01-12-2011, 08:13 AM
#226 | |
Oddometer: 3,814
"Deeply flawed people make deeply flawed decisions." |
01-12-2011, 10:13 AM
#227 | |
Oddometer: 569
In the photo it looks like the extended drain plug is missing. Maybe just the angle of the shot. I thought maybe you removed and modified your pan. |
01-12-2011, 12:01 PM
#228 |
Gravel Runner
Oddometer: 2,773
that's 15" with the bike on the stand, maybe 12" static to the pan and 10" to the underside of the exhaust with the bike on the ground. plenty for gravel.
jdrocks screwed with this post 01-12-2011 at 12:10 PM |
01-12-2011, 12:09 PM
#229 |
Gravel Runner
Oddometer: 2,773
nope, the drain is above the exhaust, so in my configuration it's not really exposed. more vulnerable are the mounting lugs for the stock belly fairings, but i've been using those mounts for a gravel guard with no problems.
01-12-2011, 06:14 PM
#230 |
Gravel Runner
Oddometer: 2,773
01-13-2011, 04:10 AM
#231 |
Gravel Runner
Oddometer: 2,773
you can see the battery box in the photo. the versys and 650R use the same box, and from the box forward on the subframe and frame, everything is identical between the frames for both bikes other than a few tabs for the plastics. from the box to the rear of the subframe, everything is different.
01-13-2011, 04:21 AM
#232 | |
Checks in the mail.
Oddometer: 2,972
Here's what happens when something grabs those mounting lugs. Left me stranded in the middle of nowhere. Wave hi to my pickup tube.
Go ahead, pull my finger.
01-13-2011, 05:08 AM
#233 |
Gravel Runner
Oddometer: 2,773
01-13-2011, 05:53 AM
#234 |
Oddometer: 273
You really do nice work, JD!
ALL ROADS LEAD TO ZEN MOTO |
01-13-2011, 08:22 AM
#235 |
Checks in the mail.
Oddometer: 2,972
i run a gravel guard. 6000 miles of gravel road, so far, so good.
[/QUOTE] If I remember it correctly mine made it up to about 35,000 miles "so far so good". It was the next mile after that hurt. When I hit the rock that tore the original plastic guard off, I have to say that I didn't think that the impact was that hard. So what I'm getting at is those mounting bosses are very weak. Other than those mounting points you did a really nice fab.
01-13-2011, 03:10 PM
#236 |
Gravel Runner
Oddometer: 2,773
01-13-2011, 03:31 PM
#237 | |
Gravel Runner
Oddometer: 2,773
what can't be seen in the photo is the steel pad between the gravel guard and the flat on the underside of the oil pan. the mounting holes are slightly oversized on the side supports and the guard is jacked hard against the oil pan before the fasteners are tightened. the guard can't be displaced directly upwards. the front supports are rock solid when tied directly to the motech bars. this is not a skid plate, but coupled with good composite strength and decent ground clearance, i sure think it's adequate for running gravel roads. the entire bike has been lifted many times with a floor jack placed under the guard. |
01-13-2011, 07:50 PM
#238 |
Gravel Runner
Oddometer: 2,773
the parts bike is pretty much gone, so i can get some photos of the subframe. the 650R is sitting in the foreground, so the photo doesn't show how much bigger the beast sitting behind it really is. the new build in back is huge in comparison, but i couldn't get a good photo angle.
![]() i mentioned earlier that the versys subframe was missing a few members that were incorporated in the 650R subframe. then came a report that a rider experienced some flex in his versys subframe when the rear footpeg struts were loose. that's not real good news, especially since you would think that the versys would have the stronger subframe of the two bikes. not so, and here's why. the 650R subframe has a tubular crossbrace on the main support tube that is missing on the versys subframe. ![]() in addition, the secondary subframe tubes on the 650R are connected by a hoop that ties the sides together, also missing on the versys. ![]() another view of brace and hoop on the 650R. ![]() the versys subframe has exactly the same stamped part that is welded on the 650R frame, but no connecting hoop. ![]() the 650R can carry a big load of gear on the back without a problem, but then they don't build the same strength into the versys subframe, even though the bike is promoted as the more rugged of the two. another mystery. |
01-14-2011, 04:04 AM
#239 |
Purveyor of Light
Oddometer: 3,664
Sometimes we forget the Ninja and the Versys are street bikes
![]() Your build is looking good. Is that an after market exhaust? I'm still waiting on the rear shock for mine.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
01-14-2011, 04:26 PM
#240 | |
Gravel Runner
Oddometer: 2,773
that must be an old photo, you have a different headlight now. that's an old TB can that i had in the shop and stuck it on there for fun. those things just make noise, about like having straight pipes. i hope to have my shock together next week. you still building rat bikes for your chick travel mates? |
