Old 01-07-2011, 09:34 AM   #1
Donzzilla OP
Donzzilla's Avatar
Oddometer: 416
New AMA Vintage Rules and Classes for 2011
2011 AMA Racing National Vintage Dirt Track Championship Series
Supplemental Regulations
The 2011 AMA Racing Rulebook Governing Pro/Am, Standard, ATV and Youth Competition and
these Supplemental Rules will govern these events.
AGE AND ELIGIBILITY
1. To compete in the 2011 AMA Racing National Vintage Dirt Track Championship Series,
participants must be at least 18 years old on the date of the event.
Please see the 2011 AMA Racing rulebook for regulations regarding rider eligibility.
GENERAL
1. AMA Pro Racing license holders must wait one full year after their pro license expires to be
eligible for Amateur National competition.
2. If one or more main events cannot be run, results will be awarded based on heat and/or semi
results.
3. Three entries minimum are required to make a class.
4. Limit of four classes per rider per meet.
5. Knobby tires will NOT be permitted.
6. Only riders who qualify for main events will receive points.
7. All riders who qualify for a main event but are unable to start will receive nine points which is
equal to a 12th place finish position.
8. Riders who are disqualified from a main event will not receive points.
9. Points Scale
Pos Pts Pos Pts Pos Pts
1st 30 10th 11 19th 2
2nd 25 11th 10 20th 1
3rd 21 12th 9
4th 18 13th 8
5th 16 14th 7
6th 15 15th 6
7th 14 16th 5
8th 13 17th 4
9th 12 18th 3
10. Ties in the final standings will be broken for 1st, 2nd and 3rd places only. The first tiebreaker
is the better finish in the final main event in the class; the second tiebreaker is the better finish
in the next to last main event in the class, etc. If the main events are run in an order different
than originally scheduled, e.g. because of a rain delay, the actual order in which the races took
place will apply.
11. The machine the rider brings to the starting line for his/her first heat is considered the qualified
machine for that day’s event.
EQUIPMENT
1. Standard flat track front spools and real knock off wheels are allowed on all no brake machines.
2. OEM, like make and model = parts or accessories from the same make and model motorcycle.
No mixing or matching different makes or model parts or accessories. Different year parts
from the same make and model are allowed.
3. Era correct = parts or accessories that were made in the time period or similar reproductions.
4. 1969-1976 any brakes – 2 pistons max.
5. No hydraulic clutches in any classes.
6. No pumper type carburetors are allowed in any class.
7. All drain plugs must be safety wired. No exceptions.
8. All axles and swing arm pivots must be steel.
9. All 2-stroke machines must have a packed silencer.
10. No front fenders allowed on any machine.
11. No electrical engine monitoring or management systems.
12. Restrictor requirements for all RS750 Honda s and XR750 Harley-Davidsons must be
equipped with restrictor plates, one per cylinder the restrictor plate is a 1/8 (0.125" or
3.175mm) inch thick plate, containing a round 33mm (1.299") hole in the center of the air path.
the hole must have square corners (no radius or chamfer on either side) the minimum size
for carburetors is 38mm. the restrictor plate must be installed directly at the rear end and in
contact with the carburetor casting the manifold on the cylinder head side of the restrictor plate
must have a minimum inside diameter of 35mm for a distance of 1" in contact with the restrictor
plate.
