01-17-2011, 04:59 PM
#1 |
Plenty of seasoning
Oddometer: 707
Bulletproof skidplate for 990!
Received my new skidplate from Weld86 the other day and installed it with no problems. Charlie is selling them in Vendors - he built one for himself and a friend and a dozen more to recoup material costs, (edit: I think he is now in full production, the dozen was an initial run). Here is the link:
http://www.advrider.com/forums/showthread.php?t=647689&referrerid=129859 Lots of good pix there so I won't add mine here. I am very impressed with his work and the welds are things of beauty. They are made of tough alloy (5052? Cannot recall...) 1/4" plate. If you hit this hard enough to bend it you may be more concerned with your ER bill than your sump. Makes many of the other brands look like something you would wrap candy in. Charlie was doing a deal with throwing in a sidestand relocator that appears to be very strong too (haven't installed it to say for sure, but apparently made of the same material). My only association with Charlie is as a very satisfied customer.
2009 KTM Adventure RoundOz screwed with this post 10-11-2012 at 03:57 AM Reason: Changed conditions, less misleading |
01-17-2011, 05:17 PM
#2 | |
North Georgia Dual Sportr
Oddometer: 1,694
Nicest Skid Plate I've seen yet !!!
I just wished he made that same Skid Plate for my 950 Super Enduro ![]() I love that Natural Aluminum . . . . . . . especially in 1/4" Thick
2008 KTM 690 ENDURO ![]() http://www.advrider.com/forums/showp...postcount=1784 http://www.advrider.com/forums/showp...postcount=8594 http://advrider.com/forums/showpost....&postcount=683http://www.youtube.com/watch?v=gnFCdoc_IDE |
01-17-2011, 08:05 PM
#3 |
shazam.
Oddometer: 808
+1
yamaha wr250r | ktm 950se RIDES: Pop & Pax - West TAT 2009 | The Dean of Adventure Routes “Character is much easier kept than recovered.” –Thomas Paine |
01-17-2011, 08:17 PM
#4 |
Rough Rider
Oddometer: 829
Mine should be here any day. I'll be replacing the TouraTech that's
on my 990 now. This one looks bomb proof. I've also got the side stand support he makes. I'm planning on spraying mine with pickup bed coating, don't really like the silver. Max
Da oggi la strada é senza limiti |
01-17-2011, 08:24 PM
#5 |
MotorcycleMayhem
Oddometer: 2,154
bed liner is STICKY stuff... so if you do any "bashing" over rocks etc... the bike will not glide over them, it will stop or at least slow down. And if you get high centered on something it will take more effort to get the bike through/over it. Just sayin...
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
01-17-2011, 11:46 PM
#6 |
Oddometer: 294
you can put some WAX on the belly, to make sure you slide and glide before each ride)))))))
01-18-2011, 07:44 AM
#7 | |
Rough Rider
Oddometer: 829
I'll be sure not to bed line my KTM 300's skid plate but it's carbon anyway. My TT plate which is being replaced has around 100,000 mi. of use on LC8's and I have yet to be hung up on any rocks. With the Dupli Color pickup bed liner spray I use, one can control the texture achieved by the distance the can is held from the parts being sprayed. I also find that by clear coating over the bed liner a glossier look can be had. I've done many parts this way and have had good results, Skid plates, side panels, crash bars, the engine protection plate on my Ducati MTS 1200s, foot peg hangers, the frame on my KTM 300 was just finished with this method and looks and works fine. Twist it, Max
01-18-2011, 10:21 AM
#8 |
06 950 Adventure
Oddometer: 93
Hope you post up a pic or two Max when you get to it. I have used bedliner with good success as well.
Mine has shipped and I will have to mount it and, with the help of a few tasty ales, give it a look from several artistic angles as to whether it will look best raw and naked or with a coating of liner. |
01-18-2011, 10:14 PM
#9 | |
MotorcycleMayhem
Oddometer: 2,154
01-19-2011, 06:50 AM
#10 |
Rough Rider
Oddometer: 829
Aluminum plates are soft anyway no matter what.
That's why I run carbon composite ( Eline ) on the bikes I ride technical trails with, 300exc, 525 exc. Twist it, Max
01-19-2011, 02:46 PM
#11 |
out and about
Oddometer: 23
Skid marks
Those skid plates are awesome...albeit a little heavy. 8lbs I think. Still...whats a couple of extra pounds for something that can stop a bullet...
01-19-2011, 04:46 PM
#12 |
Plenty of seasoning
Oddometer: 707
Uh-Oh!!!
I can see this thread dissolving into a discussion about which firearms could punch a hole in the plate and which couldn't, all because of my poor choice of adjectives. The laborers/machine operators I used to work with in underground mines in Australia were known as "feds" and a common saying was "You can make something foolproof but you can't make it fed-proof"...maybe that would have been a better choice...
To get back off that tangent, if you are going to carry a little extra protection, below the belt is a better place than most...
2009 KTM Adventure |
01-19-2011, 07:39 PM
#13 |
Hooliganantic
So, rubber bedliner coating slides over things better than bare aluminium? Wait, glossy rubber bedliner slides over things better than bare aluminium? Hmmm, gosh, I guess I dont have to skin my guard in kydex, Ill just spray on rubber. Are'nt tires made of rubber? Just sayin'
01-21-2011, 07:39 AM
#14 |
Rough Rider
Oddometer: 829
You missed the point, I use the bed liner to make my skid plates
black not to make them slid over rocks easier. The clear coat adds a glossier sheen to it, which I like, it looks great on the belly pan of my Ducati MTS 1200. The other point was , those of us who ride lots of tech single track have learned that the ali plates are soft and really don't slide that well over rocks and many of us have switched to carbon or the new plastic plates available for that reason. Twist it, MAX
01-21-2011, 03:55 PM
#15 |
Oddometer: 356
PM sent
