02-07-2011, 10:51 AM
#7321 | |
Oddometer: 1,381
Different opinions I guess. I don't think this is being productive to the XRR thread so I'd rather let it go.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
02-07-2011, 11:11 AM
#7322 |
fishing with dynamite
Oddometer: 2,029
I wasn't trying to be argumentative. Honest question, and I think it's as relevant as anything else that's been discussed in this thread. There are many accounts of 650R's going 20,000+ miles without any major service/overhauls. Whether you call it a race engine or not, seems to have proven itself to be pretty darn reliable. No big deal if I have to live with it burning a little bit of oil, but would rather address it if it's anything I can fix.
02-07-2011, 11:30 AM
#7323 |
Mors ex Tenebris
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,081
Mine "uses" a littl oil too when I ride the highway, which is most of the time.
As a result, I usually run a 15/44 gear combitation. Typically, I may need to add 8 oz. once I have exceded 500 miles after an oil change. I just am in the habit of checking the oil when I return home after each ride. It does not seem as bad at lower speeds, say 60 MPH and does not smoke, so the consumption is relatively slight. Even the full-blown race XRR's needed to add oil during the Baja 1000. It is in the nature of the beast. FWIW, I am the third owner of this bike and have added over 7,000 miles so far on the stock top end.-Joe -
The Marines...When it absolutely, positively has to be destroyed overnight. Trust and Respect take years to earn, but can be lost in a moment. Life's too short to hold a grudge. -Joe |
02-07-2011, 11:38 AM
#7324 |
Oddometer: 2,029
Thanks for the reply. We're running almost exactly the same gearing, and I'd guess that's about how much oil it's consuming. No big deal, but doesn't that seem excessive? I mean, what is it about these engines that they gobble-up oil?
02-07-2011, 11:54 AM
#7325 | |
r-u-n-n-o-f-t
Oddometer: 12,177
Yet the GB500, NX650/Dominator, XR650L, etc all used the same basic engine. There were differences in tuning, but the basics were the same - and the GB500 WAS design as a streetgoing machine - and I'll be 80% of the XR650L's out there are used on pavement more than offroad.
IBA #11735 . 1968-present |
02-07-2011, 12:05 PM
#7326 | |
Mors ex Tenebris
Oddometer: 3,081
-Joe
02-07-2011, 12:28 PM
#7327 | |
Oddometer: 1,381
It can be called whatever we want it to be called. I guess I'm the only one who doesn't expect this engine to last forever without issues. I'm fine with that. I'm on the mindset that it wasn't designed to drone for 1000's of miles on end without problems, and so I don't expect it to. I don't even know what's being talked about anymore. I'd sooner read about interesting things or important stuff rather then ramblings about how durable a thumper can be and what kind of mileage to expect from it. It's been covered before. (search for XRR and mileage) So with that said, I'll drop the subject so we can return back to our normal programing of quality XRR talk/reading.
02-07-2011, 01:18 PM
#7328 |
San Juan Island, WA
Oddometer: 579
If it is burning oil why don't you try out some different brands of quality oil and see if that makes a difference?
Should see some stay in there better than others. Joe |
02-07-2011, 01:43 PM
#7329 | |
Mors ex Tenebris
Oddometer: 3,081
-Joe
02-07-2011, 02:09 PM
#7330 |
Oddometer: 2,669
I wouldn't call the XR650R engine a "race engine". It's nowhere near as maintenance intensive as a current 450cc race engine. It's a low compression, low RPM engine comparatively.
Posted while shaving in my Pruis! 2000 XR650R |
02-07-2011, 03:40 PM
#7331 |
r-u-n-n-o-f-t
Oddometer: 12,177
I change the oil frequently enough, that if it did go through a bit of oil - it gets topped off with a fresh new supply before it could become an issue.
Lots of pavement miles puts you in the realm of checking it like you would a street bike - less often. In the dirt my oil gets looked at virtually every time I take it out.... if I were commuting on it, that inspection would probably get lax and normal consumption would seem to be exaggerated. For peace of mind, if I were riding that many pavement miles....I would just change the oil often, and the filter every other oil change. Then you could rest a bit easier.
02-07-2011, 08:17 PM
#7332 | |
Secret Agent
Oddometer: 4,526
Hi Ho Silver... Away! |
02-07-2011, 08:37 PM
#7333 |
Oddometer: 243
My experience with big singles is they all use oil when spun up. Big lung creates more crank case pressure at higher RPMs which makes the rings and valve seals job harder. The whole reason I got a XRR was because it was built to last with a relaxed maintenance schedule. No "racemotor" maintenance/rebuild schedule for me.
02-07-2011, 09:09 PM
#7334 |
Oddometer: 145
Before I ran a bunch of mud through the motor (not-so-fun story), I was commuting 100+ miles per day on pavement at 80mph. I was changing the oil roughly every 1,000 miles and checking it every fill-up. I had almost no oil consumption over the 1k miles between oil changes, as in I didn't ever need to add any. Here's the rebuild ready to go in: HRC Copy cam (XR's Only), Kibblewhite valves with 3-angle grind, new stock piston and rings, newly re-nikasil'd cylinder and a brand new TM-40
02-08-2011, 05:03 AM
#7335 | |
Road Hog
Oddometer: 2,892
Why do you think the CRF are a race engine? |