CLASSES
FACTORY WARS (BRAKELESS)
CLASS: PRE 1951 750cc side valve or 500cc over head valve 4 stroke only
No brakes in oval competition. Brakes in TT racing only
Front tire-2.70x7.0 or 4:00 maximum
Front rim-wm-3 2.15" maximum spoke type only. No mag type wheels
Rear tire-2.70x7.0 or 4:00 maximum
Rear rim-wm-3 2.15" maximum. Spoke type only. No mag type wheels
Forks-OEM. Era correct stiffening allowed. No adjustable triple clamps
Gas tank-OEM
Frame-OEM. Era correct stiffening allowed
Seat-era correct
Oil tank-OEM
Motor-mfg. Must match frame and forks. Like, make and model
Head-OEM, like, make and model
Cylinder-OEM, like, make and model .080 overbore and mfg stroke
Cases-OEM, like make and model
Ignition-era correct. Aftermarket ignitions allowed, but must be hidden
Carburetor-era correct OEM or Linkert m&s series, amal type 29, 76, and 276
TT, RN no Mikuni's or Kehin's
Restrictors-none
Transmission- OEM, like make and model. 4 speed max. No foot shift or hand clutch
Conversions on bikes originally hand shift
No military hand clutch conversions
Shocks-rigid rear suspension only
Exhaust-era correct
TT brakes front-OEM, like make and model drum only
TT brakes rear-OEM, like make and model, mechanical drum only
80ci limit in TT racing only OEM mfg. Bore and stroke
250 IRONMAN (BRAKELESS)
CLASS: 1952-1968 0-250cc 2-stroke or 4-stroke
Front rim-wm-3 2.15" maximum. Spoke type only. No mag type wheels
Rear rim wm-3 2.15" maximum. Spoke type only. No mag type wheels
Forks-OEM or era correct. 35mm max dia. Conventional design only
Gas tank-era correct
Frame-OEM twin shock or rigid. Aftermarket rigid frames only
Seat-OEM or era correct
Oil tank-OEM or era correct
Motor-mfg. Approved for competition
Cylinder- OEM, like, make and model .080 overbore and mfg stroke
Carburetor-era correct 32mm maximum for singles 28mm for twins. Linkert
m,l&stillotsen, del 'orto ssi, amal mono block, concentric, gp and TT. Irz
32mm. Mikuni vm flange mounts or spigot mount round slides. No flat slides
Restrictors-no reed valves
Transmission-OEM, like make and model. 5 speed max.
Shocks-OEM or era correct. No piggy back shocks
Exhaust-era correct
TT brakes front-mechanical drum only. Era correct
TT brakes rear-mechanical drum only. Era correct
750 IRONMAN (Brakeless)
CLASS: 1952-1968 251cc-750cc 4 stroke side valve or 251cc-500cc over head valve, 2
Or 4 stroke
Rear rim wm-3 2.15" maximum spoke type only. No mag type wheels
Gas tank- era correct
Frame-OEM twin shock or rigid. Aftermarket frames rigid only
Seat-era correct
Oil tank-era correct
Ignition-OEM or era correct. Aftermarket ignitions may be used but must be hidden
Carburetor-OEM or Linkert m,l&s, tillotsen, del'orto ssi, amal monoblock and concentric, gp,
TT, irz 2mm. Mikuni vm flange mount or spigot mount round slides. No flat slides
allowed restrictors no reed valves
Exhaust-era correct
TT brakes front-mechanical drum only era correct
TT brakes rear-mechanical drum only era correct
TT racing 900cc maximum displacement
250 HOTSHOE
CLASS: 1969-1976 175cc-250cc 2 stroke singles only. 4 stroke singles and twins allowed
Rear brakes mandatory. No front brakes in oval competition
Front rim-wm-3 2.15" maximum. Mag or spoke type allowed
Rear rim wm-3 2.15" maximum. Mag or spoke type allowed
no adjustable triple clamps. Fixed aluminum triple clamps allowed
Frame-OEM, modified allowed or era correct replacement. Twin shock or rigid
Seat-era correct
Carburetor-era correct. No mm limit. No Mikuni or Kiehin flat slides
Restrictors-none
Transmission- OEM, like make and model. 5 speed max.
Exhaust-era correct
TT brakes front-OEM or era correct disc, two piston max.
Brakes rear-OEM or era correct disc, two piston max
360 HOTSHOE
CLASS: 1969-1976 251cc-360cc 2 stroke singles or 4 stroke singles and twins. 250cc twins in this
class.
