Old 01-04-2011, 08:12 PM   #391
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
Originally Posted by cmore View Post
This thing breath fire yet?? or R you just blowing smoke.
Probably not nearly as much fire as you were breathing on your drive back home
YZman is offline   Reply With Quote
Old 01-07-2011, 06:24 AM   #392
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
Holly Hell batman! Nuts and bolts gets expensive!
LineMcMaster
Part Number
Description/Customer ID #You
Ordered
We
Shipped
Balance
Due
Unit
Price
Extended
Amount
192949A58918-8 Ss Button Head Socket Cap Screw 5/16"-18 Thread, 1-3/4" Length
$6.21
298017A689300 Series Ss Nas 1149 Flat Washer 5/16" Sz, .562"od,.028"-.036"thk, Dash No. C0532r
$4.67
391831A03018-8 Stainless Steel Nylon-insert Hex Locknut5/16"-18 Thread Size, 1/2" Width, 11/32" Height
$6.93
492949A53718-8 Ss Button Head Socket Cap Screw 1/4"-20 Thread, 1/2" Length
$5.70
592146A02918-8 Stainless Steel Split Lock Washer 1/4" Screw Size, .49" Od, .06" Min Thick
$4.03
692949A53918-8 Ss Button Head Socket Cap Screw 1/4"-20 Thread, 5/8" Length
$6.64
79084K114Easy-to-machine Stainless Steel (type 303) 3/16" Thick, 5/8" Width, 1' Length
$6.14
889965K223Aluminum Tubing 3/8" Od, .277" Id, .049" Wall Thickness, 3' Length
$8.27
990024A070Metric 18-8 Stainless Steel Threaded Rod M6 Size, 1-meter Length, 1.00 Mm Pitch
$4.36
1091828A251Metric 18-8 Stainless Steel Hex Nut M6 Size, 1mm Pitch, 10mm Width, 5mm Height
$8.73
116750K161Multipurpose Anodized Aluminum (alloy 6061) 1/2" Diameter, 1' Length
$5.96
1292949A24918-8 Ss Button Head Socket Cap Screw 10-24 Thread, 1-1/4" Length
$8.17
1392949A24618-8 Ss Button Head Socket Cap Screw 10-24 Thread, 7/8" Length
$5.66
1491831A01118-8 Stainless Steel Nylon-insert Hex Locknut10-24 Thread Size, 3/8" Width, 15/64" Height
$6.53
1590313A20018-8 Ss Large-diameter Flat Washer No. 10 Screw Size, 1/2" Od, .03"-.05" Thick
$6.89
Merchandise Amount:$ 94.89
Old 01-07-2011, 06:57 AM   #393
bk brkr baker
bk brkr baker's Avatar
Oddometer: 4,147
It's not economical to buy 1 or 2 nuts or bolts at a time. I go to fastenal and buy them by the bag,100 at a time. Much cheaper by the piece.
You'll do more progects in the future,no?
Old 01-07-2011, 08:50 AM   #394
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
You'll do more projects in the future,no?
Oh agreed. Ill use them eventuly. Still dont make it feel any better paying the bill.
Got a new rear brake linkage in last night. And like everything else it doesnt work as delivered so I have more parts comeing (part of this order) to make it all play nice. It should look killer once done.
My coil brackets came in Wed, they look killer. They dont work either and will have to be re-worked. Hopefully tonight.
Should have some more picts up in the next few days once something note worthy starts happening.
And against my better judgment I rolled my next project onto the operating table (nothing like having 2 project going at the same time). 67 CT90. And wouldnt ya know it. The 1st new part I go to put on...dont work at all. Seat cover is wrong. Figures.
Old 01-07-2011, 09:10 AM   #395
England-Kev
Location: Berkshire, England. Just off the Beaten Track!
Oddometer: 2,567
Sweet, so the work is now starting on the CT then, you know if you need that special part for the BSA you only have to ask and I will see if I can find it for you...
England-Kev is online now   Reply With Quote
Old 01-07-2011, 09:57 AM   #396
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
The CT is getting nothing more than a britening and replacing a handfull of broken bits. No frame off resto for that one. This is just going to be filler work for when Im stuck on the BSA waiting for more parts to come in. I dont think it will take long to get back to working order.
I think Im actually sitting pretty good on BSA parts right now. At least on british parts. What I need for it now is just custom stuff for my application and even that Is getting to the end of the list. But thanks for the offer. Ill keep it in mind if I get stumped.
Old 01-12-2011, 07:30 PM   #397
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
Well all kinds of fun stuff going on this week. No pictures to speak of yet, Ill try tomorrow maybe.
Electronics panel finished and mounted
New parts for rear brake linkage have arrived, I started fabbing up parts for that
Got a new rear drum brake stay made (bottom link that goes between the drum and frame)
Started fabbing up rear fender mounts
new horn and switch on the way
Lots and lots of Stainless hardware ariving...almost every day
Figured out what the outter valve cover bolts are. They are 5/16-24. Got some and went to bolt the cover on....and...it dont fit. The head Im using is not the stock head. Its a 650 twin carb (stock was 500 single carb) the outter valve cover bolt holes in the head are wider than the holes in the valve cover. Anybody got an idea what year head I have and what valve cover to look for? I have an email in to my BSA guru. Im sure he will know (and probably have a valve cover)
Thats about it for now. Ill try and get some picts up latter.
Old 01-13-2011, 02:19 AM   #398
Hughlysses
Hughlysses's Avatar
Oddometer: 2,644
You just HAD to say you were "good" on BSA parts for a while, didn't you?
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 01-13-2011, 04:09 AM   #399
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
I was thinking the same thing.
I got an email from EV last night. Sounds like I have a 71-newer head and a 70-older valve cover. He is going to try and find the correct valve cover for me.
Old 01-13-2011, 10:18 AM   #400
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
Got my coil brackets modified. These brackets are meant to bolt to dune buggy frames and you then bolt like your tach to it. Its 2 pc polished aluminum. The hole is 1.5. My coil was 1.59. We milled the center out on my neighbors bridgeport CNC mill. Sooo much easier than using a dremal and turned out killer.
Sorry for the crappy camera phone picts.
Ill get some pics of it installed later tonight maybe.
And here is the rear drumb brake stay fresh off the drill press complete with speed holes ready for polishing
YZman screwed with this post 01-13-2011 at 02:39 PM
Old 01-13-2011, 11:00 PM   #401
jbcaddy
Oddometer: 939
ya gonna round off those corners? I love the holes! much better with the two sizes rather than just the large ones. JB
jbcaddy is offline   Reply With Quote
Old 01-14-2011, 10:10 AM   #402
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
better
Old 01-23-2011, 12:45 PM   #403
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
Got my rear brakes working
Got new K&N air filters and Taylor plug wires
And a new horn
Old 01-23-2011, 01:26 PM   #404
Hughlysses
Hughlysses's Avatar
Oddometer: 2,644
Startin' to look like a real motorsickle.
Old 01-25-2011, 04:07 AM   #405
YZman OP
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
Wicked
Ive avoided it long enough..... Time to mount the fender
It will be next week before I can get it welded and make the rear supports.
Times are GMT -7.   It's 09:24 AM.
