Old 12-02-2010, 09:19 AM   #151
crazydrummerdude OP
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
Haven't really determined what it is/was yet.
One guy in the lab is going to be grasping at straws to not fail, so he's been following me around like a little annoying puppy dog lately. Since I've been a 1-man group and written all the reports, made both the designs, and ran the simulations, I'll have him look at that (and micro-structure).. if he feels like actually doing something. If not.. well, I have until Wednesday to figure it out. That's when I'm giving my design(s) presentation.
crazydrummerdude is offline   Reply With Quote
Old 12-02-2010, 09:44 AM   #152
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
Drummer:
Can you elaborate on a few things? The 60-40-18 - Is that just a goal you need to hit in order for this specific batch of metal to be good for the intended purpose? Or, did you or someone just make up these ratios and then see if you can hit it? Is the 60-40-18 a standard mix for certain kinds of applications?
What would happen if this got spilled onto your foot? You mentioned the one person with a burned sock, but I kinda thought this would just burn a hole all the way through anything it touches.
Can you detail for me (unless it's too much work) what these items are:
"To get this, it takes a specific mixture of C, Si, Mn, P, S, Cr, Mo, Ni, Al, Cu, Ti, V, Sn, Mg, Fe, etc. "
I find this thread fascinating and the new pictures are terrific.
Tom
Infracaninophile is offline   Reply With Quote
Old 12-02-2010, 10:45 AM   #153
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,531
Your pour on the previous page reminded me of high school metal shop 1976. We were going to mass produce aluminum beer mugs with the school mascot on the design. First pour we didn't have enough air holes and only partially filled the mold. We fixed that and ended up with a couple of good prototypes. I guess we ended up only making about 5 mugs.
Think about what it would be like to have your classmates at a job site.
scooteraug02 is offline   Reply With Quote
Old 12-02-2010, 10:49 AM   #154
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,551
Originally Posted by Infracaninophile View Post
Drummer:
Tom
Those are abbreviations for elements.
C=Carbon
Si=Silicon
Mn=Manganese
P=Phosphorous
S=Sulfur
Cr=Chromium
Mo=Molybdenum
Ni=Nickel
Al=Aluminum
Cu=Copper
Ti=Titanium
V=Vanadium
Sn=Tin
Mg=Magnesium
Fe=Iron
All found on the periodic table.
Most metal that we use to make things from are alloy, or mixes of various elements. Different mixes give different properties like density, strength, hardness, toughness, corrosion resistance, thermal and electrical conductivity, and on and on.
For the Ferrous metals, carbon is usually considered the most important alloying element. It, more that any other element, contributes to strength and hardness when mixed with iron. Some of the alloys of iron are Cast iron, Steel, Pig Iron. The difference is defined by carbon content. Very roughly and incompletely <2% C = Steel, > 2ish % =Cast Iron, > 6ish % = Pig.
The primary purpose of refining steel or iron is the control of Carbon, but impurities (like sulfur in most cases) are removed and other things like molybdenum, nickel, and chromium are added to give the steel/iron it's desired properties. Sometimes elements are added to drive others out of the alloy.
Alloys can contain dozens or even hundreds of elements, but not all are present in quantities that have a significant outcome on the material properties, so only the ones that are considered important are referred to.
There are several standards organizations that give numbers to the various mixes that create alloys (like AISI) and numbers like 4130 or 4340 are used to represent these mixes. In this case however the number relates to the properties of the steel
60-40-18
60=min tensile strength in thousands of pounds/in squared
40=min yield strength in thousands of pounds/in squared
18=% elongation in tensile test
www.Ductile.org has a lot of reference info for the type of material he is casting.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne screwed with this post 12-02-2010 at 01:01 PM
dwayne is offline   Reply With Quote
Old 12-02-2010, 11:51 AM   #155
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,635
This is a scaled down gating design project for a railcar brake piece. It's ~18(?) inches long. My first one:
I assume that's what's used in the real world for this piece: "buckeye tender truck" apparently.
It's one of many "standards."
Well, if you dipped your foot into the furnace, or they poured it in your shoe, you'd probably be missing a limb (it's 2700+ degrees F). What happened in class was the TA was slagging it off and knocked the rod on a metal stand. A spark flew off and down into the girls boot. I'd compare it to getting a welding spark down your shoe. Painful, but you'll be ok.
Even though she was wearing a metatarsal boot, sometimes you get unlucky. She should have been wearing clip-on silvers when working that close to the furnace (she was directing the charge).
Old 12-07-2010, 08:48 AM   #156
Oh2RideMore
Oddometer: 1,299
great thread
Loved reading this thread, and have always wanted to play with a home brew forge. Keep us posted on your progress. Thinking of trying the hairdryer 5 gallon steel bucket version. This kind of work is really interesting.
2008 WR250R(Anywhere)
2009 Versys
Oh2RideMore is online now   Reply With Quote
Old 12-14-2010, 04:25 PM   #157
subybaja
subybaja's Avatar
Oddometer: 2,891
I don't know anything about iron casting (Sadly- my grandfather was a grey-iron foundryman for 50 years. I wish I'd learned from him when I had the chance.), but that kind of porosity/roughness in a jewelery casting would indicate sprues (gates?) that are too small. The cooling, contracting liquid metal needs a reservoir to pull from, or it will pull from the piece.
But lost-wax gold may not work the same as iron...
It looked as though you leave the foam cores in the molds, and just let the iron burn them out? Weird. Jewelers burn the wax out in an oven before pouring metal.
