Old 01-30-2011, 06:35 PM   #4366
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
Originally Posted by Cruz View Post
Hey Geoff, can you remember which ceramic coating you had applied?
Mine is still as good as new and cleans off very easily. They used the hardest one available on mine as the darker coating (which looks really good and you see on a lot of road and bigger adv bikes) chips off easily from small stones thrown up and even scratches from boot buckles etc. The cooling properties certainly do as advertised.
I never got the brand name. Got it done @ http://www.specializedcoating.com/index.htm in Huntington Beach, CA.
Mine is titanium colored which I was told is not one of the harder shades. But it has more baked-on tar than pits!
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 01-30-2011, 06:43 PM   #4367
Geoffster
Geoffster's Avatar
Oddometer: 1,373
Originally Posted by AZ-Twin View Post
I need a good GPS mount. The ram holder for the 60CSX sucks.
I find my RAM mount more than adequate. I mount in on the ball on the handlebar clamp:
I keep my 60CSX from vibrating in its mount with a hair scunci or two:
(I stay away from the pink and lime ones, BTW.)
Old 01-30-2011, 07:00 PM   #4368
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Geoff,
The ball, mount, and all that stuff is solid. The problem is the GPS sometimes bounces out of the holder. I use conventional rubber bands, I will get some of those hair ones. I also thought about one of those rubber bracelets that were in fashion a couple years ago.
I find the GPS decides to bounce out of it's cradle at the worst moment, when negotiating more difficult terrain.
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 01-30-2011, 07:07 PM   #4369
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
I had the same issue with the RAM for my 60CSx...I noticed that it occurred when the front suspension cycled the MOST...and therefore I guess that the front brake line would hit the cradle and "trigger" the GPS to pop out...
Relocating it to a different/higher angle, and using a hair band as well (I have long hair, black colored hair band please)...it works great ever since!
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 01-30-2011, 09:08 PM   #4370
mbfj40
Oddometer: 170
Hi Guys, After a bird strike at well over the speed limit popped the Zumu out of it's mount, I made up a simple safety gadget that 100% eliminates unwanted Zumo departures at speed. Also keeps your sleeve from unlatching the release when you reach over to reset the odometer or clock. I'll snap some pics asap..........
mbfj40 is offline   Reply With Quote
Old 01-30-2011, 09:14 PM   #4371
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,124
I use a strip of self adhesive velcro in the cradle and also on the rear of my Oregon to help keep it in place. Does not move a bit now and you have to 'tear' it off the velcro to remove from the cradle. Not sure on the design or shape of your cradle though.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz screwed with this post 01-31-2011 at 04:47 AM
Cruz is offline   Reply With Quote
Old 01-31-2011, 03:10 AM   #4372
Muddler
Muddler's Avatar
Oddometer: 779
Velcro sounds like a good idea. I smeared some silcon on the inside of the holder to improve fit, then I use a loop cut from inner tube to secure it. I use similar loops to secure the power lead to the gps (1/2 hitch on the cable), and at the other end, to the power socket.
I use a stip of self adhesive velcro in the cradle and also on the rear of my Oregon to help keep it in place. Does not move a bit now and you have to 'tear' it off the velcro to remove from the cradle. Not sure on the design or shape of your cradle though.
Muddler is offline   Reply With Quote
Old 01-31-2011, 06:21 AM   #4373
GB
Mod Squad
GB's Avatar
Oddometer: 56,744
There's no selling in Thumpers please. The selling post and replies have been moved to Vendors.
Old 01-31-2011, 06:53 AM   #4374
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,458
How do you knock a 60CSx out of the cradle? I have yet to do that. If it is bouncing a vibrating, you don't have it in the cradle right. Check how you used the security screw on the back, as it isn't locating correctly.
tbarstow is offline   Reply With Quote
Old 01-31-2011, 08:38 AM   #4375
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
I am certain I am putting the GPS in the cradle properly.
Below is a pic of the cradle I use, it is made by Ram. The security screw only holds on a rubber grommet that snaps into the ring on the pic. Others use a beefy rubber band to hold the GPS in. That tells me I am not the only one who has had this issue.
I will get better rubber bands for future use as mine must bee too wimpy. I may add some Velcro also.
Perhaps I will just roll a condom over the whole thing, then it will be waterproof, retained very well, and one hell of a conversation piece.
Cradle
Grommet
AZ-Twin screwed with this post 01-31-2011 at 05:59 PM
Old 01-31-2011, 10:53 AM   #4376
gsstampeder
gsstampeder's Avatar
Oddometer: 1,079
I am certain I am putting the GPS in the cradel properly.
Below is a pic of the cradle I use, it is made my Ram. The security screw only holds on a rubber grommet that snaps into the ring on the pic. Others use a beefy rubber band to hold the GPS in. That tells me I am not the only one who has had this issue.
Perhaps I will just roll a condom over the whole thing, then it will be waterproof, retained very well, and on hell of a conversation piece.
Cradle
Grommet
and i bet the little antenna should fit nicely in the reservoir
gsstampeder is offline   Reply With Quote
Old 01-31-2011, 12:19 PM   #4377
Geoffster
Geoffster's Avatar
Oddometer: 1,373
I run the scrunci between the mounting ball and the antenna. It lets the unit jiggle a little and, thus, the unit get scuffed on its base each ride. But that way, the scrunci doesn't interfere with the display or scratch it.
Others: ribbed and pre-lubricated?
Old 01-31-2011, 12:27 PM   #4378
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
I've had the lose of GPS problem.
I started running the Garmin lanard tied to the bars,for the chance of GPS departure.
The TT GPS cradle model that mounts on the bar riser is the way to go in my opinon.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 01-31-2011, 01:25 PM   #4379
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,458
I tried that and you can't see ithe GPS when you're standing up.
If your 60CSx moves in the cradle at ALL, you don't have it mounted in the cradle right.
Old 01-31-2011, 01:47 PM   #4380
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
I run street pilot's,i can't see 3" screens at 80mph sit'n or standing.
Times are GMT -7.   It's 11:20 AM.
