Old 11-18-2009, 07:15 PM   #16
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Originally Posted by Scott Davis
I have a 92 model and just rebuilt both my carbs. I am pretty good at setting them up, PM me if you would like some local help!
I think the float level would be my first check, then balance carbs. While in there, blow out all the jets and ports. Can't hurt!!!
Scott
[snobby british accent]Good show old man. [/accent]
datchew is offline   Reply With Quote
Old 11-18-2009, 07:18 PM   #17
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Originally Posted by bgoodsoil
It was a genius that came up with that one right? I'm not an engineer and I hate to badmouth somebody's work but whoever designed that is a moron. Whoever left it that way for decades is even dumber.
There are morons in the engineering world. Trust me... I'm one of them sometimes.
Old 11-10-2010, 05:31 AM   #18
jeveretts
jeveretts's Avatar
Oddometer: 494
Did you ever get this problem sorted out? I am having the exact same issue with my r100gs 1992
jeveretts is offline   Reply With Quote
Old 11-10-2010, 07:23 AM   #19
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,420
Check your diaphragms as well! Take them out and look for holes next to a bright light.
Go far or stay home.
durtwurm is offline   Reply With Quote
Old 11-10-2010, 09:45 AM   #20
Tim McKittrick
Oddometer: 1,775
No one has mentioned fuel filters yet- I chased a similar issue for some time with my R100RT and after going through float settings, valve adjustments, timing, coils, petcock filter socks, and tank and carb venting I finally changed the fuel filters. In my case, the old filters appeared fine- they looked new and had no visible buildup of crud in them, yet they were just restrictive enough to starve the bike for fuel under just the right conditions. Pulling a hose off a carb and opening the petcock appeared to produce plenty of flow as well, and if there was more than a half tank of fuel it was fine because of the added fuel pressure from the full tank. Now whenever I hear of someone having a high load stumble I suggest looking at the filters FIRST- they are by far the easiest thing in the system to change, and cheap to boot.
Tim McKittrick is offline   Reply With Quote
Old 11-10-2010, 03:53 PM   #21
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Originally Posted by Cirbo
Would the PD tank also have red primer (being poly)? This is the second time I've heard that idea.
I am quite sure it isn't coated.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 11-10-2010, 03:55 PM   #22
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,420
Tim, I am pretty sure my petcock filters are original ('78 RS). And they represent no problem, plus they look "fine'"as you mention. I think I will change them though I have cleaned 'em up. Cannot hurt.
Old 11-10-2010, 04:00 PM   #23
StephenB
StephenB's Avatar
Oddometer: 2,044
Are you talking about the screens inside the tank or the in-line paper filter that can be used?
+1 if you're talking external paperfilters (VW-type): they seem very restrictive and when I am on reserve the pressure of the remaining 4-5l isn't enough to let gas flow through them when you let them run dry.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 11-10-2010, 04:22 PM   #24
Tim McKittrick
Oddometer: 1,775
I was referring to the little clear after-market external filters commonly installed between the petcock and carburetor. All of the BMW's I have ever owned have had them but they never came out of the factory with them. I've seen both pleated paper style units (I think that would be the VW sort referred to above) as well as the sintered bronze style. I had the ones that had the bronze element in them, and they appeared fine. I honestly only replaced mine (instead of eliminating them altogether) as it was easier to plug in a new filter than to find a double ended hose barb to rejoin the sections of fuel line, and I'm a lazy, lazy person.
The filter socks in the tank can be reached by unscrewing the petcock and are easily cleaned- these usually catch the majority of the crud.
Old 11-10-2010, 05:41 PM   #25
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,420
The in line filters if used should be changed yearly. The plastic ones are cheap; the metal filters with replaceable innards are more expensive initially. I was wondering. I thought you were referring to the petcock filters and always thought they just need a little periodic cleaning.
Old 11-10-2010, 09:28 PM   #26
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,673
Originally Posted by StephenB
Float bowel level is my initial thought ...
Believe me when I write, it's not your bowel! Though this problem is frustrating enough to have that effect. Someone will usually do that typo in such a thread.
My bike has shown similar symptoms in the past. Riding along and a poor stuttering response that improves if slowing down for a while. It tends to repeat itself unpredictably/inconsistently at higher speeds. A diaphragm problem would be more consistent and predictable.
Advice to me at the time was:
  • float bowl level...hadn't been touched, looked correct.
  • fuel flow problem. Nope, flowed well from the tap, no ext. filter.
  • diaphragms..were ok
  • hall effect sensor. Never tested.
  • ht leads/plugs. Replaced.
Then whilst on a 4K+ ride, and 1600k from home it happened and wouldn't go away. It proceeded to deteriorate.
I holed up in a motel, went thru the usual trouble shooting checks to no avail. I found a local airhead owner (known via another forum) and he generously helped me the next day. We repeated the checks and got no where. A quick call to a BMW mechanic, who offered the same advice as we'd already performed.
Then he said..."have you pulled the main jet and checked it"?
Haven't had a problem since.
Simple things first. Bowl level, the jet, fuel flow, diaphragms, electrics.
boxerboy81 is offline   Reply With Quote
Old 11-11-2010, 06:13 AM   #27
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,420
And while you're in there go to your nearest auto parts dealer and replace the o-ring! These are stock items and will be carried at Carquest and NAPA, etc. That black item looks like an old o-ring. Is it?
durtwurm screwed with this post 11-11-2010 at 06:31 AM
Old 11-11-2010, 06:22 AM   #28
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
Looks like someone else had "The little piece of crap floating around the bowl.......sometimes impeding the fuel flow until it finally jams up there and blocks the jet".
Very frustrating the first time, but second time around only a 5 minutes repair job.
Have tools, will travel!
Old 11-11-2010, 08:30 AM   #29
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,546
You just reminded me of putting appart the petcocks and cleaning the screens.
From inexpensive and easy to expensive and hard; that is how troubleshooting is done!
Uncle Pollo is offline   Reply With Quote
Old 11-11-2010, 09:16 AM   #30
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,536
I changed the float bowl gaskets shortly after getting the bike (6-8 months ago).
Give us a quick maintenance history of the bike, as long as you've owned it.
'73 R60/5 Toaster
Times are GMT -7.   It's 05:04 AM.
