Old 05-04-2009, 08:46 PM   #1
Prospect4896 OP
1983 CT 110
Oddometer: 4
sythentic oil in CT110
I thought for sure this had been covered in the past, and maybe it has but I couldn't find it in 5 min so .....
Is it OK to use synthetic oil in the CT110 since it also comes in contact with the clutches?
Prospect4896 is offline   Reply With Quote
Old 09-13-2010, 05:32 AM   #2
sean_syd
Oddometer: 37
Oil
You need to use mineral oil as the clutch will slip and wear with synthetic oil.
Some people use car oil as it's cheap.
Motorbike oil will be nicer to the clutch.
I picked up castrol 15w 50 $30 for 3L.
Will stay thicker at high temps.. Which you get with posties.
sean_syd is offline   Reply With Quote
Old 09-13-2010, 10:40 AM   #3
HandKPhil
HandKPhil's Avatar
Oddometer: 475
Yes, synthetic motorcycle oil is fine in your CT110
I put synthetic motorcycle oil in all of my bikes, including my CT90, CT110 and ST90. You can buy it at most auto parts stores nowadays, or you can go online and find a local Amsoil dealer. Just ask for synthetic motorcycle oil. It is approved for use with wet clutches.
HandKPhil is offline   Reply With Quote
Old 09-18-2010, 07:40 AM   #4
topless
Oddometer: 127
I have a CT90, and last oil change I went with Shell Rotella 5w40 full synthetic diesel oil. In about a mile it felt like I had installed new clutches in it. Motor was quieter than with 5w-40 Yamalube synthetic and it's half the price. Try a quart from Walmart.
topless is offline   Reply With Quote
Times are GMT -7.   It's 05:59 PM.