We had part of a Slinky. But I straightened it.
subybaja is offline   Reply With Quote
Old 12-14-2010, 04:46 PM   #158
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,635
The sprue is the part through which the metal travels from the pouring cup to the runner. The gates are where the metal travels from the runner to the casting.
The point of risers is to feed liquid metal into the casting to make up for this solidification shrinkage, based on Niyama criterion.
The gates were not too small, but the risers were (using a rule of thumb that the risers should have 120% the modulus (volume/area) of the local modulus of the casting).
Note, that was my first casting. The second one turned out much better. Once I am done with this take-home final (my last thing to do for this semester), I will update this thread more thoroughly.
How does it look like that?
Additionally, it's not that weird to actually leave the foam in. I chose not to because I wanted hot, good metal in there as fast as possible. In lecture, we discussed the metal front as it spends energy burning the foam out, and we actually saw an x-ray video of a casting doing just that.
crazydrummerdude screwed with this post 12-14-2010 at 04:57 PM
Old 12-17-2010, 11:17 AM   #159
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,635
Well, then. The semester is over.
To recap: My group was a bunch of losers who never showed up or did anything. On Sunday after my last update, I got an email from one group member asking if I had made the presentation yet. The last time I talked to (or saw) this guy was 2 months prior, so I responded telling him that we all decided I was to be in my own group, and yes.. I already made my presentation. He replied saying that he wants to have a meeting with me, the professor, and the department chair. I agreed, suspiciously. I figured it would be in my best effort to document all our interactions, so I made a 2-page spreadsheet consisting of times/dates/topics/actions/etc of everything everyone in the group had done. During the meeting, he started crying out that I never let him do any work, and that I kept him from succeeding and that he sent email after email to me and I ignored them all. I whipped out my sheet, and from that point on, it was all over for that lying scumbag.
Let's see, he showed up TWICE out of 16 weeks in the lab, and almost as many times in the lecture, and it's my fault?!
ANYWAYS...
To recap the design:
First one sucked.
Had porosity and surface roughness.
Second one did not suck, but did have a lot of flash.. and a sand problem at two of the gates (not at the parting line). The one guy who meows to himself in the corner (did I mention he does that?) came up and was standing so close to me, I could feel his long hair on my neck as I was packing the sand. JUST A BIT distracting. Everything went fine during the pour, and the casting came out great. A sledge hammer broke off everything easily enough; light swings on the risers while it was laying on the floor, then a drop of the hammer on the gates.
..and she looked damn good. No real surface roughness or porosity.
On both designs, I incorporated a simulated "washburn core" on the risers. That is, a design such that the riser doesn't have full diameter where it meets the casting. A short, small cylinder (or tapered square) is in between the riser and casting for ease of removal. That's why on the second design (without having to wait on zero input from WORTHLESS group members), I incorporated something similar in the gating. (Finishing is part of the design! It isn't supposed to take 5 hours to removed the gating and risers.) Studies show that the small volume in between the riser and casting has no detrimental effects (in terms of feeding the casting liquid metal on solidification). A real washburn core is a donut of sand placed in between the casting and riser, instead of a small piece of foam with sand packed around it.
Anyways, here's what the bottoms of the risers looked like after hammered off.
I wrote up the report (19 pages) and gave a 31-slide presentation by myself.
Then, when I turned in my take-home final for the lecture class, my teacher and I got to talking.. and I scored some scrap gray iron for my brother for a cylinder on a miniature engine he is machining.
I could go into a lot more detail, but.. I'll save it unless anyone has questions/comments.
Next semester is CNC!
Old 12-17-2010, 06:45 PM   #160
Ben Carufel
Boxer Addict
Ben Carufel's Avatar
Oddometer: 729
Just read through the whole thread. Super cool!
Ben Carufel
'02 BMW R1150GSA - '72 BMW R60/5
Recovering BMW Addict...
Ben Carufel is offline   Reply With Quote
Old 12-17-2010, 08:23 PM   #161
subybaja
subybaja's Avatar
Oddometer: 2,891
Great work, man! Fascinating to watch the learning process over your shoulder!
Extra points for not letting the worthless partners slow you down.
Old 12-17-2010, 09:35 PM   #162
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 12,121
DUDE! STOP! You're killing me here. "Packing the sand?" Is that what kids call it today?
Donkey Hotey is offline   Reply With Quote
Old 12-17-2010, 09:50 PM   #163
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,635
I set that up to be as gross as I felt at the time. I'm hunched over making the mold and he's standing behind me hunched over too.
Get. The hell. Away.
Old 12-18-2010, 07:23 AM   #164
Infracaninophile
Finding My Way..
Oddometer: 7,514
So, dish the dirt. Did you receive a top grade? And your "team" members? Lets hear the dirty details. Did team members 3 & 4 complain also?
I love threads like this as it opens a window into something really interesting of which I had zero knowledge before.
tom
Old 12-18-2010, 10:38 AM   #165
milq
milq's Avatar
Oddometer: 743
I swear...one of my students must be driving over there to take classes with you. I have one that has zero sense of personal space or privacy, I have turned around to find him reading over my shoulder as I type on a laptop in the lab. Some of his fellow students have made it clear to him that they don't appreciate it, but he always finds someone else to hover over. (The guy does get his work done though)
Good stuff on the class, looks like you learned a lot and had a (mostly) good time doing it. I'm not surprised that the guy tried to leech onto your work in the end. Happens here all the time, but I keep very good records on attendance and make notes about who is screwing off, etc. even if they are there.
milq is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 12:27 AM.
