View Results: Most practical based on: MPGs, reliability, storage, comfort, cost, build quality
Honda Reflex 7 4.96%
Honda Silverwing 32 22.70%
Suzuki Burgman 400 39 27.66%
Suzuki Burgman 650 33 23.40%
Yamaha Majesty 400 17 12.06%
Yamaha T-Max 16 11.35%
Kymco Xciting 250 1 0.71%
Kymco Xciting 500 5 3.55%
Multiple Choice Poll. Voters: 141. You may not vote on this poll
Old 09-22-2010, 08:05 PM   #16
smm
smm's Avatar
Oddometer: 68
I had a Honda reflex (16K miles) and a Burgman 650 (27K miles) both used for daily commuting, about 70% freeway.
The Reflex got 65mpg and was definitely maxed out on the freeway. It doesn't have enough brakes for 2-up riding. The quality of my Reflex was so-so: It had a bad alternator which ultimately caused it to die in the far left lane of a rush-hour freeway. A few other minor problems.
The Burg gets 45mpg and is completely comfortable on the freeway, even 2-up. I took my daughter to school a couple mornings a week, did a few weekend trips to the wine country, etc. The Burg has had no mechanical problems whatsoever.
The Burgman is definitely bigger and heavier but for all the extra weight still surprisingly nimble. 12' u-turns are pretty easy, and splitting through urban traffic is no problem. The only obvious problem with the larger scoot is the gas mileage.
So where I come down on the size issue is like this: if you have a bunch of freeway in your commute, or you fancy riding 2-up, the 650 is definitely worth it. If not, the burg 400 or the TMax might be a better choice.
If you're in the SF Bay Area, and beyond the burg-curious stage, mine is for sale, $3500. Resale on scooters, not so good. But I no longer have much of a commute and the adv bug has bitten...
-Scott
smm is offline   Reply With Quote
Old 09-25-2010, 04:01 PM   #17
lucky6600
lucky6600's Avatar
Oddometer: 590
Originally Posted by advtek
It was the best damn scooter ever built that's NOT a scooter!
Did some search, PC800s are in 3k range. I guess it's collectable.
lucky6600 is offline   Reply With Quote
Old 09-25-2010, 06:07 PM   #18
The PacRat OP
I'm that other guy
The PacRat's Avatar
Oddometer: 2,643
They are getting harder to find, but the type of rider than generally owns a PC800 tends to keep it in good shape, so there are some pretty cherry PCs out there. They are rock-solid too.
If you could just put floorboards on them...
If a hammer don't fix it, then it's an electrical problem.
The PacRat is offline   Reply With Quote
Old 09-25-2010, 09:13 PM   #19
windburn
Oddometer: 1,187
I'm real Pleased with my 2007 Silver Wing
I have owned two scooters a Honda Helix and a Honda Silver Wing. 21,000 miles on my Silver Wing and Only scheduled Maintenance. I for one have no Experience with the other scoots but others speak highly of the Burgmans
windburn is offline   Reply With Quote
Old 09-26-2010, 08:11 PM   #20
S/W
S/W's Avatar
Oddometer: 385
Silverwing
I have had my Silverwing since 2002, and still love it.
S/W is offline   Reply With Quote
Old 09-27-2010, 08:39 AM   #21
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 6,978
While from all of the above I'd probably get the Xciting 500, considering
you're concerned with MPG figures you should stay clear of it (250 too),
since they're rather thirsty, especially the older carb version.
Even the newer 500Ri (FI) sips more fuel then my 650cc Kawasaki.
Can't help with other choices though.
They're as reliable as it gets, but there's more comfy rides out there
and most of the mentioned have more under-seat storage.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 10-12-2010, 09:50 AM   #22
777arkrider
Confused and jet-lagged
Oddometer: 7
Cool2
I bought a 2009 silver Burgman 400 in July after test riding several maxi-scoots. The only bike I was unable to ride was a Honda Silverwing. The Yamaha Majesty was a nice ride, very similar to the Burgman in just about every way except the fuel mileage (45 to 55 mpg vs. 65 plus for the Burgman). The power and speed were almost identical as far as RPM vs. speed. I had owned a Kymco Peoples 200 and wanted to try the Xciting 500. The ergonomics did not fit me well ( I am 5'10 30" inseam weigh 165 to 170), the seat was to high, the handle bars to low, the seat was very hard and there was very little foot room. The instruments were almost impossible to see, the MPH were in tiny print and inside the ring and I had a hard time determining speed. It performed OK, the acceleration was good, and the engine was smooth. The fuel mileage was low at around 40mpg. It was also very heavy and difficult to maneuver it around in the parking lot. The T-Max was a great bike and I really enjoyed riding it, very motorcycle-like. My only negative was the high price and the lack of storage space, but other than that, I really liked the T-Max. I even got to drive the Burgman 650 and a 400 back to back, and liked the 400 better.
