12-30-2010, 09:35 AM
#1696 |
Cheated Anion
Oddometer: 4,540
Is there a trick to getting seamless welds (like around an exhaust fitting) with flux core mig? I can't for the life of me either a) get a good leak proof weld all the way around or b) get a seamless weld and not blow through it like its not even there.
12-30-2010, 09:41 AM
#1697 | |
aka Road Monster
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin. "Politicians are always interested in people. Not that this is always a virtue. Fleas are interested in dogs." -P.J.O'Rourke |
12-30-2010, 10:18 AM
#1698 | |
MotoBiggots Suck
Oddometer: 371
A guy once ask me, "what the trick to sucessful brain surgery was", I told him to stop using a chainsaw...
12-30-2010, 12:19 PM
#1699 |
Who knows
Oddometer: 1,746
Question About Welding Stainless Pipes
I have been given a stainless mid pipe from a GSXR with carbon fiber Can that I want to put on my BWM F650 DAK I figure I can cut the Mid Pipe and then Cut the back section of the DAK pipe and weld the two together (or maybe have somebody do it)
I have a simple Lincoln AC buzz box for a welder Questions are: Can I use what I have to weld this pipe? If So what rods would be recommended? I have no clue what type stainless this would be 300 / 400 series ect ? If I can do this what would the recommended methods be?
There's a fine line between "RED ASS" and "DUMB ASS" "Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK |
12-30-2010, 04:31 PM
#1700 | |
moto junkie
Oddometer: 1,654
You will need Argon/CO2 for mild steel, or Tri-mix gas for stainless. Also, if doing exhaust work with existing tubing, make sure all the chrome is ground off the tubing, otherwise you will have impurities in the weld which will also cause the bead to not look the greatest. I'm no expert, but I've discovered that on very thin materials it's best to lay a series of tack welds upon one another similar to the TIG welding process. I just did some 18 ga. mild steel using this method, and it turned out great. edit - another thing I was just thinking of...too large of an arc length (the distance from the end of your torch to the welded surface) will also cause excess spatter. kirkster70 screwed with this post 01-03-2011 at 06:50 AM |
12-30-2010, 10:32 PM
#1701 |
the (in)famous boxer perv
Broken shock mount on a R1100GS frame - what's the best solution?
So guys I have a broken R1100GS shock mount on the rear subframe and stranded in Nairobi (read Nairobbery) in Kenya.
![]() ![]() ![]() ![]() ![]() This part takes extreme abuse under 2up fully loaded bike on very bad roads and trails. Any idea if there's any point bending it back together and welding it or will doing this just make it weaker and I'll have the same problem soon again? There's not much space to reinforce it - bottom recession needs space for shock movement, upper part is with seat mounts attached. Or it's better to cut the complete mounting part off and CNC a brand new one - stronger than original? Cutting it out is quite complicated as you can see, so it'll be a risky business as well. There's one CNC place here and some sorts of weldings are also possible. Any idas, thoughts are highly apreciated since I'm currently a stranded traveller because of this. Happy new year, Margus |
12-31-2010, 06:22 AM
#1702 | ||
ceiling unlimited
Oddometer: 1,806
Since the exhaust tube is a thin wall your dick (stick) welder is just about useless unless you want a crappy looking, leaking and weak welds. imo your only option would be to find someone to tig weld it. 300 or 400 sereis won't matter much as the welder will still use 308l filler. Quote:
I would reinforce and modify the existing on the seat side then cut away the seat to fit. Sacrifice a small chunk of the seat for the most important part, the frame.
sideways and smiling |
12-31-2010, 12:04 PM
#1703 | |
Oddometer: 6,469
Welded correctly it will be as strong as it was before it was broken. I think I would opt for straightening and bracing as best you can and then get a good weld on it. |
12-31-2010, 05:55 PM
#1704 |
n00balicious
Oddometer: 2,918
I personally would straighten it, then weld it, then attempt to brace it the best you can. I don't think that this type of part would be a good CNC'ed part.
"I couldn't wait for success, so I went ahead without it." |
12-31-2010, 06:05 PM
#1705 |
aka Road Monster
Take it to a welding shop. they should be able to make the repair. Any attempt to make this part stronger will only result in the next weakest link failing.
12-31-2010, 08:34 PM
#1706 |
Syndicated
Oddometer: 11,286
+1 on welding the cracked upper shock mount. Depending on access, you may have to cut off the seat mount bracket, make the weld to the shock tower, then reweld the seat mount bracket. All the subframe material is low carbon (aka: mild) steel, it isn't hardened. It can't be be hardened because of the low carbon content. The heat from welding will not change its strength. |
01-02-2011, 08:16 PM
#1707 | |
The Pre-Banned Version
Oddometer: 2,731
i would put a lettle bevel on both edges of the break than bend it back into place and weld it. than grind the weld down close to flush, and take a peice of strap (3/4 x 1/8 or something like that) and lay it over the weld, like you are puting a back up plate on it. but you are not working on a flat surface so you are going to have to tack one end and heat hammer bend and weld the strap into form, i have heard this called fish plating
you actually expect people to take responsibility for their actions in today's society?! |
01-08-2011, 01:24 PM
#1708 |
Oddometer: 258
I'm making my own steel shoe for flat track racing. I have a hard surface rod thats applied with a torch. Its not a flux core rod. I'm guessing this is like brazing and I need some form of flux. Thanks for any help.
01-08-2011, 05:25 PM
#1709 | |
Oddometer: 6,469
This may sound dumb but some of those rectangular and square bare rods are put on with an electric welder. They treat it like a stick electrode. |
01-08-2011, 05:35 PM
#1710 |
Ed
Oddometer: 425
are you sure about that?
I do a lot of cast iron repair and the cast filler rod I get for gas welding, (with a flux), is square in cross section. You can buy fluxes from your local supplier or you can make your own from anhydrous borax, silica sand and iron filings can be thrown into the mix as well. I use this last blend for forge welding, (hammer and anvil and a coal fire). E |
