Old 01-07-2011, 05:08 PM   #1
rthuey OP
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,826
cause looks do matter
is there a fix for this?
We're gonna go ridin!!!
rthuey is offline   Reply With Quote
Old 01-07-2011, 05:11 PM   #2
MayerMR
MayerMR's Avatar
Oddometer: 291
Soda blasting will fix that right up for you.
-Matt
1972 Honda CB450 (Rebuilding), 1971 Ducati 450 R/T (in the queue), 1971 Honda SL100, 1965 Ducati 160, 1967 Honda CM91/CT90 hybrid, 1986 BMW K75
MayerMR is offline   Reply With Quote
Old 01-07-2011, 06:10 PM   #3
rthuey OP
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,826
you mean like dropping mentos into diet soda, blasting or what these guys do?
do i get to remove the seat and gas tank and they can do it. or does the thing have to be stripped down and given to them in pieces?
once it is blasted what stops it from happening again?
tanks for the info by the way
Old 01-08-2011, 02:17 AM   #4
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,800
Check out this thread, some good suggestions there http://www.advrider.com/forums/showthread.php?t=646371
Old 01-08-2011, 04:32 AM   #5
Jasper ST4
Guest
Oddometer: n/a
Do you have a larger photo so that we could see some details?
Old 01-08-2011, 05:03 AM   #6
goatroper
goatroper's Avatar
Oddometer: 626
You're welcome
goatroper is offline   Reply With Quote
Old 01-08-2011, 06:35 AM   #7
AtLarge
AtLarge's Avatar
Oddometer: 125
Thank you for fixing that. When I first started reading this thread I thought someone put Kawasaki jugs on their beemer.
1973 CL70-K3
1983 KZ750-K1
2008 GSX1300-BKK8 #1120
Cardo Scala rider G4 PowerSet
AtLarge is offline   Reply With Quote
Old 01-08-2011, 07:03 AM   #8
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,701
Paint it black
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 01-08-2011, 10:08 AM   #9
DaveBall
DaveBall's Avatar
Oddometer: 1,163
+10 Paint it black, but use a brush and don't remove anything.
Looks like you are into a total tear down and getting into some serious media blasting. As all the parts are fairly small. get yourself a blasting cabinet from Harbour freight and a big compressor. The cost of having it all blasted will be more than just doing it yourself.
DaveBall is offline   Reply With Quote
Old 01-08-2011, 10:24 AM   #10
NitroMax
NitroMax's Avatar
Oddometer: 684
I just did this today just to try the stuff I bought last week.
Rain, snow and salt from the last couple of weeks ruined the brakeplate of my SuperElastik sidecarwheel.
Sprayed it with Race Glaze Alubright Metal Deoxidiser and briefly scrubbed it with a brush:
Repeated spraying and brushing it for a second time, rinsed it with hot water and dried with airhose:
Cap on the right was just as bad, problem with the brakeplate is that it's got a rough surface.
This is the result of only a couple of minutes.
After this I sprayed it with Race Glaze Jet Laq Non-Paint Lacquer for protection. It's drying as I type this, putting it back on tomorrow and hope for more snow and salt to test it
I can do this piece by piece but with a good brush and with some elbowgrease I think you can get your engine back to a better looking state. Obviously not as good as taking it apart and have it sand/bead/pearl/glassblasted but hey it's a lot cheaper and less work
@ AtLarge: I was wondering about the same thing when I opened the topic
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Times are GMT -7.   It's 05:23 AM.
