Old 11-15-2010, 08:06 AM   #11
Spark01
V-Twin
Spark01's Avatar
Oddometer: 304
Somebody on the dutch lc8 forum is testing some custom settings on the ecu
He did alter the setting for the switch between the TPS&Manifold air pressure(F-L map).
The firts test results are very good.
He altered the settings between 1000-4000rpm lower than 10% TPS (standard this is 12% or higher).
For the switch between the L and F map.
He allready tried: 16sprocket,O2 sensors disabled, other throttle cams,2nd valves removed but none really worked for him, for the bike response on non smooth roads.
The Bike is a SMT by the way
This is a similar known mod that is also done on Suzuki SV1000/TLR's only on those bikes The tps switch is rotated to lower the switch point. On the KTM you can't do this that why he changed the settings in the F-L map.
'10 990SMT
Spark01 screwed with this post 11-15-2010 at 08:18 AM
Spark01 is offline   Reply With Quote
Times are GMT -7.   It's 03:43 PM.