Rear brakes mandatory no front brakes in oval competition
Front rim-wm-3 2.15" maximum. Spoke or mag type allowed
Rear rim wm-3 2.15" maximum. Spoke or mag type allowed
No adjustable triple clamps. Fixed aluminum triple clamps allowed
Frame-OEM, modified allowed or era correct replacement twin shock or rigid
Seat-era correct
Restrictors-none
Exhaust-era correct
TT brakes front-OEM or era correct disc. 2 piston max
Brakes rear-OEM or era correct disc. 2 pistons max
750 HOTSHOE
CLASS: 1969-1976 335cc-750cc multi cylinder 2 or 4 stroke
No adjustable triple clamps. Fixed aluminum allowed
Seat-era correct
Cases-OEM, like make and model. Pre 1988 oil pump only on xr750's
Ignition-era correct. Aftermarket ignition allowed, but must be hidden
No motoplat or pvl ignition on xr750's
Restrictors-none
Exhaust-era correct
TT brakes front-OEM or era correct disc, 2 piston max
Brakes rear-OEM or era correct disc, 2 piston max
No 1989 or later engine components allowed on HD xr750's
250 MASTERS
CLASS: 1977-1988: 250cc 2-stroke; singles only
Rear brakes-mandatory no front brakes in oval competition front brakes in TT racing only
Front tire-2.7x7.0 or 4:00 maximum
Front rim-wm-6 3.50" maximum. Spoke or mag type
Rear tire-2.75x7.5 or 4:00 maximum
Rear rim-wm-6 3.50" maximum. Spoke or mag type
Forks-OEM or era correct. Any diameter, conventional design only adjustable triple clamps
allowed
Frame-OEM, stiffening allowed or era correct replacement twin shock or Roberts mono
shock, early C&J mono shock (horizontal shock on top of motor) Honda factory dirt
track, rs linkage frame or Panther-Bolger linkage frame
Seat-era correct
Motor- mfg. Approved for competition
Restrictors-none
Transmission-OEM like make and model. 5 speed max.
Shocks-OEM or era correct. Piggy backs allowed. No remote reservoirs
Exhaust-era correct
TT brakes front-OEM or era correct disc, multi piston allowed
Brakes rear-OEM or era correct disc, multi piston allowed
500 MASTERS
CLASS: 1977-1988; 504cc 4 stroke singles only
Front brakes in TT racing only
Front rim-wm-6 3.50" maximum. Spoke or mag type rim
Rear rim wm-6 3.50" maximum. Spoke or mag type rim
allowed
Gas tank -era correct
Seat-era correct
Restrictors-none
Exhaust-era correct
750 MASTERS
CLASS: 1977-1988 375CC-500cc 2 stroke singles: 504cc-600cc 4 stroke singles: 501cc-750cc
twins
Front rim-wm-6 3.50" maximum. Spoke or mag type allowed
Rear rim-wm-6 3.50" maximum. Spoke or mag type allowed
shock, early C&J mono shock (horizontal shock on top of Motor) Honda factory dirt
Seat-era correct
Head-OEM, like, make and model no d port head on xr 750. Single plug only
Cases-OEM, like make and model. No big oil pump on xr 750's. 1988 or older
oil pump only
Ignition-era correct no motoplat or pvl on xr750's
Carburetors-singles, un-restricted. Xr750 and rs75 must have a 33mm intake restrictor and a
38mm or larger carb. All other twins no mm limit or restrictors required
Exhaust-era correct
Any single cylinder 4 stroke approved for AMA competition before 1988 can be bored (no
stroking) up to 600cc's and run un-restricted in this class
Any single cylinder 4 stroke over 600cc's must have a 38mm or smaller carburetor
HD xr750 may not use any 1989 or newer engine components
HOT ROD SINGLES OPEN
CLASS: Pre 1988 Open Singles 2 Or 4 Stroke
No front brakes in oval competition. Front brakes allowed in TT racing only.
Engine cases only must be from a 1988 or earlier AMA approved for competition motorcyc
HOT ROD MULTIS OPEN
CLASS: Pre 1988 Open Multi Cylinders 2 Or 4 Stroke
Rear brakes mandatory in oval competition.
Engine cases only must be from a 1988 or earlier AMA approved for competition motorcycle
50+ AND 60+ VINTAGE OPEN
ALL '69-'88 vintage legal and open legal bikes eligible
Donzzilla is offline   Reply With Quote
Times are GMT -7.   It's 12:30 PM.
