Old 08-23-2010, 10:30 AM   #151
electroman
6.02*10^23 Gigawatts
electroman's Avatar
Oddometer: 95
I bought HF's pneumatic framing nailer for a 750-sq. ft. job installing 3/4" oak flooring. It worked fine, cost less than renting a "good" one from Home Despot, and I was able to resell it to a friend, who then did a similar-sized job at his house.
I don't buy anything motorized there, though.
electroman is offline   Reply With Quote
Old 08-23-2010, 11:44 AM   #152
hugemoth
hugemoth's Avatar
Oddometer: 2,074
A couple years ago I bought a HF 1000 watt 4 stroke generator for $160 with 20% off coupon. A couple weeks later I went down and bought a 2 year exchange warranty for $35. After a few months it started smoking pretty bad on start up but ran good otherwise so I figured it was just a bad valve seal. Eventually carbon built up in the valve guide sticking the valve so there was no compression. By the time I took it in for an exchange they had discontinued that model and since they had nothing similar they gave me a refund for the full non sale price of $200.00. I made $5 on the deal and had 2 years of use. Had I not purchased the warranty I could have easily fixed it for a few dollars worth of parts.
Old 08-24-2010, 11:05 AM   #153
HapHazard
t00 0ld 2b n00b
HapHazard's Avatar
Oddometer: 1,287
Originally Posted by Plaka
The frame is hard to screw up.
Au contraire! A friend of mine ordered a press some years ago from HF, and the holes drilled in the legs didn't line up. He called HF, and they sent another set - and no, they didn't match each other either.
In the end, it really didn't matter, and it gave him some left over stock to use, but yes, they can (and have) screwed up the frame!
HapHazard is offline   Reply With Quote
Old 08-24-2010, 11:07 AM   #154
SteelRain
Beer Cooled
SteelRain's Avatar
Oddometer: 301
Only thing I ever had a problem with was the dirtbike lift.
My saftey wire pliers have worked on my SBK racebike for 8 years and show no signs of letting up.
SteelRain is offline   Reply With Quote
Old 02-13-2011, 10:41 AM   #155
NJ-GS
NJ-GS's Avatar
Oddometer: 768
Stuff from the Garage
Harbor Freight is a pretty cool store. Unfortunately, a lot of the things they sell are sub standard. They are pretty good about taking stuff back, as long as you have the receipt -- so save your receipts!
Thought I'd start a list of items that in my experience are junk. (I'll also start a thread with items that are worthy of purchasing, again, in my experience.) Please add to the lists. Here's the kick-off for junk:
1. hobby knife set - The handles appear to be solid metal, but are hollow and filled with cheap, breakable plastic. Broke on first use. Stick with Exacto.
2. "multipurpose" scissors - The blades stuck together and when pulling them apart, one of the handles snapped off. Lasted about 30 days. But hey, for $2, I pitched them and didn't bother returning.
3. motocross dirtbike stand - Absolute junk. Don't put anything other than a bicycle on this. The stand will topple and/or break.
A serious side effect of life is death. Ride while you can.
NJ-GS is offline   Reply With Quote
Old 02-13-2011, 12:40 PM   #156
NJ-GS
NJ-GS's Avatar
Oddometer: 768
"Stainless Steel" Glove
This one's going back. Was able to cut it with grade-school scissors.
The only thing "steel" about it is the color.
Old 02-14-2011, 06:48 AM   #157
tgeliot
Topher
Oddometer: 1,328
Originally Posted by Loudo View Post
I thought, "Hey, two pairs of m/c tie-downs for about a buck two ninety eight. Good deal!" So I gave a pair to a buddy who just bought a bike and doesn't have shit yet. We go to use them....OMG what utter shite they are. If you try to use the ratchet to tighten even a little bit the thing twists and goes into Safe Mode. Plus they're way too long. I ended up giving him my good pair of tie-downs, the simple kind with the one-way clasp you just pull tight.
Huh. I've used mine many times with no problems, to tie down everything from my Transalp to a pallet of squash.
Topher
1989 Transalp. Sort of.
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 02-14-2011, 10:39 AM   #158
mfp4073
mfp4073's Avatar
Oddometer: 1,353
I have worked at several restaurant running kitchens. Several years ago now I ended up starting at the bottom (IE, newbie) of a new chain. The "chef" was younger than me by a few years and wasnt too bad, but really was an idiot about some stuff. He "swore by" those mesh cut proof gloves. i knew better. Chain or nothing for me. They also didnt bother sharpening any of their knives. I brought my own that were proper. One day in an arguing match with him about these "cut proof mesh gloves" I finally set on on a cutting board and cut 2 fingers off with one of my knives in one smooth slice. Bunch of the other cooks sat looking wide eyed cause they trusted him that these things actually worked.
1974 BMW R90/6 Bettie #1
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is online now   Reply With Quote
Old 02-14-2011, 11:43 AM   #159
TheSweep
Oddometer: 98
Any powered tool I've used from HF is junk.
TheSweep is offline   Reply With Quote
Old 02-14-2011, 11:44 AM   #160
mfp4073
mfp4073's Avatar
Oddometer: 1,353
I have used the crap out of my HF angle grinder!
Old 02-14-2011, 12:32 PM   #161
Numb
Oddometer: 190
chinese knockoff garbage....
of course I tried in vain to find a corded drill at HD this weekend that was not made in china ... B&D, ridgid, dewalt, milwaukee, all china...
Numb is offline   Reply With Quote
Old 02-14-2011, 01:04 PM   #162
Riteris
Dessert Runner
Oddometer: 2,511
Yup. I went through this recently.
It really makes you wonder about how much you are paying for a brand name and/ or a particular color.
Chris
I am taking the advice of all those people that told me, "Hey kid, why don't you go play in traffic!"
Riteris is offline   Reply With Quote
Old 02-14-2011, 05:07 PM   #163
PoundSand
PoundSand's Avatar
Oddometer: 4,254
i like this guy. works fine. :P
PoundSand is offline   Reply With Quote
Old 02-14-2011, 05:17 PM   #164
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 1,652
Got the entry level angle grinder, about $10. Had to cut the bottom out of a dumpster, made it 3/4 the way around before meltdown. Got out the milwaukee and finished it. Returned the grinder to HF got my money back & upgraded to the $16 dollar model. I really wanted to see how long before the smoke leaked out
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is online now   Reply With Quote
Old 02-14-2011, 06:18 PM   #165
cyclingtom
Sim Sala Bim
cyclingtom's Avatar
Oddometer: 3,377
Originally Posted by duck View Post
The thread title is redundant.
Yep. You don't usually head to HF for the outstanding quality and craftsmanship. BTW, their two buck shop brushes are pretty nice.
Inconsequential Adventurer
Upon us all a little rain must fall. L.Z.
cyclingtom is offline   Reply With Quote
Times are GMT -7.   It's 11:16 PM.