The 650 just felt too heavy and was difficult moving it around the parking lot.
So after comparing all my notes, and after re-riding some of my top choices I finally picked the Burgman 400. It feels lighter maneuvering, has great acceleration, cruises all day at 75 - 80 mph and gets 68.9 mpg at every fill-up. The Burgman 400 also has tremendous storage under the seat and an add on box is not necessary. I have put 1700 miles on my Burgman 400 and it is a joy to ride. The rpms vs. speed seem to be coming down. For example, yesterday I took a hundred mile ride and I noticed that at 70 mph my rpm was only 6,000 rpm whereas before right after 1,000 miles 70mph took 6300 rpm.
Also, I do not rely on the fuel mileage calculation the bikes computer comes up with. I always fill it up with the centerstand down and fill it up right to the bottom of the filler neck and divide miles driven by the gallons used and get 68.9 mpg every time. I don't baby it either but try to be smooth with the throttle and am amazed at the acceleration, very seductive and addictive!
777arkrider is offline   Reply With Quote
Old 10-12-2010, 05:58 PM   #23
Roose Hurro
Oddometer: 86
Don't forget to check out SYM, from the HD200 to the Citycom 300i.
Roose Hurro is offline   Reply With Quote
Old 10-12-2010, 10:41 PM   #24
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 2,862
gee I guess the helix in this vote is like the old grandfather that got stuff away and only visited at Christmas. My vote helix . cheap, reliable and if you have to shoot it to put it out of it s misry no ones going to call SPCM which is kind of like spca. Only it's hells angels that show up if you mistreat you bikes. .
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 01-27-2014, 07:00 PM   #25
gec343
gec343's Avatar
Oddometer: 817
I am considering a maxi scooter, so resurrecting this thread!!
“Until one has loved an animal, a part of one's soul remains unawakened.” -- Anatole France
2010 Gold Wing/ABS
1977 R100/7 (bought new)
gec343 is online now   Reply With Quote
Old 01-27-2014, 08:18 PM   #26
klaviator
klaviator's Avatar
Oddometer: 6,017
If I were going to buy a Maxi scooter, my first choice would be one not on your list, Kymco DT300. It is supposed to have very good handling. Gets good MPGs. Unlike most of the others, Valve adjustments are supposed to be real easy. Probably not too many used ones out there but new ones are going for well under MSRP.
Not sure if it qualifies as a maxi scooter but you do have some 250s in the poll.
Second choice, also not in the poll, Kymco GT300i.
And What about the BMW maxi scoots? About the same price as the Burgman 650?.
I ride, Therefore I Am.
klaviator screwed with this post 01-27-2014 at 08:31 PM
klaviator is online now   Reply With Quote
Old 01-27-2014, 08:42 PM   #27
brianwheelies
Iron toocus
brianwheelies's Avatar
Oddometer: 3,711
Have not ridden any of them. Based on research of all models, the go to here is the Burgman 400 even though I would most likely snag a used Majesty.
As Klaviator indicated, other viable options are now available too. Kawasaki 300
Originally Posted by Skowinski View Post
Speaking of dumps, that coffee is working for sure, gotta scurry and perch on the thundermug...
brianwheelies is offline   Reply With Quote
Old 01-27-2014, 10:18 PM   #28
JerryH
Oddometer: 5,069
I would prefer the Honda Silverwing for a full sized Maxi. It fit me better than any of the others I tried. The Burgman 400 had valve issues through '07, I believe. I know it was redesigned sometime around there. I wouldn't even consider the Burgman 650. It has a well known reputation for transmission failures, and when they happen, they usually cost more than the scooter is worth to fix. The problem is real, I borrowed a Burgman service manual, and found the problem. The Burgman uses a very intricate and fragile gear shifting mechanism. Manual shifting puts more stress on it, and while failure is not that common on low mileage bikes, the more miles it has on it the more it will wear. I had a motorcycle with a plastic oil pump gear, took it almost 40,000 miles to fail. But when it did the motor became a boat anchor. A 1500cc motorcycle should last more than 40,000 miles. A 650 scooter should easily make it past 100,000 miles. For a mid size scooter, I like the Kymco GTi300. I won't even comment on BMW.
JerryH is offline   Reply With Quote
Old 01-27-2014, 10:35 PM   #29
quasigentrified
Trumpet Strumpet
quasigentrified's Avatar
Oddometer: 790
piaggio bv350, hands down.
'14 Triumph Tiger 800XC for failin'
'12 BMW F800ST for haulin'
'14 Triumph America LT for posin'
quasigentrified is offline   Reply With Quote
Old 01-28-2014, 05:51 AM   #30
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 6,978
That's the Downtown.
Times are GMT -7.   It's 10:50 AM.
