02-08-2011, 09:49 AM
#91 |
STILL Jim Williams
Oddometer: 5,985
Bakers Percentage
Ok, here's a pretty good write up on bakers percentages from a bakery I used to work for. It just happened to pop up when I googled bakers percentage. Go figure..
Anyway, this is a good thing to know and understand since it helps manipulate ingredients, and understand the process a little more. This is also really easy to integrate into a spreadsheet if you're so inclined. Here's the link http://www.artisanbakers.com/percentage.html |
02-08-2011, 10:43 AM
#92 |
Oddometer: 831
Excellent!! Since I'm a beginner I might as well develop good habits from the start. I just want to spend some time perfecting a loaf of plain bread. Might experiment with varieties much later. But I'd just love to get the skills down to do that basic loaf well whenever/whereever I happen to want to. |
02-08-2011, 10:55 AM
#93 | |
STILL Jim Williams
Oddometer: 5,985
02-08-2011, 10:56 AM
#94 |
WeeBeastie
Oddometer: 18,228
going to start simple with the no knead type and see what happens.
My mum use to make fresh bread when I was growing up and that smell of the kitchen is like a time machine!
⊕R1200GS⊕ ⊕Zuma 125⊕ Save $5 on Smugmug "so9RUAXlMm0bE" |
02-08-2011, 01:02 PM
#95 | |
Oddometer: 831
02-08-2011, 06:03 PM
#96 |
Oddometer: 15
02-08-2011, 06:08 PM
#97 |
Oddometer: 15
Great thread. I've been making bread for a long time but only recently started using a levain. It's a lot different than using regular yeast.
Finally made a great baguette this weekend after temporarily giving up on some of the varieties of doorstops I have been making. I'm guessing that since I am used to a dough that is a lot drier, I am not using enough water in the dough. |
02-08-2011, 06:18 PM
#98 | |
STILL Jim Williams
Oddometer: 5,985
02-08-2011, 06:20 PM
#99 | |
STILL Jim Williams
Oddometer: 5,985
I love this one of that bread coming out of the oven from above
02-08-2011, 06:46 PM
#100 |
Riding Nomad™
Oddometer: 12,786
Yum!!!
02-08-2011, 10:22 PM
#101 |
WeeBeastie
Oddometer: 18,228
nice pics!
Bread is doing whatever it does for 12-18 hours. only thing there is no where in my house that is 70degrees so I wrapped the bowl and put it in the oven (off of course) to see if that helps keep it at a constant temp or as close as I can get this time of year. was a rush throw it together when I got home so I forgot the pics, will take some tomorrow when I see if it raised up or not
02-09-2011, 03:11 AM
#102 | |
STILL Jim Williams
Oddometer: 5,985
02-09-2011, 05:38 AM
#103 | |
Boring bastard
How do you feel about the pan o' hot water in the stove to keep the temps up for rising/proof/etc >? I've been leaving it in for the actual baking too, as my house induces nosebleeds with it's level of non-humidity.
I like cold wet doggy nose in my crack. |
02-09-2011, 07:18 AM
#104 | |
STILL Jim Williams
Oddometer: 5,985
Humidity in the oven is crucial for expansion of the final loaf. Without it, you get alot of busting out all over, and you won't achieve correct volume. I don't have much experience baking at home unfortunately. Any humidity you can get into the oven in the first 15min or so would be a good thing! The no-knead method as well as Chad Robertsons method described in Tartine use a covered dutch oven. That seems like a great technique to me. What is going to happen is all the moisture being driven off from baking will be trapped in the pot, and steam the bread. You'll need to take top off towards the end of the bake to drive off that moisture so you get a crust, and it obviously only works for round loaves. |
02-09-2011, 07:49 AM
#105 | |
Boring bastard
In the house, generally around 70. The heat pump does pretty well at keeping that within a degree or three. Differences in rise time outside of the oven and inside with a pan of hot water is about 2:1. That's for a double volume. My oven should be shot and then buried at sea. It's a travesty. I don't have a dutch anything at the moment. I'll give it a try once I do though. I'm going to try some dark bread this weekend.
| Thread Tools | |
