, if Everything I said above was with the exact same amounts of AIR/GAS/Oil in those trains. So as I read in that article, that spooge from the penton could just be that the train gets past the cylinder before combustion due to the design of its time, where optimum trains are at at best, 40% of wide open, meaning unburned gas oil and air gets past the cylinder before the squish happens, leaving deposites of oil and gas in your exhaust, more of the time if you are riding down trails hard and fast on the RPM ranges. you are 60% more likely to be using that 60% of that condition tossing unburned oils and fuel into the tiny little exhausts on a trials bike, instead of it sitting in the crankcase and ending up on the piston areas. IMHO, the BIG thing is about all the hot air I expressed above is, the oil has to have enough molecules in the right places to protect or provide "lubrication"... So since Trials bikes usually breath in the gas and oil, which gets deposited in crank cases and pistons etc, (due to the lower velocity of the air charges) which does accumulate in those areas, more oil is there in reserve. Since we're really not reving the engine much, you know at most of the use of the trials engine, in a given amount of time of operation (over a typical day). This tends to aid in lubing things even when mixed with less oil. so we typically mix trials bikes with less oil, to lessen the effect of a crankcase full of oil when we suddenly need RPM's that bring with them, a "lot" of that oil, or loading up, which also lessens the spooge in the exhaust. MANY people get foooled by this, but the trials bike wont take prolonged operation at HIGH RPM, unlike race engines, especially when we mix our gas typically at lower oil concentrations. We only do this because the little bit of "oil" deposited and channeled to the bearings let alone piston/cylinder surfaces, goes flying out the tailpipes PLUS it gets washed away with the more prevalent GAS in the mixture being pushed through the cylinder at higher pressures those few times we are at WIDE OPEN... If I find that article, if it was on the web, Ill try to post the link, I thought it was very well written, and I am sure I didnt explain a couple parts. like velocity vs port and spark timing, which hoepfully wont really change the thoughts that do pertain to oil/gas mixes depending on the "Duty Cycle" of the given engine in question. I hope this makes sense, anyone else read that article?
07-13-2010, 05:21 AM
#35 |
No Marks....
Oddometer: 1,610
Gordo 83....Your jets are likely way too big. You have discovered that RICHNESS means gas/air NOT gas /oil is what you are actually burning. I have a KT255 with a 26 Mikuni. Running 50:1 my engine builder does a spl needle,a 100 main jet and a 30 pilot, 2.5 slide. You are actually running RICHER than I am at 64:1. That's all done by trial by changing down through a lot of needles and pilot jets. It is totally counter-intuitive, but the bike will keep running better and cooler as you go DOWN in jet size and leaner on your needle. They will run clean and crisp when you get them close. On different days you just alter your PAJ a touch after the bike is warmed up. Your plug is probably blk and should be medium brown. Hope this helps.
07-13-2010, 05:21 PM
#36 |
Oddometer: 45
Thanks sting32, Great information.
buls4ever, Just checked the pilot. Main is 150 and the pilot is 25. Not sure about the needle. The plug is white with a little yellow on it. It is usually black, but this weekends trial had a long loop and I was able to wind it up on the loop. I would like to know the numbers on your needle and slide, if possible. Thanks |
07-14-2010, 05:47 AM
#37 |
No Marks....
Oddometer: 1,610
Gordo83.......Needle is a 5C23 machined by B&J. Slide a 2.5. Your pilot may be a little small and your needle is the part that you run on all the time in trials(most racing actually) and you really need to know what that is and what groove it is set on. Raise needle to richen,lower to lean. Your main is likely way big. Note that this refers to my Mikuni 26MM roundslide so if you run a Bing in that Penton none of this is the same as they have different jets and number system. Also you are talking about a 125 vs a 255. Give Bob Ginder a call at B&J Racing. This is a set-up to run 50:1 BTW.
07-14-2010, 11:02 AM
#38 |
Oddometer: 45
I have talked to Bob several times and he has helped me out with suspension. He was unable to help out with a carb for my Penton, as he hasn't built one for a Penton Trials bike. I am running a Mikuni VM26. That's what caught my eye on your post. I have the Bing built for trials also, but it is far from perfect. I am doing everything myself, as far as carburetion goes, so it's all trial and error. I may end up with a VM24 before I'm through.
07-14-2010, 01:55 PM
#39 |
Oddometer: 255
Tank Liner
Thanks Gordo83. Great link. I'm going to give it a try. It looks like just about any of them affect the gel.
08-20-2011, 03:07 PM
#40 | |
Oddometer: 10
I worked at a small saw mill that relied on a chain saw to cut the logs to length for the head saw. That chain saw worked, full throttle, all day long. It used a 100:1 mix.
I would use that oil, and mix ratio, if I had a street 2 stroke. I won't use that ratio in my off road bikes. The saw worked at WOT all day long. It always had oil on the important surfaces. Every time you decrease, or close the throttle on your "2 stroke dirt bike" you do not lube the important bits. Thats why you blip the throttle on long down hills. Run it a bit rich on oil, I dought you will feel the difference. H Quote:
b50bsa screwed with this post 08-22-2011 at 05:01 PM |
08-25-2011, 09:04 PM
#41 |
Wonna Be ADVrider
Screw the math. I use (for over 25 years) 1.5 ounces of pre mix per 1 gallon of premium gasoline, FTW.
NMOHVA Member & NMTA Member The silence was absolute, the sense of peace profound, and it bled in to me from this beautiful land. (ROD CURRIE, Team Sibersky Extreme) Fly & Ride RR: http://advrider.com/forums/showthread.php?t=841561 |
08-25-2011, 09:53 PM
#42 | |
cheap bastard
Oddometer: 2,996
08-30-2011, 04:50 AM
#43 |
No Marks....
Oddometer: 1,610
A-TEAMNM you are running 85:1 ratio.... 128(oz) divided by 1.5 = 85.33. FIXED for you
